PS2X Library + TB6560 stepper driver
#include <PS2X_lib.h>       //for v1.6 PS2 Library
#define PS2_DAT        12  //14
#define PS2_CMD        11  //15
#define PS2_SEL        10  //16
#define PS2_CLK        9  //17
#define dirPin 7
#define stepPin 8
#define dirPin1 4
#define stepPin1 5
#define stepsPerRevolution 3200
//analog values read from PS2 joysticks
int LX = 0;
int LY = 0;
int RX = 0;
int RY = 0;
   select modes of PS2 controller:
     - pressures = analog reading of push-butttons
     - rumble    = motor rumbling
   uncomment 1 of the lines for each mode selection
#define pressures   true
//#define pressures   false
//#define rumble      true
#define rumble      false
PS2X ps2x; // create PS2 Controller Class
int error = 0;
byte type = 0;
byte vibrate = 0;
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(stepPin1, OUTPUT);
  pinMode(dirPin1, OUTPUT);
  delay(300);  //added delay to give wireless ps2 module some time to startup, before configuring it
  //setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
  error = ps2x.config_gamepad(PS2_CLK, PS2_CMD, PS2_SEL, PS2_DAT, pressures, rumble);
  if (error == 0) {
    Serial.print("Found Controller, configured successful ");
  else if (error == 1)
    Serial.print("No controller found, check wiring, see readme.txt to enable debug. visit www.billporter.info for troubleshooting tips");
  else if (error == 2)
    Serial.print("Controller found but not accepting commands. see readme.txt to enable debug. Visit www.billporter.info for troubleshooting tips");
  else if (error == 3)
    Serial.print("Controller refusing to enter Pressures mode, may not support it. ");
  Serial.print(ps2x.Analog(1), HEX);
  type = ps2x.readType();
  switch (type) {
    case 0:
      Serial.print("Unknown Controller type found ");
    case 1:
      Serial.print("DualShock Controller found ");
    case 2:
      Serial.print("GuitarHero Controller found ");
    case 3:
      Serial.print("Wireless Sony DualShock Controller found ");
      error = 0;
      type = 1;
  ps2x.read_gamepad(false, vibrate); //read controller and set large motor to spin at 'vibrate' speed
  delay(50);
  if (ps2x.Button(PSB_L1))
    LY = ps2x.Analog(PSS_LY);                     //receive values from p22 joystick
    LX = ps2x.Analog(PSS_LX);
  if (ps2x.Button(PSB_R1))
    RY = ps2x.Analog(PSS_RY);
    RX = ps2x.Analog(PSS_RX);
  if (LY > 200 || RY > 200)                       //check if the joystick pushed up side
    Lfast();
  if (LY < 100 || RY < 100)
    Lslow();
  if (LX < 100 || RX < 100)
    Rslow();
  if (LX > 200 || RX > 200)
    Rfast();
  if (LX == 128 && LY == 128 && RX == 128 && RY == 128)
    Stop();
  LY = LX = 128;         //return to default vlaues
  RY = RX = 128;         //return to default values
void Lfast()
  //Serial.print("Left fast");
  digitalWrite(dirPin, HIGH);
  digitalWrite(stepPin, HIGH);
  delayMicroseconds(200);
  digitalWrite(stepPin, LOW);
void Lslow()
  //Serial.print("Left slow");
  delayMicroseconds(2000);
void Rfast()
  //Serial.print("Right fast");
  digitalWrite(dirPin, LOW);
void Rslow()
  //Serial.print("Right slow");
void Stop()
  //Serial.print("Stop");
//**************END**************************
Hi All,
This is my very first post on the forum. I usually try to figure everything out myself, but this time i gut stuck. I have a PS2 controller (wireless) hooked up to a arduino UNO, TB6560 stepper driver en nema 23 stepper motor. The code attached compiles nicely en works.. kinda. I want to use 1 joystick to control the direction and speed of the motor. I made a setup without a ps2 controller and just a analog joystick and this works fine. but now i want to do this via the ps2 controller.
The main issue here is that the motor speed is not what it should be when i use the ps2 controller. I think this "delay" has something to do with the communication between the ps2 controller and the arduino or stepper driver. Or i made a mistake in de code. I would appreciate any help.
Regards,
Mark (NL)
