Putting the Nano 33 BLE to sleep and waking it
I have a project where I would like to put the Arduino Nano 33 BLE to sleep and then wake it up when needed.. The first couple of lines in the loop section are where I would like to wake up the BLE and put it to sleep. I have found a few threads on this but nothing I can comprehend. Any help would be apriciated.
// Note this program uses a watchdog timmer.
// It is required to reset the Arduino by two presses of the reset button and setting available com ports prior to upload.
// After upload the com port needs to be reset.
// Define Global Constants /////////////////////////////////////////////////////////////////
// constants thet are desirable to adjust during debugging.
const bool SerialStatus = true;               // Set to true to hold serial printing until the serial printer is started. Set to false to release hold for stand alone use
const bool WDTStatus = false;                 // Set to true to activate the Watch Dog Timmer, Set to false to deactivate for debugging
const unsigned long WDT = 30;                 // Watch Dog Timer max time seconds This must be greater than the time requird to complete a cycle
// Constant for voltage sensing
const unsigned long Resistor1 = 33000L;       // Voltage divider resistor #1
const unsigned long Resistor2 = 3300L;        // Voltage divider resistor #2
const float BoardV = 3.3;                     // Board operating voltage
const float VMult = BoardV*((Resistor1 + Resistor2)/Resistor2)/1023L;        // Voltage multiplier to get voltage from analogread pin "VsnPin"
const float EngineOnVoltage = 13.2;           // Voltage at which the engine is considered to be running
const float KeyOnVoltage = 12;                // Voltage at which the key is considered to be on
const long PostRunInterval = 30;              // Time the fan will run after engine shut down
// Constanst for program control
const int frequency = 10.0;                   // Set fan frequency
const int NumberOfSamples = 20;               // Sent number of data samples for averaging.
const int BlinkTimeOnTest  = 2000;            // Blink time on period for initial circuit test
const int BlinkTimeOn      = 500;             // Blink time on period
const int BlinkTimeOff     = 500;             // Blink time off period
// Constants for Arduino board configuration
const int VsnPin  = A0;                       // Circuite 15 Voltage level sensing pin
const int RadPin  = A1;                       // Radiator Input Thermister
const int CndPin  = A2;                       // Condenser Input Thermister
const int AuxPin  = A3;                       // Auxilary Input Not used at this time
const int FanPin  = D9;                       // Set Fan pin
const int LED1Pin = D4;                       // Set Cooling Fan LED
const int LED2Pin = D3;                       // Set Condenser Fan LED
const int LED3Pin = D2;                       // Set Aux Fan FED
// 10 bit temperature equivolents for radiator sensor Delphi 12146312
const int Rad0   = 8;      // - 20°C equivolent Sensor assumed open.
const int Rad20  = 444;    //85C
const int Rad30  = 466;    //88C
const int Rad40  = 489;    //91C
const int Rad50  = 512;    //94C
const int Rad60  = 536;    //97C
const int Rad70  = 560;    //100C
const int Rad80  = 584;    //103C
const int Rad90  = 608;    //106C
const int Rad100 = 668;    //115C This is an emergency mode either coolant is too hot or senser is shorted. Set duty cycle to 0 to activate emergency mode
// 10 bit temperature equivolents for condenser sensor Litlefuse USP7766
const int Cnd0   = 19;     //-30C Sensor Test point
const int Cnd20  = 391;    //40C
const int Cnd30  = 440;    //45C
const int Cnd40  = 489;    //50C
const int Cnd50  = 537;    //55C
const int Cnd60  = 583;    //60C
const int Cnd70  = 627;    //65C
const int Cnd80  = 668;    //70C
const int Cnd90  = 706;    //75C
const int Cnd100 = 849;    //100C Sensor Test Point
// 10 bit temperature equivolents for temp sensor Delphi 25036751
const int Aux0   = 8;      //-20C Sensor Test Point
const int Aux20  = 452;    //85C
const int Aux30  = 474;    //88C
const int Aux40  = 496;    //91C
const int Aux50  = 519;    //94C
const int Aux60  = 543;    //97C
const int Aux70  = 567;    //100C
const int Aux80  = 591;    //103C
const int Aux90  = 614;    //106C
const int Aux100 = 733;    //125C Sensor Test Point
const int Rad0   = 1015;   // - 20°C equivolent Sensor assumed open.
