Proximity sensor
I want to make a project where the sensor detects a strip of metal coming into position .
I want the sensor to be very accurate
What sensor should i use ?
jerome1234:
The correct sensor for your exact specification.
You need to give much more detail of your problem e.g.
what metal is the strip made of, how big is it, what does "come into position mean", how far away is the metal before it is in position, how close is it after it is in position, how fast is it moving, what does "very accurate" mean?
It is probably best if you also gave a general description of what you are trying to do, how far you have got yourself and what your skill are.
jerome1234:
Ultrasound, magnetic, inductive, capacitive, optical, pressure and conduction sensors are examples that could all do what you want depending on your actual project. There may be other general types as well.
