I need help please how to control a 9v pulse latching solenoid valve.
It needs only a pulse and a reversed pulse to open/close.
I have tried with an 500mA adaptor directly, and works fine.
I have external power supply to feed the valve instead of the arduino board.
Can somebody show some example circuit please how to do this?
I have checked this, but it is enough??
cjdelphi:
A 2n2222 would suffice, a flyback diode in reverse across the relay should do it.
Would that work for a solenoid that needs to be driven both ways? Perhaps a bipolar capacitor would work better in that case, together with a resistor to limit the inrush current?
cjdelphi:
He wanted a pulse, that would work, but to unlatch it does it require 0v or -5v?
Needs current flow pulses in both directions, one to latch, one to unlatch.
H-bridge is the way to go.
If 500mA makes it work, then L293D should be sufficient.
Internal diodes, no external diodes needed.
