ductcord:
Ok, thanks for trolling my threaded with your half hearted suggestions to use magic pixie dust.
You might want to check your smirk at the door.
and
"Hey, you accidentally answered the actual question."
no, you did not ask a question.
go back and read your first post.
please define "1/4 of slippage"
and "Total movement will be 30 inches"
You have left out a huge amount of information and have not offered a drawing of your design.
I would use sliding rails with fixed length bars as the main support to hold the desk at level.
and only use the motor to open and close. eliminate the nonsense of trying to hold a motor or drive in a position. yes, nonsense. unless you expect it to have multiple positions, which you did not mention.
You are asking for selection of a device without any real information.
If your desk is a hinged table top that rotates from the wall to create a work platform, total weight of the platform and keyboard being 30 pounds. add to that your leaning, pressing, writing, coffee cup and what-not.
The hinge carries the bulk of the weight. the mechanical bits you want to add to open and close should be engineered. not cobbled together, but calculations and clever design to allow for additional forces not expected. (I may have the only overweight cat that ever jumped on a desk....)
The linear actuator located 6 inches from the hinge would be out of the way when extended and while the circumference of the arc of travel of 90 degrees is 30 inches, and your 19 inch table (doing the math) you only need a short stroke.
If you have cables that are 30 inches long , fixed at the end of the desk and you rotate 90 degrees, your 21.2 inch desk (again, doing the math) would open and close with different holding forces. or, did you mean that the platform would extend 30 inches ?
As was mentioned, you really have not offered much in the way of details.
As for your question. if you wanted to know how to hold a thing in position, then all the rest was not needed, a simple "how can I lock a thing in position with a 30 pound load ?"
would have sufficed.
sketches, crayon on paper and your cell phone would be more than enough.
We are here with the best intentions and try to do higher engineering without the whole project, details, scope, etc
I have not offered solutions on this thread as there was just so little information.
maybe you did not have enough coffee, or I had too much.....
