Project not working
Hello it's not working, I followed the guide and I don't know how to make it work, my code is correct and not erroring
Here's the code
//This code is to use with DS1302 RTC module + 4*4 Keypad + LCD i2c + Arduino + Buzzer
//After wiring the modules, the LCD will show the default date and time or the one set before
//The objective of this project is that you can set the RTC module from the keypad, and sure it will stay stored
//Then show it on the screen and after you can set your alarm.
//Refer to https://www.surtrtech.com or SurtrTech youtube channel for more information
#include <Keypad.h> //Libraries needed
#include <virtuabotixRTC.h>
#define I2C_ADDR 0x27 //LCD i2c stuff
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
virtuabotixRTC myRTC(2, 3, 4); //Wiring of the RTC (CLK,DAT,RST)
                               //If you change the wiring change the pins here also
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[numRows] = {12,11,10,9}; //Rows 0 to 3 //if you modify your pins you should modify this too
byte colPins[numCols]= {8,7,6,5}; //Columns 0 to 3
int i1,i2,i3,i4;
char c1,c2,c3,c4;
char keypressed,keypressedx;
int A_hour=NULL;
int A_minute=NULL;
int AlarmIsActive=NULL;
int buzzer = 13;
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
  lcd.begin (16,2); //Initialize the LCD
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home ();
  while(keypressed == NO_KEY){ //As long as no key is pressed we keep showing the date and time, I'm obliged to clear the screen everytime so the numbers don't get confused
                               //And I should add that little delay so the screen shows correctly otherwise it didn't work for me
  keypressed = myKeypad.getKey();
  lcd.clear(); //Here after clearing the LCD we take the time from the module and print it on the screen with usual LCD functions
  myRTC.updateTime();
  if(myRTC.hours==A_hour && myRTC.minutes==A_minute && AlarmIsActive==1 && myRTC.seconds >= 0 && myRTC.seconds <= 2){
    while(keypressedx == NO_KEY){
    tone(buzzer, 1000); //You can modify the tone or make your own sound
    delay(100);
    tone(buzzer, 2000);
    delay(100);
    lcd.clear();
    lcd.print("Wake up gorgeous"); //Message to show when the alarm is ringing
    keypressedx = myKeypad.getKey();
  keypressedx = NO_KEY;
  noTone(buzzer);
  lcd.setCursor(0,0);
  lcd.print(myRTC.);
  lcd.print("/");
  lcd.print(myRTC.month);
  lcd.print("/");
  lcd.print(myRTC.year);
  lcd.setCursor(0,1);
  lcd.print(myRTC.hours);
  lcd.print(":");
  lcd.print(myRTC.minutes);
  lcd.print(":");
  lcd.print(myRTC.seconds);
  delay(100);
         if (keypressed == '*') //As we everytime check the key pressed we only proceed to setup if we press "*"
              lcd.clear();
              lcd.print("     Setup");
              lcd.clear();
              lcd.print("Setup year");
              //So you can understand how this works, first it shows us "setup" then it prints "setup year" and now you can write your year normally (2-0-1-8)
              //It automatically passes to setting up the month...until it's finished
              //The keys from keypad are all considered chars (c) so we should convert them to int that's what I did then we store them (i)
              //We do some math and we get the year, month... as int so we can inject them to the RTC otherwise it will not be compiled
              //Months like April you should write 04, 03 for March... otherwise it will not pass to the next parameter
              //The RTC virtuabotix library is already set to not accept strange time and dates (45/17/1990) (58:90:70), and yes old dates are considered as errors
             char keypressed2 = myKeypad.waitForKey();
                    if (keypressed2 != NO_KEY && keypressed2 !='*' && keypressed2 !='#' && keypressed2 !='A' && keypressed2 !='B' && keypressed2 !='C' && keypressed2 !='D' )
                       c1 = keypressed2;
                       lcd.setCursor(0, 1);
                       lcd.print(c1);
                 char      keypressed3 = myKeypad.waitForKey();
                    if (keypressed3 != NO_KEY && keypressed3 !='*' && keypressed3 !='#' && keypressed3 !='A' && keypressed3 !='B' && keypressed3 !='C' && keypressed3 !='D' )
                       c2 = keypressed3;
                       lcd.setCursor(1, 1);
                       lcd.print(c2);
                   char  keypressed4 = myKeypad.waitForKey();
                   if (keypressed4 != NO_KEY && keypressed4 !='*' && keypressed4 !='#' && keypressed4 !='A' && keypressed4 !='B' && keypressed4 !='C' && keypressed4 !='D' )
                       c3 = keypressed4;
                       lcd.setCursor(2, 1);
                       lcd.print(c3);
                   char   keypressed5 = myKeypad.waitForKey();
