I have a project, in which I am using Pulse oximeter sensor(MAX30100), GPS(NEO-6M), Accelerometer (MPU6050). Here, I am trying to use all three sensors simultaneously and send the data to BLYNK app. This is the code I am using - ( )
#include <TinyGPSPlus.h>
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#define REPORTING_PERIOD_MS 1000
#define BLYNK_PRINT Serial
#include <Blynk.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#include <Arduino.h>
#include <HardwareSerial.h>
char auth[] = "VUjbOe139IPotsyC2Sjx-MQbB54al9s0";
float latitude , longitude;
String lat_str , lng_str;
// For Pulse sensor
PulseOximeter pox;
float BPM, SpO2;
uint32_t tsLastReport = 0;
// For Accelerometer sensor
const int MPU_addr=0x68;
int16_t accelX, accelY, accelZ, gyroX, gyroY, gyroZ;
float gForceX, gForceY, gForceZ,rotX, rotY, rotZ, Tmp;
WiFiClient client;
TinyGPSPlus gps;
HardwareSerial SerialGPS(2);
void onBeatDetected()
Serial.println("Beat Detected!");
WiFi.begin("Dhoni Finishes off in Style", "123456789");
// Wait for wifi to be connected
uint32_t notConnectedCounter = 0;
delay(100);
Serial.println("Wifi connecting...");
notConnectedCounter++;
if(notConnectedCounter > 50) { // Reset board if not connected after 5s
Serial.println("Resetting due to Wifi not connecting...");
ESP.restart();
Serial.print("Wifi connected, IP address: ");
SerialGPS.begin(9600, SERIAL_8N1, 16, 17);
Blynk.begin(auth,"Dhoni Finishes off in Style", "123456789");
Serial.println("Initializing Pulse Oximeter..");
if (!pox.begin())
Serial.println("FAILED");
for(;;);
Serial.println("SUCCESS");
pox.setOnBeatDetectedCallback(onBeatDetected);
// The default current for the IR LED is 50mA and it could be changed by uncommenting the following line.
pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
// Reading data from Accelerometer sensor
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
accelX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
accelY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
accelZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read();
gyroX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
gyroY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
gyroZ=Wire.read()<<8|Wire.read();
gForceX = (accelX-2050) / 16384.0;
gForceY = (accelY-77) / 16384.0;
gForceZ = (accelZ-1947) / 16384.0;
rotX = (gyroX+270) / 131.0;
rotY = (gyroY-351) / 131.0;
rotZ = (gyroZ+136) / 131.0;
// calculating Amplitute vactor for 3 axis
float Raw_Amp = pow(pow(gForceX,2)+pow(gForceY,2)+pow(gForceZ,2),0.5);
int Amp = Raw_Amp * 10; // Mulitiplied by 10 bcz values are between 0 to 1
int angleChange = pow(pow(rotX,2)+pow(rotY,2)+pow(rotZ,2),0.5);
// Reading data from pulseoximeter sensor
pox.update();
BPM = pox.getHeartRate();
SpO2 = pox.getSpO2();
if (SerialGPS.available() > 0) {
if (gps.encode(SerialGPS.read()))
if (gps.location.isValid())
latitude = gps.location.lat();
lat_str = String(latitude , 6);
longitude = gps.location.lng();
lng_str = String(longitude , 6);
// Uploading data to Blynk server AND printing data on serial monitor
if (millis() - tsLastReport > REPORTING_PERIOD_MS)
Blynk.run();
Blynk.virtualWrite(V3, BPM);
Blynk.virtualWrite(V4, SpO2);
Serial.println(Amp);
Serial.println(angleChange);
Serial.print("Heart rate:");
Serial.print(BPM);
Serial.print(" bpm / SpO2:");
Serial.print(SpO2);
Serial.println(" %");
Serial.print("Latitude = ");
Serial.println(lat_str);
Serial.print("Longitude = ");
Serial.println(lng_str);
//Blynk.virtualWrite(V0, 1, latitude, longitude, "Location");
tsLastReport = millis();
It works completely fine. But when I'm trying to send gps coordinates to blynk app then pulse sensor stops working. i.e. -
Can you point out what's wrong with the program.
