Push Buttons - LEDs. On and stay on till other button is pressed....
I am trying to wrap my head around some code i have found. But this is a little beyond me. I need a code that has multible buttons and leds. each button has an led associated to it. Press button #1, led #1 lights up and stays lit till you hit another button. when hit the other another button, that buttons associated led lights up and stay lit till.......
i have been looking at this code, but i think its more of an on/off type, but close.
// One Button On/Off Toggle
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// Variables will change:
int ledState = LOW;         // the current state of the output pin
int buttonState = LOW;             // the current reading from the input pin
int lastButtonState = HIGH;   // the previous reading from the input pin
int reading;
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  reading = digitalRead(buttonPin);
   if (reading != lastButtonState) {
      lastDebounceTime = millis();
      lastButtonState = reading;
if ((millis() - lastDebounceTime) > debounceDelay) {
      if (buttonState != lastButtonState) {
         buttonState = lastButtonState;
         if (buttonState == HIGH) {
            ledState = !ledState;
            digitalWrite(ledPin, ledState);
At the end of this project, i should hope to have 6 buttons and 6 leds. I have already did the wiring schem. Just looking for a little(most likely alot) help on this on. Thank you
I think you might be better off reading and writing to ports,
See Port registers on the uno - Microcontrollers - Arduino Forum
Especially answer #20
Although as it has been suggested that you use pullups and the switches you press will pull the input down you
will need to bitwise XOR the input and then write the result out.
See & - Arduino Reference
What is this for?
Show us a schematic of your wiring.
