* This file is part of PsxNewLib. *
* Copyright (C) 2019-2020 by SukkoPera <software@sukkology.net> *
* PsxNewLib is free software: you can redistribute it and/or *
* modify it under the terms of the GNU General Public License as published by *
* the Free Software Foundation, either version 3 of the License, or *
* (at your option) any later version. *
* PsxNewLib is distributed in the hope that it will be useful, *
* but WITHOUT ANY WARRANTY; without even the implied warranty of *
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
* GNU General Public License for more details. *
* You should have received a copy of the GNU General Public License *
* along with PsxNewLib. If not, see http://www.gnu.org/licenses. *
* This sketch will dump to serial whatever is done on a PSX controller. It is
* an excellent way to test that all buttons/sticks are read correctly.
* It's missing support for analog buttons, that will come in the future.
* This example drives the controller through the hardware SPI port, so pins are
* fixed and depend on the board/microcontroller being used. For instance, on an
* Arduino Uno connections must be as follows:
* CMD: Pin 11
* DATA: Pin 12
* CLK: Pin 13
* Any pin can be used for ATTN, but please note that most 8-bit AVRs require
* the HW SPI SS pin to be kept as an output for HW SPI to be in master mode, so
* using that pin for ATTN is a natural choice. On the Uno this would be pin 10.
* It also works perfectly on OpenPSX2AmigaPadAdapter boards (as it's basically
* a modified Uno).
* There is another similar one using a bitbanged protocol implementation that
* can be used on any pins/board.
#include <DigitalIO.h>
#include <PsxControllerHwSpi.h>
#include <avr/pgmspace.h>
typedef const __FlashStringHelper * FlashStr;
typedef const byte* PGM_BYTES_P;
#define PSTR_TO_F(s) reinterpret_cast<const __FlashStringHelper *> (s)
// This can be changed freely but please see above
const byte PIN_PS2_ATT = 10;
const byte PIN_BUTTONPRESS = A0;
const byte PIN_HAVECONTROLLER = A1;
const char buttonSelectName[] PROGMEM = "Select";
const char buttonL3Name[] PROGMEM = "L3";
const char buttonR3Name[] PROGMEM = "R3";
const char buttonStartName[] PROGMEM = "Start";
const char buttonUpName[] PROGMEM = "Up";
const char buttonRightName[] PROGMEM = "Right";
const char buttonDownName[] PROGMEM = "Down";
const char buttonLeftName[] PROGMEM = "Left";
const char buttonL2Name[] PROGMEM = "L2";
const char buttonR2Name[] PROGMEM = "R2";
const char buttonL1Name[] PROGMEM = "L1";
const char buttonR1Name[] PROGMEM = "R1";
const char buttonTriangleName[] PROGMEM = "Triangle";
const char buttonCircleName[] PROGMEM = "Circle";
const char buttonCrossName[] PROGMEM = "Cross";
const char buttonSquareName[] PROGMEM = "Square";
const char* const psxButtonNames[PSX_BUTTONS_NO] PROGMEM = {
buttonSelectName,
buttonL3Name,
buttonR3Name,
buttonStartName,
buttonUpName,
buttonRightName,
buttonDownName,
buttonLeftName,
buttonL2Name,
buttonR2Name,
buttonL1Name,
buttonR1Name,
buttonTriangleName,
buttonCircleName,
buttonCrossName,
buttonSquareName
byte psxButtonToIndex (PsxButtons psxButtons) {
byte i;
for (i = 0; i < PSX_BUTTONS_NO; ++i) {
if (psxButtons & 0x01) {
