Project 14: Tweak the arduino logo || Weird values
I am getting weird vlaues from my potentiometer.
This is my code:
  Serial.write(analogRead(A0)/4);
  delay(1);
And the processing code:
import processing.serial.*;
Serial myPort;
PImage logo;
int bgcolor = 0;
void setup(){
  colorMode(HSB, 255);
  logo = loadImage("http://arduino.cc/logo.png");
  size(170, 116);
  println("Avaliable serial ports:");
  println(Serial.list());
  myPort = new Serial(this, Serial.list()[0], 9600);
void draw(){
  if (myPort.available() > 0) {
    bgcolor = myPort.read();
    println(bgcolor);
  background(bgcolor, 255, 255);
  image(logo, 0, 0);
I couldn't get logo.width and logo.height to work, so i just used 170 and 116.
The Arduino logo shows up but it stays red.
Thanks
Update Arduino code : Present Serial.write(analogRead(A0)/4);
Change: Serial.print(analogRead(A0)/4); OR Serial.println(analogRead(A0)/4);
Should solve the problem.
Update the following lines of code in the processing code and the logo.width and logo.height will also work.
logo = loadImage("https://www.arduino.cc/en/pub/skins/arduinoWide/img/logo.png"); size(logo.width, logo.height);
this can be a temporary fix for you i guess.
just change this
myport= new Serial(this, Serial.list()[0], 9600);
the number 0, change it to the right port that your arduino is connected. It didnt worked for me when it was 0, then i changed to 3(arduino was on COM3) didnt work either, 2 didnt work and 1 was the right one.
I had the same issue than you, using Processing 3.
The solution is to use the "while" keyword instead of "if" in the draw() function :
while (myPort.available() > 0) { bgcolor = myPort.read(); println(bgcolor); }
