PubSubClient callback not executing
Hi! I am using ESP32-C3-DevKitM-1, HC-SR04 ultrasonic sensor and external LED. For MQTT I am using PubSubClient library. Publishing works fine but receiving doesn't work. I think that callback function is not executing, because in MQTT Explorer I am receiving messages, but I don't see in monitor "Starting callback". I don't know what to do anymore, please help
#include <TimeLib.h>
#include <WiFi.h>
#include <PubSubClient.h>
// WiFi credentials
const char* ssid = "ssid";
const char* pass = "pass";
// MQTT broker details
const char* mqttServer = "xxx.xx.xx.xx";
const int mqttPort = 30000;
const char* mqttTopic = "json/BR_Real";
const char* username = "user";
const char* password = "pass";
// HC-SR04 Ultrasonic Sensor
const int trigPin = 4;
const int echoPin = 5;
// External LED
const int ledPin = 3;
WiFiClient wifiClient;
PubSubClient mqttClient(wifiClient);
float readDistance();
void connectToWiFi();
void connectToMQTT();
void publish(float distance, int led);
void callback(char* topic, byte* payload, unsigned int length);
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.println("Starting callback");
float readDistance() {
  // Trigger the ultrasonic sensor
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the echo duration
  long duration = pulseIn(echoPin, HIGH);
  // Calculate the distance based on the speed of sound
  float distance = duration * 0.034 / 2;
  return distance;
void connectToWiFi() {
  WiFi.begin(ssid, pass);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
void connectToMQTT() {
  mqttClient.setServer(mqttServer, mqttPort);
  mqttClient.setCallback(callback);
  while (!mqttClient.connected()) {
    Serial.println("Connecting to MQTT...");
    if (mqttClient.connect("ESP32-c3", username, password)) {
      Serial.println("Connected to MQTT");
      bool result = mqttClient.subscribe("all/BR_Real", 0);
      Serial.printf("Subscribed: %d\n", result);
      mqttClient.setKeepAlive(90);
      Serial.print("Failed to connect to MQTT, rc=");
      Serial.println(mqttClient.state());
      delay(2000);
void publish(float distance, int led) {
    time_t timestamp = now();
    char msg[300];
    snprintf(msg, sizeof(msg),
        "\"header\":{\"timeStamp\":%ld},"
        "\"body\":{"
        "\"BikeRentalActuator\":{\"BikeRentalLed\":%d},"
        "\"BikeRentalHC-SR04\":{\"BikeRentalDistance\":%.2f}}}",
          timestamp, led, distance);
    bool status = mqttClient.publish(mqttTopic, msg);
    if (status) {
      Serial.printf("Sending `%s` to topic `%s`\n", msg, mqttTopic);
      Serial.printf("Failed to send message to topic %s.", mqttTopic);
void reconnect() {
    if (mqttClient.connect("clientID", username, password)) {
      bool result = mqttClient.subscribe("all/BR_Real");
      delay(2000);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  connectToWiFi();
  connectToMQTT();
  delay(2000);
  if (!mqttClient.connected()) {
    reconnect();
  mqttClient.loop(); // Maintain  MQTT communication
  delay(100);
  float distance = readDistance();
  if (distance < 0.5) {
    digitalWrite(ledPin, HIGH);
    publish(distance, 0);
Monitor output is:
Connected to WiFi
Connected to MQTT
Subscribed: 1
Sending `"header":{"timeStamp":6},"body":{"BikeRentalActuator":{"BikeRentalLed":0},"BikeRentalHC-SR04":{"BikeRentalDistance":0.00}}}` to topic `json/BR_Real`
Connected to MQTT
Subscribed: 1
Welcome to the forum
If you do not see the message indicating that the callback() function has been executed then the obvious conclusion would be that no message has been received
Does the sketch connect to WiFi ?
Does the sketch ever connect to the broker ?
Do you see the printouts indicating that the message has been sent ?
It prints out "Connected to WiFi" and "Connected to MQTT", so I think sketch is connected to broker and WiFi? I think that message is arrived beacuse I see message in MQTT Explorer. Sorry I am new to Arduino.
Look closely at the topic that you are publishing to and the topic that you are subscribing to
Are they the same ?
How they can be same? Publishing is working correctly
If you publish to json/BR_Real but do not subscribe to it would you expect to receive any massages from it ?
I have to publish to json/BR_Real but subsribe to all/BR_Real
That does not answer my question
Why do you need to publish to one topic and subscribe to another ?
As an experiment try publishing and subscribing to the same topic
Because purpose of subscribing is to receive messages from a topic and publishing is meant for sending messages to a topic. It is recommended to use two different topic for publishing and subsribing. That's how it is configured in platform that I am connecting to publish and subsribe.
Please explain in simple terms what the sketch is supposed to do. What is publishing to the all/BR_Real topic ?
I have to receive message from all/BR_Real topic. Meesage contains LED status, if LED = 1 turn on external LED, wait 10 seconds and then turn off external LED. I have to publish to json/BR_Real my distance returned from ultrasonic sensor and led status. Therefore I have to subscribe to all/BR_Real topic and publish to json/BR_Real
Now we are getting somewhere
So, something is publishing to the all/BR_Real topic.
Are you sure that this is happening correctly ?
