I am working on a project/making a PCB that has:
1.) all components on one side, DFPlayer, Arduino Pro-Mini, regulator, resistors/caps..etc..
- the main modules will be connected using SMD male headers (not through hole)
2.) the other side is all 5050 WS2812 (Neopixel) leds.... current count and arrangement is still be worked out.. but in the range of: 36+ leds..... I would imagine roughly 1A or so being pulled by these (not full white and maybe a little blue, or just full white.. so maybe 25mA per led I'm roughly calculating at)
I have used these linear regulators in the past: (same pinout as the common LM7805 regulators... but this one is rated for up to 2A)
BA50DD0T
TO220FP-5
This datasheet is hard for me to read as the diagrams (to me.. I'm sure those more experience it might be easier)..
Anyways.. around page 14.. it says to use a:
*Please attach a capacitor (greater than 0.33μF) between the Vcc and GND
Then in diagram: Fig.32 Output Equivalent Circuit
- it shows using a 22uF cap on the output.
Do these need to polarized? (a tant or electrolytic type capacitor?)
In previous builds.. I used through hole electrolytic ones.. (been a while Id have to go back to be 100% sure)..
but now I want everything to be SMD (so ti can all remain on 1 side)..
Do they make 1206 sized caps that will work? Can I use 1206 ceramic caps in this?
Alternately.. if anyone has a schematic for for a DC-DC booster circuit (I have found some modules on ebay, but I'd rather have an Eagle schematic this time, to add it into the design itself, instead of an external module).. so I can just use a +3.7v li-ion pack.. instead of a +7.4v li-ion pack...
** I also have not found one that is fixed +5v output... and have over 1A of current.. (most say 400-500mA with +5 or more input)..
You guys are always good at showing me the way... and even sometimes...'shaming' me to the correct way! LOL
I'm also open to other solutions.. but not something that makes this project more difficult.... or is another 'project' in itself...
But if there is a different/better regulator to use..... or correct (polarized?) caps to be used.... or even swapping out to Boost circuit to use +3.7v li-ion packs..
Thanks!