const int Rad20  = 579;    //85C
const int Rad30  = 557;    //88C
const int Rad40  = 534;    //91C
const int Rad50  = 511;    //94C
const int Rad60  = 487;    //97C
const int Rad70  = 463;    //100C
const int Rad80  = 439;    //103C
const int Rad90  = 415;    //106C
const int Rad100 = 355;    //115C This is an emergency mode either coolant is too hot or senser is shorted. Set duty cycle to 0 to activate emergency mode
const int Cnd0   = 1004;   //-30C Sensor Test point
const int Cnd20  = 632;    //40C
const int Cnd30  = 583;    //45C
const int Cnd40  = 534;    //50C
const int Cnd50  = 486;    //55C
const int Cnd60  = 440;    //60C
const int Cnd70  = 396;    //65C
const int Cnd80  = 355;    //70C
const int Cnd90  = 317;    //75C
const int Cnd100 = 174;    //100C Sensor Test Point
const int Aux0   = 1015;      //-20C Sensor Test Point
const int Aux20  = 571;    //85C
const int Aux30  = 549;    //88C
const int Aux40  = 527;    //91C
const int Aux50  = 504;    //94C
const int Aux60  = 480;    //97C
const int Aux70  = 456;    //100C
const int Aux80  = 432;    //103C
const int Aux90  = 409;    //106C
const int Aux100 = 290;    //125C Sensor Test Point
#define _PWM_LOGLEVEL_                2
#define USING_MICROS_RESOLUTION       true    //false
#define HW_TIMER_INTERVAL_US          20L
// #define PRINT_INTERVAL                15000L      // Interval of time ms for printing to the serial moniter
#define UPDATE_CHECK_INTERVAL_MS      15000L      // Interval of time for fan to run befor checking sensors and re adjusting fan speed
// Initialize Global Variables ///////////////////////////////////////////////////////////////////
bool EngineRunningStatus = false;          // Initialize engine running as off
bool Keyon = false;                        // Initialize key position as off
bool ShutDown = false;                     // Initilize shutdown event an false
int RadVals [NumberOfSamples + 1];
int CndVals [NumberOfSamples + 1];
int AuxVals [NumberOfSamples + 1];
int RadValAvg = 0;
int CndValAvg = 0;
int AuxValAvg = 0;
int RadSpeed = 10;
int CndSpeed = 10;
int AuxSpeed = 10;
int RadTemp;
int CndTemp;
int AuxTemp;
int DutyCycle = 10;            // Set fan to 10% PWM = Fan off
int FanSpeed = 0;              // Fan speed is 0 with 10% PWM, Fan speed = 100% with 0% PWM
uint32_t startMicros = 0;
// You can assign pins here. Be careful to select good pin to use or crash
uint32_t PWM_Pin    = FanPin;
// Channel number used to identify associated channel
int channelNum;
#if !( ARDUINO_ARCH_NRF52840 && TARGET_NAME == ARDUINO_NANO33BLE )
  #error This code is designed to run on nRF52-based Nano-33-BLE boards using mbed-RTOS platform! Please check your Tools->Board setting.
#endif
// To be included only in main(), .ino with setup() to avoid `Multiple Definitions` Linker Error
#include "nRF52_MBED_Slow_PWM.h"     // https://github.com/khoih-prog/nRF52_MBED_Slow_PWM
#include <ArduinoBLE.h>
// For mbed nRF52, you can only select NRF52 Hardware Timer NRF_TIMER_3-NRF_TIMER_4 (3 to 4)
// If you select the already-used NRF_TIMER_0-2, it'll be auto modified to use NRF_TIMER_3
// Init NRF52 timer NRF_TIMER3
NRF52_MBED_Timer ITimer(NRF_TIMER_3);
// Init nRF52_Slow_PWM, each can service 16 different ISR-based PWM channels
NRF52_MBED_Slow_PWM ISR_PWM;
///////////////////////////////////////////////////////////////////////// Define the Temperature Service for BLE
BLEService TempService("53436b3f-5f91-474b-963e-8b09b170c670");        //*** BLEService Class Any Hex Name 128-bit UUID in String format *********************************************************
// Define Temperature and Fan Speed Characteristics
BLEUnsignedIntCharacteristic RadLevelChar("694d181e-4421-47f3-9653-c4d6bb295a07",  // standard 128-bit characteristic UUID *******************************
    BLERead | BLENotify); // remote clients will be able to get notifications if this characteristic changes
BLEUnsignedIntCharacteristic CndLevelChar("0407dd37-ae29-4ec7-ab40-a83898d610df",  // standard 128-bit characteristic UUID *******************************
BLEUnsignedIntCharacteristic AuxLevelChar("ad43db8f-e3e6-4025-b745-43f2100f27e1",  // standard 128-bit characteristic UUID *******************************
BLEUnsignedIntCharacteristic FanSpeedChar("8ed03f79-29c0-46d5-a2ca-bfddd629347e",  // standard 128-bit characteristic UUID *******************************
void TimerHandler()
  ISR_PWM.run();
void PrintData(const int& index = 0)      // Subroutine to print each pin value to the serial monitor
                                          // Note this subroutine must be declared befor it is called?
