PS4 USB Library
Hello,
I want connect the PS4 controller to USB HOST SHIELD ARDUINO by using USB port for getting all the press buttons in the serial monitor,I have used the PS4USB EXAMPLE.
I uplaoded the code and I got in the serial monitor this message "PS4 USB Library Started",but when I press the PS4 buttons nothing appeared in the serial monitor.
HARDWARE USED: - Arduino uno
  • USB HOST SHIELD
    -PS4 CONTROLLER (DOUBLESHOCK 4)
Any help please I will appreciate that.
 Example sketch for the PS4 USB library - developed by Kristian Lauszus
 For more information visit my blog: http://blog.tkjelectronics.dk/ or
 send me an e-mail:  kristianl@tkjelectronics.com
#include <PS4USB.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
USB Usb;
PS4USB PS4(&Usb);
bool printAngle, printTouch;
uint8_t oldL2Value, oldR2Value;
#if !defined(__MIPSEL__)
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); // Halt
  Serial.print(F("\r\nPS4 USB Library Started"));
  Usb.Task();
  if (PS4.connected()) {
    if (PS4.getAnalogHat(LeftHatX) > 137 || PS4.getAnalogHat(LeftHatX) < 117 || PS4.getAnalogHat(LeftHatY) > 137 || PS4.getAnalogHat(LeftHatY) < 117 || PS4.getAnalogHat(RightHatX) > 137 || PS4.getAnalogHat(RightHatX) < 117 || PS4.getAnalogHat(RightHatY) > 137 || PS4.getAnalogHat(RightHatY) < 117) {
      Serial.print(F("\r\nLeftHatX: "));
      Serial.print(PS4.getAnalogHat(LeftHatX));
      Serial.print(F("\tLeftHatY: "));
      Serial.print(PS4.getAnalogHat(LeftHatY));
      Serial.print(F("\tRightHatX: "));
      Serial.print(PS4.getAnalogHat(RightHatX));
      Serial.print(F("\tRightHatY: "));
      Serial.print(PS4.getAnalogHat(RightHatY));
    if (PS4.getAnalogButton(L2) || PS4.getAnalogButton(R2)) { // These are the only analog buttons on the PS4 controller
      Serial.print(F("\r\nL2: "));
      Serial.print(PS4.getAnalogButton(L2));
      Serial.print(F("\tR2: "));
      Serial.print(PS4.getAnalogButton(R2));
    if (PS4.getAnalogButton(L2) != oldL2Value || PS4.getAnalogButton(R2) != oldR2Value) // Only write value if it's different
      PS4.setRumbleOn(PS4.getAnalogButton(L2), PS4.getAnalogButton(R2));
    oldL2Value = PS4.getAnalogButton(L2);
    oldR2Value = PS4.getAnalogButton(R2);
    if (PS4.getButtonClick(PS))
      Serial.print(F("\r\nPS"));
    if (PS4.getButtonClick(TRIANGLE)) {
      Serial.print(F("\r\nTraingle"));
      PS4.setRumbleOn(RumbleLow);
    if (PS4.getButtonClick(CIRCLE)) {
      Serial.print(F("\r\nCircle"));
      PS4.setRumbleOn(RumbleHigh);
    if (PS4.getButtonClick(CROSS)) {
      Serial.print(F("\r\nCross"));
      PS4.setLedFlash(10, 10); // Set it to blink rapidly
    if (PS4.getButtonClick(SQUARE)) {
      Serial.print(F("\r\nSquare"));
      PS4.setLedFlash(0, 0); // Turn off blinking
    if (PS4.getButtonClick(UP)) {
      Serial.print(F("\r\nUp"));
      PS4.setLed(Red);
    } if (PS4.getButtonClick(RIGHT)) {
      Serial.print(F("\r\nRight"));
      PS4.setLed(Blue);
    } if (PS4.getButtonClick(DOWN)) {
      Serial.print(F("\r\nDown"));
      PS4.setLed(Yellow);
    } if (PS4.getButtonClick(LEFT)) {
      Serial.print(F("\r\nLeft"));
      PS4.setLed(Green);
    if (PS4.getButtonClick(L1))
      Serial.print(F("\r\nL1"));
    if (PS4.getButtonClick(L3))
      Serial.print(F("\r\nL3"));
    if (PS4.getButtonClick(R1))
      Serial.print(F("\r\nR1"));
    if (PS4.getButtonClick(R3))
      Serial.print(F("\r\nR3"));
    if (PS4.getButtonClick(SHARE))
      Serial.print(F("\r\nShare"));
    if (PS4.getButtonClick(OPTIONS)) {
      Serial.print(F("\r\nOptions"));
      printAngle = !printAngle;
    if (PS4.getButtonClick(TOUCHPAD)) {
      Serial.print(F("\r\nTouchpad"));
      printTouch = !printTouch;
    if (printAngle) { // Print angle calculated using the accelerometer only
      Serial.print(F("\r\nPitch: "));
      Serial.print(PS4.getAngle(Pitch));
      Serial.print(F("\tRoll: "));
      Serial.print(PS4.getAngle(Roll));
    if (printTouch) { // Print the x, y coordinates of the touchpad
      if (PS4.isTouching(0) || PS4.isTouching(1)) // Print newline and carriage return if any of the fingers are touching the touchpad
        Serial.print(F("\r\n"));
      for (uint8_t i = 0; i < 2; i++) { // The touchpad track two fingers
        if (PS4.isTouching(i)) { // Print the position of the finger if it is touching the touchpad
          Serial.print(F("X")); Serial.print(i + 1); Serial.print(F(": "));
          Serial.print(PS4.getX(i));
          Serial.print(F("\tY")); Serial.print(i + 1); Serial.print(F(": "));
          Serial.print(PS4.getY(i));
          Serial.print(F("\t"));
Hello, have you found a solution to this problem? because am struggling with the same issue.
This older thread was moved to a more appropriate section of the forum.
