I have connected my LDR between A0 and 3volts on my board and a 10k resistor between 3volts and ground, as i have seen on a schematic,
but i only get high values, its giving 1024 even in low light and it only goes down to 600 even if i cover it,
i tried to change the resistor to 3.3k ohms but its still the same.
is there a problem with the sensor or the resistor value?
Your schematic is wrong if it shows those connections.
Or for a simple test, connect the LDR from analog input to ground. Set the pinMode of the input to INPUT_PULLUP to enable the internal pullup resistor. Then no external resistor is needed.
example of LDR on input pullup analog input pin:
const byte ldrPin = A0;
Serial.println("LDR Test Program");
pinMode(ldrPin, INPUT_PULLUP);
static unsigned long timer = 0;
unsigned long interval = 1000;
if (millis() - timer >= interval)
timer = millis();
int ldrReading = analogRead(ldrPin);
Serial.print("ldr reading = ");
Serial.println(ldrReading);
Reads low numbers when in light, high when dark. Often when using the internal pullup the sensitivity is OK, but if not then use an external resistor.
So you need to drop the value of the resistor in the circuit shown in reply #2.
For best results measure the resistance of the LDR in the mid light level you want and make the resistor as close to this value as you can.
szevlin:
Try the resistor between A0 and gnd, with the LDR between 3V and A0.
Tom... ![]()