  PWM_LOGINFO3("Rad(", index, ") input = ", RadVals[index]);
  PWM_LOGINFO3("Cnd(", index, ") input = ", CndVals[index]);
  PWM_LOGINFO3("Aux(", index, ") input = ", AuxVals[index]);
void printAvg()                           // Subroutine to print the average values to the serial monitor
                                          // Not this subroutine must be declared befor it is called?
  PWM_LOGWARN1("RadAvg = ", RadValAvg);
  PWM_LOGWARN1("CndAvg = ", CndValAvg);
  PWM_LOGWARN1("AuxAvg = ", AuxValAvg);
  pinMode(VsnPin, INPUT);
  pinMode(RadPin, INPUT);
  pinMode(CndPin, INPUT);
  pinMode(AuxPin, INPUT);
  pinMode(LED1Pin, OUTPUT);
  pinMode(LED2Pin, OUTPUT);
  pinMode(LED3Pin, OUTPUT);
  pinMode(FanPin, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  if (SerialStatus)               // Set the SerialStatus bool variable in the main body as required for stand alone use or debugging
    while(!Serial);
  //Configure WDT.
  if (WDTStatus)                  // Set the WDTStatus booleen variable in the main body as required to turn on or off the WDT
    NRF_WDT->CONFIG         = 0x01;         // Configure WDT to run when CPU is asleep
    NRF_WDT->CRV            = WDT*32769;    // CRV = WDT *(32768 + 1)
    NRF_WDT->RREN           = 0x01;         // Enable the RR[0] reload register
    NRF_WDT->TASKS_START    = 1;            // Start WDT
    NRF_WDT->RR[0] = WDT_RR_RR_Reload;      // Reset WDT
    Serial.println("Watchdog iniialized and Set *************************************************************");
  Serial.print(F("\nStarting Car_Fan_Control using ")); Serial.println(BOARD_NAME);
  Serial.println(NRF52_MBED_SLOW_PWM_VERSION);
  Serial.print("Resistor 1 = "); Serial.println(Resistor1);
  Serial.print("Resistor 2 = "); Serial.println(Resistor2);
  Serial.print("BoardV = "); Serial.println(BoardV);
  Serial.print("VMult = "); Serial.println(VMult, 6);
  delay(200);
  digitalWrite(LED_BUILTIN, HIGH);
  // Interval in microsecs
  if (ITimer.attachInterruptInterval(HW_TIMER_INTERVAL_US, TimerHandler))
    startMicros = micros();
    Serial.print(F("Starting ITimer OK, micros() = ")); Serial.println(startMicros); Serial.println();
  else Serial.println(F("Can't set ITimer. Select another freq. or timer")); Serial.println();
  channelNum = ISR_PWM.setPWM(PWM_Pin, frequency, DutyCycle);  // During setup DutyCycle will be set to initialized value of 10 = off.
  ReadAveragSensorsData();          // Read all the sensors and find the averages
  // CalcDutyCycle();               // Call the CalcDutyCycle routine moved to loop
  StartUpBlink();                   // Call the blink sensor StartUpBlink subroutine to test all sensors
  SetUpBLE();                       // Call the SetUpBLE routine
  Serial.println("Setup Complete *************************************************************"); Serial.println();
  if (VMult*analogRead(VsnPin) > EngineOnVoltage)
      // Wake Nano 33 BLE
  if (RunFan() == false)
      //Put Nano 33 BLE to sleep
  if (RunFan() == true)                          // Run the fan if apropriate
    // wait for a Bluetooth® Low Energy central
    BLEDevice central = BLE.central();
    // if a central is connected to the peripheral:
    static unsigned long update_timeout = 0;
    static bool LED_status = HIGH;
    // Take reading every update_timeout ms.
