Hey gang-
I have a project I am working on.. its a mini-arduino based board.. that has on-board microSD socket.. and DAC/BUFFER/AMP for audio output.. (playing .wav files off SD card)
it was based off the WaveShield by Adafruit.. and use the WaveHC lib by default..
using same DAC.. an LM386 amp.....etc
got all pcb's ordered, stencil ordered, all components arrived...etc
assembled my first board.. and re-flowed in my toaster oven..
things worked GREAT!.. no re-flow fixes... no bridges (that I can see)..etc
took optiloader bootloader on first try.. and I loaded up a couple example sketches (blink) and they all loaded & worked fine..
I load the WaveHC lib.. to play the default (all .wav files from SD card in loop)... and it 'looks' as if its playing.
I see this when I view the serial monitor:
Wave test!
Free RAM: 688
Using partition 1, type is FAT16
Files found (* = fragmented):
0.WAV
1.WAV
2.WAV
3.WAV
4.WAV
5.WAV
6.WAV
7.WAV
8.WAV
9.WAV
P.WAV
Playing 0.WAV
Playing 1.WAV
Playing 2.WAV
Playing 3.WAV
Playing 4.WAV
** I am also powering the board externally to power the DAC correctly.. (in case anyone brings it up as a point of failure)
** I have tried 3 different, 1watt 8Ohm hobby speakers.. (intended use for this board was always this type of speaker)
looking for some help/sample code to directly send some data to the dac
any ideas?
thanks
