Put JSON to API Endpoint using WifiNina Library
I have an Uno Wifi v2 board and I'm using WiFiNINA to connect to an API on the Internet. I can perform GET requests to the API without any issues but when I attempt to perform PUT requests I get errors.
connected to server
HTTP/1.1 400 Bad Request
Server: awselb/2.0
Date: Sat, 29 Jul 2023 01:17:50 GMT
Content-Type: text/html
Content-Length: 122
Connection: close
Here is all of the code:
This example puts data to a secure API endpoint
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;            // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
char server[] = SERVER;
WiFiSSLClient client;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to wifi");
  printWiFiStatus();
  Serial.println("\nStarting connection to server...");
  if (client.connect(server, 443)) {
    Serial.println("connected to server");
    client.println("Content-Type: application/json");
    client.println("User-Agent: ArduinoWiFi/1.1");
    client.println("PUT / HTTP/1.1");
    client.println('{"id":"78918", "name":"Pizza", "price":"12.45"}');
    client.println("Connection: close");
    client.println();
  // if there are incoming bytes available
  // from the server, read them and print them:
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
    // do nothing forevermore:
    while (true);
void printWiFiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
I need Content-Type to change to application/json and I need the payload sent with the request. How can I do this with the WifiNina library?
How about you post all of your code here. How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
I've updated it to include all of my code. Thanks!
curl work with the API like so:
curl -d '{"id":"2", "name":"Test", "price":"2.45"}' -H "Content-Type: application/json" -X POST $API_URL
This solution: How to POST JSON data from NANO 33 IOT? - #9 by Klaus_K worked for me. It uses the HTTP library instead of WifiNina to send the data.