    if ( (millis() > update_timeout) && (millis() > UPDATE_CHECK_INTERVAL_MS) )
      LED_status = !LED_status;
      digitalWrite(LED_BUILTIN, LED_status);
      UpdateTemperatures();
      CalcDutyCycle();                // Call read sensors subroutine to calculate fan speed and print values to serial moniter
      CalculateTemperatures();        // Calculate the thermister temperatures
      BlinkSpeed();                   // Call blink test to blink out speeds
      Serial.print("millis() = "); Serial.println(millis());
      if (WDTStatus) Serial.println("Watchdog Reset *************************************************************");
      update_timeout = millis() + UPDATE_CHECK_INTERVAL_MS;
      if (central)
        Serial.print("Connected to central: ");
        // print the central's BT address:
        Serial.println(central.address());
        // turn on the LED to indicate the connection:
       // when the central disconnects, turn off the LED:
       digitalWrite(LED_BUILTIN, LOW);
       Serial.print("Disconnected from central: "); Serial.println(central.address());
       PrintData(); // Print every update_timeout ms.
void ReadAveragSensorsData() // Subroutine to read each pin and sum them
  int index = 0;
  RadValAvg = 0;
  CndValAvg = 0;
  AuxValAvg = 0;
  do
    // Read al data points
  RadVals[index]  = analogRead(RadPin);
  CndVals[index]  = analogRead(CndPin);
  AuxVals[index]  = analogRead(AuxPin);
  // sum all data points
  RadValAvg += RadVals[index];
  CndValAvg += CndVals[index];
  AuxValAvg += AuxVals[index];
    PrintData(index);               //Call the printData subroutine to print each reading to the serial monitor.
    index = index + 1;
  } while (index < NumberOfSamples);
  // Find Average of all data points
  RadValAvg  = RadValAvg  / NumberOfSamples;
  CndValAvg  = CndValAvg  / NumberOfSamples;
  AuxValAvg  = AuxValAvg  / NumberOfSamples;
  printAvg();                       //Call the printAvg function to print the average data to the serial monitor.
bool RunFan()
  float Voltage;                               // Voltage read on circuite 15 (Key Voltage)
  static bool Running;                                // Engine runing status
  static bool KeyOffEvent;                            // Used to determine whether or not the engine was tuned off
  static bool RecentRunning;                          // Used to determin if the engine was running within a prescribed time
  static unsigned long KeyOffMillis;                  // Time the key was sensed as being tuned off
  unsigned long CurrentKeyMillis = millis();   // Current time
  int Status;
  Voltage = VMult*analogRead(VsnPin);         // Get the circuit 15 voltage
  if (Voltage <  EngineOnVoltage && Running == true)
    KeyOffEvent = true;
    KeyOffMillis = millis();
    KeyOffEvent = false;
  if (Voltage >= EngineOnVoltage)
    Running = true;
    Running = false;
  // Ckeck to see if key was tuned off recently
  if (CurrentKeyMillis - KeyOffMillis < PostRunInterval*1000)
    RecentRunning = true;
    RecentRunning = false;
Serial.print("KeyOffMillis      = "); Serial.print(KeyOffMillis);Serial.println();
Serial.print("Voltage           = "); Serial.print(Voltage);Serial.println();
Serial.print("Running           = "); Serial.print(Running);Serial.println();
Serial.print("KeyOffEvent       = "); Serial.print(KeyOffEvent);Serial.println();
Serial.print("RecentRunning     = "); Serial.print(RecentRunning);Serial.println();
Serial.print("CurrentKeyMillis  = "); Serial.print(CurrentKeyMillis);Serial.println();
Serial.print("CurrentKeyMillis - KeyOffMillis  = "); Serial.print(CurrentKeyMillis - KeyOffMillis);Serial.println();
Serial.print("PostRunInterval   = "); Serial.print(PostRunInterval*1000);Serial.println();
  if (Running == true || RecentRunning == true)
    Status = 1;
    Status = 0;
Serial.print("Status           = "); Serial.println(Status); Serial.println();
    return true;
    return false;
void CalcDutyCycle()                  // Subroutine to do 1 cycle of reading the temperature data
  // Find the speed levels required by each sensor Not only rad temperature can initiate emergency mode.
