system
1
I'm trying to control a toy car that uses dc motors using a L293d (as in http://www.instructables.com/id/Control-your-motors-with-L293D-and-Arduino/step3/Arduino-code/ ).
However when I try switching to PWM, the motors don't move at all and I get this odd humming noise coming out of my arduino.
What could be the problem? (And am I going to break my arduino??)
Not good.
It sounds like you have wired it up wrong. Are you suer that you have ground common between your arduino and battery?
system
3
Yeah I'm pretty sure I've got it wired up correctly. It works using normal digitalWrite() after all.
Interestingly enough, some of the pins have different frequency hums.
EDIT: It was do to the duty cycle being too low. Whoops.
Nothing to see here....
