Prototype Enclosure for Project
Hi All!
I've finally reached the point where I want a more solid enclosure for my Arduino project. The project is going along the lines of a guitar footswitch, and the problem I've had with finding pre-made enclosures online is that I need the top face to be at an angle (see: http://static.music123.com/derivates/18/001/261/292/DV016_Jpg_Large_483489.001_black_footswitch.jpg). My project needs six switches/leds, however, so the top face will likely be around 12" x 6", with a depth of 1" in the front to 2" in the back. I'm absolutely clueless on where I should go for getting a custom (or maybe not custom? but I need it to be very similar at the least) enclosure made on a budget. The material doesn't matter, but it has to be able to take a stomp from a foot, so I suppose it has to be relatively strong so I was thinking of going the metal route. I'm open to 3D printing or other approaches as well, I just don't know much about this part of the design and definitely need it to be affordable. I'm going to make ten this first time around, not a very big number at all. Should I ask around locally? Or does anyone have a website they recommend? Thanks a lot for input in advance!
Pat
Find a sturdy box/cover, and mount it on an angled base?
Aluminum box might be better:
Pick a size ...
Thanks for the reply, although since this isn't the first prototype I'm trying to get something a little closer to what the finished product may be. I just came across the hammond enclosures, specifically the 1456 series:
http://www.hammondmfg.com/pdf/9c2pg79.pdf
This is ideal for what I need, specifcally the PH1 style, although upon further measuring, I've realized I need something around the ballpark of 12"x6", but I suppose 14"x8" should suffice for now (maybe I'll take a saw to it if it's really a problem). They're on mouser for ~$35 which is a number I'm willing to say yes to. I'm still all ears for suggestions though! I know there's a lot out there...
Assuming you have been around the musical stuff, you may know that a lot of stuff for musicians is fabricated of MDF and then covered in a cloth. with that in mind, you can make a base, sides and even the angle with MDF and then lay on metal panels to allow you to drill holes and mount things.