                   if (keypressed5 != NO_KEY && keypressed5 !='*' && keypressed5 !='#' && keypressed5 !='A' && keypressed5 !='B' && keypressed5 !='C' && keypressed5 !='D' )
                       c4 = keypressed5;
                       lcd.setCursor(3, 1);
                       lcd.print(c4);
                     i1=(c1-48)*1000;        //the keys pressed are stored into chars I convert them to int then i did some multiplication to get the code as an int of xxxx
                     i2=(c2-48)*100;
                     i3=(c3-48)*10;
                     i4=c4-48;
                     int N_year=i1+i2+i3+i4;
                     lcd.clear();
                     lcd.print("Setup month");
                     char keypressed6 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed6 != NO_KEY && keypressed6 !='*' && keypressed6 !='#' && keypressed6 !='A' && keypressed6 !='B' && keypressed6 !='C' && keypressed6 !='D' )
                       c1 = keypressed6;
                       lcd.print(c1);
                    char   keypressed7 = myKeypad.waitForKey();
                    if (keypressed7 != NO_KEY && keypressed7 !='*' && keypressed7 !='#' && keypressed7 !='A' && keypressed7 !='B' && keypressed7 !='C' && keypressed7 !='D' )
                       c2 = keypressed7;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_month=i1+i2;
                     lcd.clear();
                     lcd.print("Setup Day");
                      char keypressed8 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed8 != NO_KEY && keypressed8 !='*' && keypressed8 !='#' && keypressed8 !='A' && keypressed8 !='B' && keypressed8 !='C' && keypressed8 !='D' )
                        c1 = keypressed8;
                       lcd.print(c1);
                      char keypressed9 = myKeypad.waitForKey();
                    if (keypressed9 != NO_KEY && keypressed9 !='*' && keypressed9 !='#' && keypressed9 !='A' && keypressed9 !='B' && keypressed9 !='C' && keypressed9 !='D' )
                        c2 = keypressed9;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_day=i1+i2;
                     lcd.clear();
                     lcd.print("Setup hour");
                     char keypressed10 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed10 != NO_KEY && keypressed10 !='*' && keypressed10 !='#' && keypressed10 !='A' && keypressed10 !='B' && keypressed10 !='C' && keypressed10 !='D' )
                       c1 = keypressed10;
                       lcd.print(c1);
                    char   keypressed11 = myKeypad.waitForKey();
                    if (keypressed11 != NO_KEY && keypressed11 !='*' && keypressed11 !='#' && keypressed11 !='A' && keypressed11 !='B' && keypressed11 !='C' && keypressed11 !='D' )
                        c2 = keypressed11;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_hour=i1+i2;
                     lcd.clear();
                     lcd.print("Setup minutes");
                    char keypressed12 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed12 != NO_KEY && keypressed12 !='*' && keypressed12 !='#' && keypressed12 !='A' && keypressed12 !='B' && keypressed12 !='C' && keypressed12 !='D' )
                        c1 = keypressed12;
                       lcd.print(c1);
                   char    keypressed13 = myKeypad.waitForKey();
                    if (keypressed13 != NO_KEY && keypressed13 !='*' && keypressed13 !='#' && keypressed13 !='A' && keypressed13 !='B' && keypressed13 !='C' && keypressed13 !='D' )
                        c2 = keypressed13;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_minutes=i1+i2;
                     lcd.clear();
                    myRTC.setDS1302Time(22, N_minutes, N_hour, 1, N_day, N_month, N_year); //once we're done setting the date and time we transfer to values to the RTC module
        //the 22 stands for seconds you can add a setup for it too if you want
        //the 1 stands for day of the week, as long I don't show it on the screen I don't change it
                    keypressed=NO_KEY; //the "*" key is stored in "keypressed" so I remove that value from it otherwise it will get me in the setup again
/////////////////////////////////////////Alarme setup/////////////////////////////////
             if (keypressed == 'A'){
              lcd.clear();
              lcd.print("  Alarm setup  ");
              lcd.clear();
              lcd.print("Set alarm hour");
               char keypressed14 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed14 != NO_KEY && keypressed14 !='*' && keypressed14 !='#' && keypressed14 !='A' && keypressed14 !='B' && keypressed14 !='C' && keypressed14 !='D' )
                       c1 = keypressed14;
                       lcd.print(c1);
                    char   keypressed15 = myKeypad.waitForKey();