psxButtons >>= 1U;
return i;
FlashStr getButtonName (PsxButtons psxButton) {
FlashStr ret = F("");
byte b = psxButtonToIndex (psxButton);
if (b < PSX_BUTTONS_NO) {
PGM_BYTES_P bName = reinterpret_cast<PGM_BYTES_P> (pgm_read_ptr (&(psxButtonNames[b])));
ret = PSTR_TO_F (bName);
return ret;
void dumpButtons (PsxButtons psxButtons) {
static PsxButtons lastB = 0;
if (psxButtons != lastB) {
lastB = psxButtons; // Save it before we alter it
Serial.print (F("Pressed: "));
for (byte i = 0; i < PSX_BUTTONS_NO; ++i) {
byte b = psxButtonToIndex (psxButtons);
Serial.print (PSTR_TO_F (bName));
psxButtons &= ~(1 << b);
if (psxButtons != 0) {
Serial.print (F(", "));
Serial.println ();
void dumpAnalog (const char *str, const byte x, const byte y) {
Serial.print (str);
Serial.print (F(" analog: x = "));
Serial.print (x);
Serial.print (F(", y = "));
Serial.println (y);
const char ctrlTypeUnknown[] PROGMEM = "Unknown";
const char ctrlTypeDualShock[] PROGMEM = "Dual Shock";
const char ctrlTypeDsWireless[] PROGMEM = "Dual Shock Wireless";
const char ctrlTypeGuitHero[] PROGMEM = "Guitar Hero";
const char ctrlTypeOutOfBounds[] PROGMEM = "(Out of bounds)";
const char* const controllerTypeStrings[PSCTRL_MAX + 1] PROGMEM = {
ctrlTypeUnknown,
ctrlTypeDualShock,
ctrlTypeDsWireless,
ctrlTypeGuitHero,
ctrlTypeOutOfBounds
PsxControllerHwSpi<PIN_PS2_ATT> psx;
boolean haveController = false;
void setup () {
fastPinMode (PIN_BUTTONPRESS, OUTPUT);
fastPinMode (PIN_HAVECONTROLLER, OUTPUT);
delay (300);
Serial.begin (115200);
Serial.println (F("Ready!"));
void loop () {
static byte slx, sly, srx, sry;
fastDigitalWrite (PIN_HAVECONTROLLER, haveController);
if (!haveController) {
if (psx.begin ()) {
Serial.println (F("Controller found!"));
delay (300);
if (!psx.enterConfigMode ()) {
Serial.println (F("Cannot enter config mode"));
PsxControllerType ctype = psx.getControllerType ();
PGM_BYTES_P cname = reinterpret_cast<PGM_BYTES_P> (pgm_read_ptr (&(controllerTypeStrings[ctype < PSCTRL_MAX ? static_cast<byte> (ctype) : PSCTRL_MAX])));
Serial.print (F("Controller Type is: "));
Serial.println (PSTR_TO_F (cname));
if (!psx.enableAnalogSticks ()) {
Serial.println (F("Cannot enable analog sticks"));
//~ if (!psx.setAnalogMode (false)) {
//~ Serial.println (F("Cannot disable analog mode"));
//~ delay (10);
if (!psx.enableAnalogButtons ()) {
Serial.println (F("Cannot enable analog buttons"));
if (!psx.exitConfigMode ()) {
Serial.println (F("Cannot exit config mode"));
haveController = true;
if (!psx.read ()) {
Serial.println (F("Controller lost :("));
fastDigitalWrite (PIN_BUTTONPRESS, !!psx.getButtonWord ());
dumpButtons (psx.getButtonWord ());
byte lx, ly;
psx.getLeftAnalog (lx, ly);
if (lx != slx || ly != sly) {
dumpAnalog ("Left", lx, ly);
slx = lx;
sly = ly;
byte rx, ry;
psx.getRightAnalog (rx, ry);
if (rx != srx || ry != sry) {
dumpAnalog ("Right", rx, ry);
srx = rx;
sry = ry;
delay (1000 / 60);
That's the code in the examples that works with my wireless controller. Could you shed some light what the code would be to turn a servo 90 degrees when I press for example the left button on the controller?
Here you can find the libary I used link
Thanks in advance
