Push Button Counter Code Issue
Hey all, I am having a problem with my code and was hoping someone could help shed some light on how to fix it. Below is a code for an arduino push button counter. The concept is that there are 2 buttons, an "add" button and "subtract" button. Every time add is pressed it adds 1 to the count and vice versa when subtract is hit. The code works fine until we hit double digits. Once you subtract from 1 from 10 the LCD displays 90 not 9. Not sure how to fix this, any ideas?
#include <LiquidCrystal.h>
LiquidCrystal lcd(1, 2, 4, 5, 6, 7);
int add=8;
int sub=9;
int valadd;
int valsub;
int count=000;
int press;
lcd.begin(16,2);
pinMode(add,INPUT);
pinMode(sub,INPUT);
valadd=digitalRead(add);
valsub=digitalRead(sub);
if(valadd==HIGH) {
delay(100);
press=count++;
delay(250);
if(valsub==HIGH) {
delay(100);
press=count--;
delay(250);
lcd.setCursor(0,0);
lcd.print("Button count");
lcd.setCursor(0,1);
lcd.print(press);
Counter.ino (725 Bytes)
try doing an lcd.clear(); right before you update the value
       lcd.setCursor(0,1);
       lcd.print("       ");  // overwrite old data with spaces
       lcd.setCursor(0,1);  // reset the cursor
       lcd.print(press);
A (faster) alternative to using clear().
The second digit is not being removed from the display when you print a single digit number
Another way to fix the problem is to always print a space after the value
lcd.print(press);
lcd.print(" "); //overwrite the previously written second (or third) digit if it is present
Thank you all for the help, it is greatly appreciated!