  if (RadValAvg < Rad0) RadSpeed = 0;           // Open sensor assumed fan will run in emergency mode at 100%
  if (RadValAvg < Rad20 and RadValAvg >= Rad0) RadSpeed = 10;   // 10% duty cycle = fan off
  if (RadValAvg < Rad30 and RadValAvg >= Rad20) RadSpeed = 20;
  if (RadValAvg < Rad40 and RadValAvg >= Rad30) RadSpeed = 30;
  if (RadValAvg < Rad50 and RadValAvg >= Rad40) RadSpeed = 40;
  if (RadValAvg < Rad60 and RadValAvg >= Rad50) RadSpeed = 50;
  if (RadValAvg < Rad70 and RadValAvg >= Rad60) RadSpeed = 60;
  if (RadValAvg < Rad80 and RadValAvg >= Rad70) RadSpeed = 70;
  if (RadValAvg < Rad90 and RadValAvg >= Rad80) RadSpeed = 80;
  if (RadValAvg < Rad100 and RadValAvg >= Rad90) RadSpeed = 90;
  if (RadValAvg >= Rad100) RadSpeed = 100;        // Set PWM duty cycle to 0 for emergency mode
  if (CndValAvg < Cnd20) CndSpeed = 10;   // 10% duty cycle = fan off
  if (CndValAvg < Cnd30 and CndValAvg >= Cnd20) CndSpeed = 20;
  if (CndValAvg < Cnd40 and CndValAvg >= Cnd30) CndSpeed = 30;
  if (CndValAvg < Cnd50 and CndValAvg >= Cnd40) CndSpeed = 40;
  if (CndValAvg < Cnd60 and CndValAvg >= Cnd50) CndSpeed = 50;
  if (CndValAvg >= Cnd60) CndSpeed = 60;                // Condensor is limited to 60%
  if (AuxValAvg < Aux20) AuxSpeed = 10;   // 10% duty cycle = fan off
  if (AuxValAvg < Aux30 and AuxValAvg >= Aux20) AuxSpeed = 20;
  if (AuxValAvg < Aux40 and AuxValAvg >= Aux30) AuxSpeed = 30;
  if (AuxValAvg < Aux50 and AuxValAvg >= Aux40) AuxSpeed = 40;
  if (AuxValAvg < Aux60 and AuxValAvg >= Aux50) AuxSpeed = 50;
  if (AuxValAvg < Aux70 and AuxValAvg >= Aux60) AuxSpeed = 60;
  if (AuxValAvg < Aux80 and AuxValAvg >= Aux70) AuxSpeed = 70;
  if (AuxValAvg < Aux90 and AuxValAvg >= Aux80) AuxSpeed = 80;
  if (AuxValAvg >= Aux90) AuxSpeed = 90;
  if (RadValAvg > Rad0) RadSpeed = 0;           // Open sensor assumed fan will run in emergency mode at 100%
  if (RadValAvg > Rad20 and RadValAvg <= Rad0) RadSpeed = 10;   // 10% duty cycle = fan off
  if (RadValAvg > Rad30 and RadValAvg <= Rad20) RadSpeed = 20;
  if (RadValAvg > Rad40 and RadValAvg <= Rad30) RadSpeed = 30;
  if (RadValAvg > Rad50 and RadValAvg <= Rad40) RadSpeed = 40;
  if (RadValAvg > Rad60 and RadValAvg <= Rad50) RadSpeed = 50;
  if (RadValAvg > Rad70 and RadValAvg <= Rad60) RadSpeed = 60;
  if (RadValAvg > Rad80 and RadValAvg <= Rad70) RadSpeed = 70;
  if (RadValAvg > Rad90 and RadValAvg <= Rad80) RadSpeed = 80;
  if (RadValAvg > Rad100 and RadValAvg <= Rad90) RadSpeed = 90;
  if (RadValAvg <= Rad100) RadSpeed = 100;        // Set PWM duty cycle to 0 for emergency mode
  if (CndValAvg > Cnd20) CndSpeed = 10;   // 10% duty cycle = fan off
  if (CndValAvg > Cnd30 and CndValAvg <= Cnd20) CndSpeed = 20;
  if (CndValAvg > Cnd40 and CndValAvg <= Cnd30) CndSpeed = 30;
  if (CndValAvg > Cnd50 and CndValAvg <= Cnd40) CndSpeed = 40;
  if (CndValAvg > Cnd60 and CndValAvg <= Cnd50) CndSpeed = 50;
  if (CndValAvg <= Cnd60) CndSpeed = 60;                // Condensor is limited to 60%
  if (AuxValAvg > Aux20) AuxSpeed = 10;   // 10% duty cycle = fan off
