Hi!
im want to creating a pump control so need some help to do that.
my hardware : Arduno mega and a 4 relay board (Opto Switched (HIGH=off),(LOW=on))
Relay board link :https://potentiallabs.com/cart/image/cache/catalog/Arduino/4-channel%20relay%20Module-800x800.jpg
So im want to creating this setup:
if im push button 1 the relay 1 (PUMP1) is ON, if im unpressed the button 1 the relay 1 is OFF
Secound state:
if im push button 1 the relay 2 (PUMP2) is ON, if im unpressed the button 1 the relay 2 is OFF
so this is a state machine if im not wrong.
Third state:
if im push button 2 the relay 1- 2 (PUMP1 AND PUMP2) is ON, if upress button 2 relays is OFF
but need some delay after relay 1 (PUMP1) is on.
a last state:
if im push button 3 the relay 3 (ALARM) is ON if upress button 3 relay is OFF
this is want to working.
int PUMP1 = 2;
int PUMP2 = 3;
int ALARM = 4;
int SensorButton1 = 9;
int SensorButton2 = 8;
int SensorButton3 = 10;
int state = 0;
int old = 0;
int buttonState = 0;
pinMode(SensorButton1, INPUT_PULLUP);
pinMode(SensorButton2, INPUT_PULLUP);
pinMode(SensorButton3, INPUT_PULLUP);
pinMode(PUMP1, OUTPUT);
pinMode(PUMP2, OUTPUT);
pinMode(ALARM, OUTPUT);
digitalWrite(PUMP1, HIGH);
digitalWrite(PUMP2, HIGH);
digitalWrite(ALARM, HIGH);
///////////////////////////////////////// STAGE 1
buttonState = digitalRead(SensorButton1);
if (buttonState == 1)
delay(800);
if (buttonState == 0)
state = old + 1;
delay(400);
switch (state)
case 1:
if (digitalRead(SensorButton1) == LOW)
digitalWrite(PUMP1, LOW);
else if (digitalRead(SensorButton1) == HIGH)
old = state;
case 2:
digitalWrite(PUMP2, LOW);
old = 0;
///////////////////////////////////////// STAGE 2
if (digitalRead(SensorButton2) == LOW)
///////////////////////////////////////// STAGE 3
if (digitalRead(SensorButton3) == LOW)
digitalWrite(ALARM, LOW);
any help would be good.
