I'm working on a project that is controlled by a ps4 controller but I'm having a hard time figuring out what's wrong with the code. It's the same code that's used in the USB HOST shield 2.0 library PS4BT but it never works when I try to pair it with the controller. Everything else works except for the code any help. I'm using the Arduino web editor for compiling if that helps.
Example sketch for the PS4 Bluetooth library - developed by Kristian Lauszus
For more information visit my blog: http://blog.tkjelectronics.dk/ or
send me an e-mail: kristianl@tkjelectronics.com
#include <PS4BT.h>
#include <usbhub.h>
// Satisfy the IDE, which needs to see the include statment in the ino too.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
USB Usb;
//USBHub Hub1(&Usb); // Some dongles have a hub inside
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the PS4BT class in two ways */
// This will start an inquiry and then pair with the PS4 controller - you only have to do this once
// You will need to hold down the PS and Share button at the same time, the PS4 controller will then start to blink rapidly indicating that it is in pairing mode
PS4BT PS4(&Btd, PAIR);
// After that you can simply create the instance like so and then press the PS button on the device
//PS4BT PS4(&Btd);
bool printAngle, printTouch;
uint8_t oldL2Value, oldR2Value;
#if !defined(__MIPSEL__)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while (1); // Halt
Serial.print(F("\r\nPS4 Bluetooth Library Started"));
Usb.Task();
if (PS4.connected()) {
if (PS4.getAnalogHat(LeftHatX) > 137 || PS4.getAnalogHat(LeftHatX) < 117 || PS4.getAnalogHat(LeftHatY) > 137 || PS4.getAnalogHat(LeftHatY) < 117 || PS4.getAnalogHat(RightHatX) > 137 || PS4.getAnalogHat(RightHatX) < 117 || PS4.getAnalogHat(RightHatY) > 137 || PS4.getAnalogHat(RightHatY) < 117) {
Serial.print(F("\r\nLeftHatX: "));
Serial.print(PS4.getAnalogHat(LeftHatX));
Serial.print(F("\tLeftHatY: "));
Serial.print(PS4.getAnalogHat(LeftHatY));
Serial.print(F("\tRightHatX: "));
Serial.print(PS4.getAnalogHat(RightHatX));
Serial.print(F("\tRightHatY: "));
Serial.print(PS4.getAnalogHat(RightHatY));
if (PS4.getAnalogButton(L2) || PS4.getAnalogButton(R2)) { // These are the only analog buttons on the PS4 controller
Serial.print(F("\r\nL2: "));
Serial.print(PS4.getAnalogButton(L2));
Serial.print(F("\tR2: "));
Serial.print(PS4.getAnalogButton(R2));
if (PS4.getAnalogButton(L2) != oldL2Value || PS4.getAnalogButton(R2) != oldR2Value) // Only write value if it's different
PS4.setRumbleOn(PS4.getAnalogButton(L2), PS4.getAnalogButton(R2));
oldL2Value = PS4.getAnalogButton(L2);
oldR2Value = PS4.getAnalogButton(R2);
if (PS4.getButtonClick(PS)) {
Serial.print(F("\r\nPS"));
PS4.disconnect();
else {
if (PS4.getButtonClick(TRIANGLE)) {
Serial.print(F("\r\nTriangle"));
PS4.setRumbleOn(RumbleLow);
if (PS4.getButtonClick(CIRCLE)) {
Serial.print(F("\r\nCircle"));
PS4.setRumbleOn(RumbleHigh);
if (PS4.getButtonClick(CROSS)) {
Serial.print(F("\r\nCross"));
PS4.setLedFlash(10, 10); // Set it to blink rapidly
if (PS4.getButtonClick(SQUARE)) {
Serial.print(F("\r\nSquare"));
PS4.setLedFlash(0, 0); // Turn off blinking
if (PS4.getButtonClick(UP)) {
Serial.print(F("\r\nUp"));
PS4.setLed(Red);
} if (PS4.getButtonClick(RIGHT)) {
Serial.print(F("\r\nRight"));
PS4.setLed(Blue);
} if (PS4.getButtonClick(DOWN)) {
Serial.print(F("\r\nDown"));
PS4.setLed(Yellow);
} if (PS4.getButtonClick(LEFT)) {
Serial.print(F("\r\nLeft"));
PS4.setLed(Green);
if (PS4.getButtonClick(L1))
Serial.print(F("\r\nL1"));
if (PS4.getButtonClick(L3))
Serial.print(F("\r\nL3"));
if (PS4.getButtonClick(R1))
Serial.print(F("\r\nR1"));
if (PS4.getButtonClick(R3))
Serial.print(F("\r\nR3"));
if (PS4.getButtonClick(SHARE))
Serial.print(F("\r\nShare"));
if (PS4.getButtonClick(OPTIONS)) {
Serial.print(F("\r\nOptions"));
printAngle = !printAngle;
if (PS4.getButtonClick(TOUCHPAD)) {
Serial.print(F("\r\nTouchpad"));
printTouch = !printTouch;
if (printAngle) { // Print angle calculated using the accelerometer only
Serial.print(F("\r\nPitch: "));
Serial.print(PS4.getAngle(Pitch));
Serial.print(F("\tRoll: "));
Serial.print(PS4.getAngle(Roll));
if (printTouch) { // Print the x, y coordinates of the touchpad
if (PS4.isTouching(0) || PS4.isTouching(1)) // Print newline and carriage return if any of the fingers are touching the touchpad
Serial.print(F("\r\n"));
for (uint8_t i = 0; i < 2; i++) { // The touchpad track two fingers
if (PS4.isTouching(i)) { // Print the position of the finger if it is touching the touchpad
Serial.print(F("X")); Serial.print(i + 1); Serial.print(F(": "));
Serial.print(PS4.getX(i));
Serial.print(F("\tY")); Serial.print(i + 1); Serial.print(F(": "));
Serial.print(PS4.getY(i));
Serial.print(F("\t"));