  if (AuxValAvg > Aux30 and AuxValAvg <= Aux20) AuxSpeed = 20;
  if (AuxValAvg > Aux40 and AuxValAvg <= Aux30) AuxSpeed = 30;
  if (AuxValAvg > Aux50 and AuxValAvg <= Aux40) AuxSpeed = 40;
  if (AuxValAvg > Aux60 and AuxValAvg <= Aux50) AuxSpeed = 50;
  if (AuxValAvg > Aux70 and AuxValAvg <= Aux60) AuxSpeed = 60;
  if (AuxValAvg > Aux80 and AuxValAvg <= Aux70) AuxSpeed = 70;
  if (AuxValAvg > Aux90 and AuxValAvg <= Aux80) AuxSpeed = 80;
  if (AuxValAvg <= Aux90) AuxSpeed = 90;
  // find the sensor with the highest speed requirment or set emergency mode
  if (RadSpeed == 100|| RadSpeed == 0){
    DutyCycle = 0;                         // Emergency mode rad too hot or shorted sensor = 100, sensor open = 0
  else {
    DutyCycle = max(RadSpeed, CndSpeed); // find the highest
    DutyCycle = max(DutyCycle, AuxSpeed);  // This is the duty Cycle
  FanSpeed = DutyCycle;
  if (DutyCycle == 0){
    FanSpeed = 100;
  PWM_LOGWARN1("Fan Speed  = ", FanSpeed);
  //write the PWM value to the pwm output pin
  PWM_LOGWARN5("Freq = ", frequency, ", DutyCycle % = ", DutyCycle, ", Pin = ", FanPin);
  if (!ISR_PWM.modifyPWMChannel(channelNum, PWM_Pin, frequency, DutyCycle))
    Serial.print(F("modifyPWMChannel error"));
void StartUpBlink()                          // Blink LEDs at startup to test sensors are in range
  digitalWrite(LED1Pin, HIGH);  // turn the LED on
  digitalWrite(LED2Pin, HIGH);  // turn the LED on
  digitalWrite(LED3Pin, HIGH);  // turn the LED on
  delay(BlinkTimeOnTest);       // Time to leave LEDs on
  digitalWrite(LED1Pin, LOW);   // turn the LED off
  digitalWrite(LED2Pin, LOW);   // turn the LED off
  digitalWrite(LED3Pin, LOW);   // turn the LED off
  Serial.print("StartUpBlink Complete");Serial.println();Serial.println();
void BlinkSpeed()                               // Blink LEDs to indicate speed called by each sensor
  int CountRadOn  = 0;    // Counter for number of radiator blinks on
  int CountCndOn  = 0;    // Counter for number of condenser blinks on
  int CountAuxOn  = 0;    // Counter for number of Aux blinks on
  int CountRadOff = 0;    // Counter for number of radiator blinks off
  int CountCndOff = 0;    // Counter for number of condenser blinks off
  int CountAuxOff = 0;    // Counter for number of Aux blinks off
  int RadBlinks   = 0;    // Initialise number of blinks based on radiator temp
  int CndBlinks   = 0;    // Initialise number of blinks based on Condenser temp
  int AuxBlinks   = 0;    // Initialise number of blinks based on Aux temp
  int MaxBlinks   = 0;    // Maximum number of blinks for all channels
  int index = 0;
  RadBlinks = RadSpeed/10;      // Number of Blinks Based on Rad Temp
  CndBlinks = CndSpeed/10;      // Number of Blinks Based on Cnd Temp
  AuxBlinks = AuxSpeed/10;      // Number of Blinks Based on Aux Temp
  MaxBlinks = max(RadBlinks, CndBlinks);
  MaxBlinks = max(MaxBlinks, AuxBlinks);    // Find the total number of blinks required
  do {                                      // Do the blink loop until the max number of blinks has occured.
