Pt1000 converting Resistance to Temp
Hi im trying to create a function that converts resistance to temperature with the values from a pt1000 sensor!
float ConvertRtoT(float R) {
    float A=3.9083 * pow(10,-3);
    float B=5775 * pow(10,-7);
    float T;
    T = (0-A + sqrt(pow(A,2) - 4 * B * (1 - R/1000))) / 2 * B;
    Serial.print(T);
    Serial.print(";");
    T=(0-A - sqrt(pow(A,2) - 4 * B * (1 - R/1000))) / 2 * B;
    Serial.print(T);
    return T;
the value of R is 1090Ohm but i only get 0.00;-0.00 C temp.
The equation that im trying to use looks like this:
R = R0 * (1 + AT + BT^2 -100CT^3 + C*T^4)
where
R = resistance of sensor in ohms
R0 = resistance at zero degrees Celsius in ohms (100 for Pt100, and 1000 for Pt1000)
T = temperature in degrees Celsius
A = 3.908310^-3
B = -5.775
10^-7
C = -4.183*10^-12 for T < 0 degrees Celsius
C = 0 for T >= 0 degrees Celsius
Using the pow function like this is expensive:
float A = 3.9083E-3;
is a perfectly valid way of initializing A, without the need for a function call.
pow(A,2) is again a slow way of computing A * A.
Try changing all the integers in the expression to floats. (4 -> 4.0).
Try printing intermediate values. Somewhere, you are performing integer arithmetic when you don't want to be (probably because of the integer values in the equation).
Ok i changed the code like this:
float ConvertRtoT(float R,float R0) {
    float A=3.9083E-3;
    float B=5775E-7;
    float T;
    R=R/R0;
    T = (0.0-A + sqrt(A*A - 4.0 * B * (1.0 - R))) / 2.0 * B;
    Serial.print(T);
    Serial.print(";");
    T=  (0.0-A - sqrt(A*A - 4.0 * B * (1.0 - R))) / 2.0 * B;
    Serial.print(T);
    return T;
But still no change in the values!
From your first post:
B = -5.775*10^-7
From your last post:
float B=5775E-7;
B is 3 orders of magnitude off, and with the wrong sign.
ooops must be a copy error =) still no change in the output though
I suggested that you break the function up into smaller pieces, and print intermediate results.
You've shown no input, no output, and no proof that there is a problem.
Ball's back in your court.
Fixed it!
float GetPlatinumRTD(float R,float R0) {
    float A=3.9083E-3;
    float B=-5.775E-7;
    float T;
    R=R/R0;
    //T = (0.0-A + sqrt((A*A) - 4.0 * B * (1.0 - R))) / 2.0 * B;
    T=0.0-A;
    T+=sqrt((A*A) - 4.0 * B * (1.0 - R));
    T/=(2.0 * B);
    if(T>0&&T<200) {
      return T;
    else {
      //T=  (0.0-A - sqrt((A*A) - 4.0 * B * (1.0 - R))) / 2.0 * B;
      T=0.0-A;
      T-=sqrt((A*A) - 4.0 * B * (1.0 - R));
      T/=(2.0 * B);
      return T;
