I'm trying to write a program that starts an led sequence (using a 74hc595n shift register) as soon as the Arduino is powered on and during that led sequence if you push the button I want the led sequence to stop completely. Instead of stopping though, I get a strange outcome where one led will flash on the 2nd led (Binary 0100 0000)and then the 7th (Binary 0000 0010) back and forth for the entire time that you're pressing the button. Once the button is released the sequence goes back to normal. Any reason for this?
Here is a link to the video of my issue on Youtube:
Here is the code:
//Constant Global variables
const int dataPin = 5;
const int latchPin = 6;
const int clockPin = 7;
//NON-Constant Global variables
bool seq_running = true;
bool pwr_on;
//Single LED attached to pin 12.
int led = 12;
//Button Pin attached to pin 2.
int buttonPin = 2;
//Reads buttonPin state (either HIGH or LOW).
int buttonState;
int buttonPrev = 1;
//Use for delay
int d = 100;
//variables for making clear whether the button is pressed or not.
byte pressed = 0;
byte notpressed = 1;
//SETUP FUNCTION
pinMode(dataPin, OUTPUT);
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(led, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
//LOOP FUNCTION
buttonState = digitalRead(buttonPin);
byte x = B10000000;
byte shutoff = B00000000;
//Check if the Arduino is powered on and running.
if(Serial)
pwr_on = true;
if(pwr_on == true)
for(byte i = 0; i <= 6; i++)
x = x >> 1;
shiftDataOut(x);
delay(d);
changeBtnMsg();
if(buttonPrev == notpressed && buttonState == pressed)
if(seq_running == true)
x = shutoff;
shiftDataOut(x);
Serial.println("Sequence has been terminated.");
x = B00000001;
for(int i = 7; i >= 1; i--)
x = x << 1;
shiftDataOut(x);
delay(d);
changeBtnMsg();
x = shutoff;
shiftDataOut(x);
pwr_on = false;
//Function to easier handle shift register data shifting to output pins.
void shiftDataOut(byte data)
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, LSBFIRST, data);
digitalWrite(latchPin, HIGH);
//Custom function for changing what the serial monitor says about the button.
//Makes it easier to understand the button's logic.
void changeBtnMsg()
if(buttonState == pressed)
Serial.println("Button Pressed(HIGH)");
Serial.println("Button NOT Pressed(LOW)");
