hi, my photoresistor doesn't perform properly, always got the highest value no matter how bright or dark my room was, so I went thought lots of tutorials and they mentioned that I will might have to use a 10k resistor for a better result. But I also came across something called "pull down resistor" which too do the trick, because I don't have any resistor around 10k on hand, so I dug deeper and found that there is a pull up resistor in arduino itself "digitalWrite(pin, HIGH)", but It doesn't says anything about the internal pull down resistor, does it exist?
Pull down doesn't exist. But you still can make it works with pull - up, connecting LDR between pin and ground, and reverse reading in software, so lower value would correspond to higher brightness.
can you show me how a pull up resistor can achieve this? I'm a complete arduino noob XD
Take a look at the schematic in this photo:
http://www.oomlout.co.uk/images/large/IC-PHOTO-10_01_LRG.jpg
This is how I have mine wired, they work great.
Try
Serial.begin(9600); //Start serial communication
digitalWrite(A0, HIGH); //Enable internal pull-up for analog pin 0
Serial.print(analogRead(A0)); //Send value for analog pin 0
