Hello, we are in high school and have a project to do.
We want to get 2 buttons and a H bridge working to change our 2 motors' direction of rotation.
However, our programm (on Tinkercad) doesn't work : we can't connect the 2nd button, and the motors work even when they are not supposed to.
We don't know if we did the connection correctly.
Can someone help us please?
Thanks!! ![]()
Here is the link to our Tinkercad: Circuit design 2 moteur + bouton + peh +capteur | Tinkercad
Here is our programm:
//Connection bouton
const int bouton = 1;
int etatBouton;
//Connection capteur distance
int sinal=6;
float distance;
// Motor A connections
int enA = 9;
int in1 = 8;
int in2 = 7;
// Motor B connections
int enB = 3;
int in3 = 5;
int in4 = 4;
// Set up du capteur
Serial.begin(9600); //on sait pas
pinMode(sinal,OUTPUT);
digitalWrite(sinal,LOW);
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Turn off motors - Initial state
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
directionControl();
etatBouton = digitalRead(bouton); //lire état bouton
read(); //lire la distance
distance=distance/2;
distance=distance*0.034029;
Serial.println(distance);
delay(100);
// This function lets you control spinning direction of motors
void directionControl() {
// Set motors to maximum speed
// For PWM maximum possible values are 0 to 255
analogWrite(enA, 255);
analogWrite(enB, 255);
//Conditions moteurs
if(distance<100 && etatBouton == 1){ //bouton pas appuyé
digitalWrite(in4, LOW); // les moteurs ne tournent pas
else if (distance>100 && etatBouton == 1){ // bouton pas appuyé
digitalWrite(in4, LOW); // Le moteur ne tourne pas
else if (distance<100 && etatBouton == 0){ // bouton appuyé
else if (distance>100 && etatBouton == 0){ // bouton appuyé
digitalWrite(in1, HIGH);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW); // Le moteur tourne
else{
digitalWrite(in4, LOW); // Le moteur s'arrête de tourner
void read(){
digitalWrite(sinal,HIGH);
delayMicroseconds(5);
digitalWrite(sinal, LOW);
pinMode(sinal,INPUT);
distance=pulseIn(sinal,HIGH);