      CountRadOn = CountRadOn + 1;
      CountCndOn = CountCndOn + 1;
      CountAuxOn = CountAuxOn + 1;
      if (CountRadOn <= RadBlinks) {
      if (CountCndOn <= CndBlinks) {
      if (CountAuxOn <= AuxBlinks) {
      delay(BlinkTimeOn);           // Time to leave LEDs on
      delay(BlinkTimeOff);          // Time to leave LEDs on
    index = index + 1;
  } while (index < MaxBlinks);
  void SetUpBLE() {
  // begin initialization
  if (!BLE.begin()) {
    Serial.println("starting BLE failed!");
    while (1);
  /* Set a local name for the Bluetooth® Low Energy device
     This name will appear in advertising packets
     and can be used by remote devices to identify this Bluetooth® Low Energy device
     The name can be changed but maybe be truncated based on space left in advertisement packet
    BLE.setLocalName("Testing 123"); //******************************************************************************
    BLE.setAdvertisedService(TempService); // add the service UUID
    TempService.addCharacteristic(RadLevelChar); // add the radiator level characteristic
    TempService.addCharacteristic(CndLevelChar); // add the condenser level characteristic
    TempService.addCharacteristic(AuxLevelChar); // add the aux level characteristic
    TempService.addCharacteristic(FanSpeedChar); // add the fan Speed characteristic
    BLE.addService(TempService);  // Add the Temperature service
    RadLevelChar.writeValue(0);   // set initial value for this characteristic
    CndLevelChar.writeValue(0);   // set initial value for this characteristic
    AuxLevelChar.writeValue(0);   // set initial value for this characteristic
    FanSpeedChar.writeValue(0);   // set initial value for this characteristic
  // Start advertising Bluetooth® Low Energy.  It will start continuously transmitting Bluetooth® Low Energy
  // advertising packets and will be visible to remote Bluetooth® Low Energy central devices
  // until it receives a new connection
  BLE.advertise();  // start advertising
  Serial.println("Bluetooth® device active, waiting for connections...");Serial.println();
  void UpdateTemperatures()
  // Update and Print the calculated temperatures used for the BLE Characteristics
  RadLevelChar.writeValue(RadTemp);                   // update the Radiator level characteristics
  CndLevelChar.writeValue(CndTemp);                   // update the Condenser level characteristics
  AuxLevelChar.writeValue(AuxTemp);                   // update the Aux level characteristics
  FanSpeedChar.writeValue(FanSpeed);                  // update the Fan Speed characteristics
  Serial.print("Rad Temp is now:  "); Serial.println(RadTemp);
  Serial.print("Cnd Temp is now:  "); Serial.println(CndTemp);
  Serial.print("Aux Temp is now:  "); Serial.println(AuxTemp);
  Serial.print("Fan Speed is now: "); Serial.println(FanSpeed);Serial.println();
  void CalculateTemperatures()
  //// Defining 6th order polynomial coefficients
  double RadCoeff0 = -3.191109E+01;
  double RadCoeff1 =  1.333142E+00;
  double RadCoeff2 = -9.388659E-03;
  double RadCoeff3 =  3.502677E-05;
  double RadCoeff4 = -6.643350E-08;
  double RadCoeff5 =  6.164271E-11;
  double RadCoeff6 = -2.214795E-14;
  double CndCoeff0 = -4.330212E+01;
  double CndCoeff1 =  7.697340E-01;
  double CndCoeff2 = -4.329864E-03;
  double CndCoeff3 =  1.423127E-05;
  double CndCoeff4 = -2.456664E-08;
  double CndCoeff5 =  2.111208E-11;
  double CndCoeff6 = -7.068046E-15;
  double AuxCoeff0 = -43.43635166;
  double AuxCoeff1 =  3.117548E+00;
  double AuxCoeff2 = -2.416554E-02;
  double AuxCoeff3 =  8.431310E-05;
  double AuxCoeff4 = -1.486206E-07;
  double AuxCoeff5 =  1.304135E-10;
  double AuxCoeff6 = -4.532547E-14;
  double RadCoeff0 =   1.660314E+03;
  double RadCoeff1 =  -1.669192E+01;
  double RadCoeff2 =   7.538496E-02;
