I'm building a LED workspace light spotlight which consists of ~60 LEDs which are arranged in parallel Groups of three serial LEDs (and a resistor per group of course). I'm using a supply voltage of 12V and those LEDs will draw a current of approximately 500mA.
I'd like to be able to dim the LEDs using a PWM controller, but I don't want to use a microcontroller (i.e. Arduino) but a dedicated PWM IC instead. I've been googling for some time now and so far I have found the TL494 IC which provides about 400mA max but it comes in a DIP-16 package and has a lot of options which I do not need, so it's a little oversized.
Essentially I'm looking for a PWM IC (DIP-8 preferred) with an adjustable duty cycle, which can be supplied by and can supply (as U_OUT) 12V. Does anyone know of an IC capable of this (and maybe has a schematic for wiring it)?
I found a schematic of that too, but I'd like to use as few parts as possible and therefore thought about an IC designed for only that purpose. I guess if there's no other solution I'll go for the 555, but still, maybe someone knows an IC that gets it done in one chip.
I found this circuit documented all over the place, very nice general purpose PWM dimmer, simple and inexpensive. I'm using one for an LED light strip, works like a charm.
Is 8 parts (excluding connectors) few enough?
1 555 IC
2 capacitors: .1uF and 1uF
2 1N4148 diodes (could use others)
1 100K potentiometer
1 resistor (4.7K for no good reason)
1 MOSFET (I used an STP16NF06, overkill)
I believe it is possible to program the ATTiny using an ICSP-Header and the Arduino IDE, with some additions to boards.txt so the ATTiny shows up as a part.
Probably have to download some cores from avr-developers.com, or you can search for Teensyduino & see how that is loaded, I think that uses ATTiny also.
The input and output on the 555 board are for 12V input power and output PWMed 12V power. I picked screw terminals for flexibility.
The ATtiny solution is cool, I new to start using those for small projects! Note that you'll need to get it 2.7-5.5V from your 12V source, so an LDO regulator and a cap or two in addition.
So the input header is essentially the VCC, correct?
I guess for thee ATTiny solution I need a MOSFET as well, I doubt that the ATTiny can source 500mA.
I'll be ordering both parts and look into it, maybe borrow an oscilloscope from the university where I study to check the PWM capabilities of the 555-circuit. But while digging some more I found the UC 3842 IC (datasheets UC3842 Datasheet pdf - CURRENTMODE PWM STEUERPULT - ST Microelectronics ). I don't know whether it can be used to PWM some LEDs because there is no similar example in the datasheet but it's description says it's a "Current Mode PWM Controller" so I guess this could be used for PWMing the LEDs as well, right?
Depending on who you get it from, the UC3842 will have a fixed switching frequency of 50 KHz, 400KHz, or 500 KHz.
Your current drive transistor will need to match up with that.
Um... both headers are polarized, + and - leads on both. Check out the schematic
Really, the 555 is just the timer outputting a PWM signal, with the MOSFET doing the power switching. The same is the case with the UTtiny approach-- it can output a PWM signal and you can use that however you like. I use my 555 board with an LED strip that draws ~400mA at 12V, but it could handle much more than that.