                    if (keypressed15 != NO_KEY && keypressed15 !='*' && keypressed15 !='#' && keypressed15 !='A' && keypressed15 !='B' && keypressed15 !='C' && keypressed15 !='D' )
                        c2 = keypressed15;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_hour=i1+i2;
                     lcd.clear();
                     lcd.print("Set alarm minutes");
                      char keypressed16 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed16 != NO_KEY && keypressed16 !='*' && keypressed16 !='#' && keypressed16 !='A' && keypressed16 !='B' && keypressed16 !='C' && keypressed16 !='D' )
                       c1 = keypressed16;
                       lcd.print(c1);
                    char   keypressed17 = myKeypad.waitForKey();
                    if (keypressed17 != NO_KEY && keypressed17 !='*' && keypressed17 !='#' && keypressed17 !='A' && keypressed17 !='B' && keypressed17 !='C' && keypressed17 !='D' )
                        c2 = keypressed17;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_minute=i1+i2;
                     lcd.clear();
                      AlarmIsActive=1;
                      keypressed=NO_KEY;
             if (keypressed == 'B')
              lcd.clear();
              lcd.print("Alarm deactivated");
              AlarmIsActive=0;
              keypressed=NO_KEY;
             else {
              myRTC.updateTime();
              keypressed=NO_KEY;
This is the guide I am following
Please, answer to the following questions:
1. Are you using DS3231 Module for the RTC?
2. What is the purpose of the Keypad? Are you entering any Password?
3. What is the purpse of RTC? Are you keeping the time of the day?
4. Under what condition, the buzzer will turn On?
or
Using plain text, bieflly describe the purpose of your project.
Im making an digital alarm clock, im using ds1302 RTC, buzzer is for the alarm
Do you need to have a button cell battery in the RTC for it to work? If so, make sure you use the right one. You may need a rechargeable version.
Can't I use it without the battery?
Yes, I just checked. You can use it without a battery. Sorry. My mistake.
Maybe placing some debug Serial.println() commands in your code might help. You can send messages to your computer from different points in your code. You can see the results looking at the Serial Monitor in the Arduino IDE.
  Serial.println("Debug: About to initialize LCD."); // Debug message
  Serial.println("Debug: LCD initialized and BACKLIGHT power set."); // Debug message
  lcd.home ();
  Serial.println("Debug: Setup complete."); // Debug message
My lcd is not turning on, huhu how can I fix this
Are you using paralll port driven LCD or I2C Bus drive LCD -- I mean which one of the follow?
(Figure-1: Parallel Port driven LCD
Figure-2: I2C Bus driven LCD
Are you using paralll port driven LCD (Fig-1) or I2C Bus drive LCD (Fig-2) -- I mean which one of the follow?
Figure 2
Disconnect everything from the Arduino board except the display. Now first work on getting the display to turn on. Once that works, add one other component of your choice; e.g. the keypad. Get that to work. And so on.
I already try that, still not workingT-T
Show how you have the display connected.
Ok!
Follow these procedures called SSS Methodology (Start with Small Step) and be sure that you will come up with a working project.
1. Remove all connections for everything from the Ardino UNO.
2. Connect your i2CLCD with UNO as per Fig-1. Before connection that that the jumpers are not broken and you can to this checkinh using a series resistor LED or a DVM st at sound.
Figure-1:
3. Uplaod the followinh sketch:
#include<LiquidCrystal_I2C.h>
#include<Wire.h>
#define slaveAddress 0x27
LiquidCrystal_I2C lcd(slaveAddress, 16, 2);
  Wire.begin();
  lcd.begin();//or lcd.init();
  lcd.backlight();
  lcd.setCursor(0, 0);  //DPos (0-15), LPos (0-1)
  Wire.beginTransmission(slaveAddress);
  byte busStatus = Wire.endTransmission();
  if (busStatus != 0)
    Serial.println("I2CLCD is not found!");
    while (1); //wait for ever
  Serial.print("I2CLCD is found!");
  lcd.print("Hello");
void loop() {}
4. Check that the following message has appeared on LCD.
Hello
If Step-4 is not correct, do the following change in the sketch of Step-3 and re-load the sketch.
===> #define slaveAddress 0x3F
Also, if compiltation error comes, do the following change:
lcd.begin();
===> lcd.init();
What library I will install for that?
LiquidCrystal_I2C.h
I have battery now but idk what's the problem with my set up its still not working please help🥹
Let's have a look at your setup first. As asked before:
There's no guessing as to what's going wrong without information on the circuit you have. Now there's a battery that wasn't mentioned anywhere before...
This is the reference I am following