  double RadCoeff3 =  -1.809468E-04;
  double RadCoeff4 =   2.411013E-07;
  double RadCoeff5 =  -1.684504E-10;
  double RadCoeff6 =   4.789740E-14;
  double CndCoeff0 =   1.656447E+02;
  double CndCoeff1 =  -5.855249E-01;
  double CndCoeff2 =   1.648293E-03;
  double CndCoeff3 =  -3.088415E-06;
  double CndCoeff4 =   3.244812E-09;
  double CndCoeff5 =  -1.670822E-12;
  double CndCoeff6 =   2.576671E-16;
  double AuxCoeff0 =   4.949081E+02;
  double AuxCoeff1 =  -3.724091E+00;
  double AuxCoeff2 =   1.595315E-02;
  double AuxCoeff3 =  -3.767238E-05;
  double AuxCoeff4 =   4.990923E-08;
  double AuxCoeff5 =  -3.498639E-11;
  double AuxCoeff6 =   1.000633E-14;
  //Calculate temperatures
  RadTemp = RadCoeff0 + RadCoeff1*RadValAvg + RadCoeff2*RadValAvg*RadValAvg + RadCoeff3*RadValAvg*RadValAvg*RadValAvg + RadCoeff4*RadValAvg*RadValAvg*RadValAvg*RadValAvg + RadCoeff5*RadValAvg*RadValAvg*RadValAvg*RadValAvg*RadValAvg + RadCoeff6*RadValAvg*RadValAvg*RadValAvg*RadValAvg*RadValAvg*RadValAvg;
  CndTemp = CndCoeff0 + CndCoeff1*CndValAvg + CndCoeff2*CndValAvg*CndValAvg + CndCoeff3*CndValAvg*CndValAvg*CndValAvg + CndCoeff4*CndValAvg*CndValAvg*CndValAvg*CndValAvg + CndCoeff5*CndValAvg*CndValAvg*CndValAvg*CndValAvg*CndValAvg + CndCoeff6*CndValAvg*CndValAvg*CndValAvg*CndValAvg*CndValAvg*CndValAvg;
  AuxTemp = AuxCoeff0 + AuxCoeff1*AuxValAvg + AuxCoeff2*AuxValAvg*AuxValAvg + AuxCoeff3*AuxValAvg*AuxValAvg*AuxValAvg + AuxCoeff4*AuxValAvg*AuxValAvg*AuxValAvg*AuxValAvg + AuxCoeff5*AuxValAvg*AuxValAvg*AuxValAvg*AuxValAvg*AuxValAvg + AuxCoeff6*AuxValAvg*AuxValAvg*AuxValAvg*AuxValAvg*AuxValAvg*AuxValAvg;
Hey there!
It sounds like you’re trying to manage power consumption on the Arduino Nano 33 BLE by utilizing sleep modes. The Nano 33 BLE has an excellent set of low-power features, including deep sleep, which should help you minimize power usage when not in use.
To wake up the BLE, you’ll likely want to utilize an external interrupt (like a button press or some other sensor trigger) to wake up the chip. Here's a simplified way to approach it in your code:
// Define the sleep pin (e.g., a button to wake the BLE up)
const int wakeUpPin = 2;
  // Start serial communication for debugging
  // Configure the wakeUpPin as input
  pinMode(wakeUpPin, INPUT_PULLUP);
  // Initialize the BLE
  if (!BLE.begin()) {
    Serial.println("Failed to initialize BLE!");
    while (1);
  // Optional: Perform any necessary setup or configuration for BLE here
  // Check for any wake-up event (like a button press)
  if (digitalRead(wakeUpPin) == LOW) {
    // Wake the BLE up and perform your task
    Serial.println("BLE is awake!");
    // Add your code for BLE communication or tasks
    // Example of putting BLE to sleep after the task is done:
    BLE.sleep();
    Serial.println("BLE is going to sleep...");
  // Implement sleep mode here to save power when idle
  delay(100);
In the above example:
  • BLE.sleep() puts the BLE in a low-power state.
  • You can wake it up using a physical event (like a button press, connected to wakeUpPin).
This is just a basic example, and the specifics will depend on your project's needs, such as what triggers the wake-up and what actions you need to take during the awake phase.
If you're interested in more advanced BLE features or managing low-power modes more efficiently, our team at teo specializes in [embedded systems](< a href="https://teo.dk/"extended team) and microcontroller power management. Feel free to reach out if you'd like to discuss further! :blush:
Good luck with your project!
Let me know if you need any further changes or adjustments!
Thanks teo. I already am down to 1.3ma just by turning everything off, which for an automotive car battery should easily not put a dent in winter storage of the vehicle. But I may try this just for educational purposes.
Thanks
John
