I am trying to change the PWM frequency of 328PB version from default 487 hz on pins 2, 3 to about 1 kHz.
I could have sucess on pin 3 by adding this in the setup:
TCCR2B = TCCR2B & 0b11111000 | 0x03; // 970 Hz // pino 3 a 975 hz
But no on the pin 2 that is connected to Timer 3. Also no success on pins 9 and 10 (Timer 1).
Nano 328PB have different timers.
Any help ?
b707
May 27, 2024, 6:42am
3
Did you try to change the settings of Timer1and Timer3, as you did it for Timer2? Please show the code.
This should set Timer 3 to pahse correct PWM mode with 977Hz PWM frequency and still having the two output compare channels OCR3A and OCR3B available.
* URL: https://dbuezas.github.io/arduino-web-timers/#mcu=ATMEGA328PB&timer=3&CompareOutputModeA=clear-up%2C+set-down&CompareOutputModeB=clear-up%2C+set-down&topValue=0x03FF&clockPrescalerOrSource=8&timerMode=PCPWM&OCR3A=508&OCR3B=794
* Mode : PCPWM
* Period : 1.023 ms
* Frequency: 977.51711 Hz
* Outputs :
* - D0: 46.04%, clear-up, set-down
* - D2: 77.61%, clear-up, set-down
void setup(){
TCCR3A =
1 << COM3A1 |
1 << COM3B1 |
1 << WGM31 |
1 << WGM30;
TCCR3B =
1 << CS31;
DDRD =
1 << DDD0 |
1 << DDD2;
void loop(){
OCR3A = 471; // change at will between 0 - 1023
OCR3B = 794; // same
Thank you for the solution. Now I could enable 10 bit (1023 values) PWM at 976 kHz on 16 bit Timers (1, 3 and 4) with your code.
This is the code for T1 and T3 :
call from setup()
void enableT1T3PWM() {
//////////work 10bit for pins 9 and 10 Timer 1 978hz
TCCR1A =
1 << COM1A1 |
1 << COM1B1 |
1 << WGM11 |
1 << WGM10;
TCCR1B = 1 << CS11;
/////// work 10bit for pins 0 and 2 Timer 3 978hz
TCCR3A =
1 << COM3A1 |
1 << COM3B1 |
1 << WGM31 |
1 << WGM30;
TCCR3B = 1 << CS31;
This allows simple
analogWrite (pin, value10bit);
Note that to enable PWM on pin 0 Serial.begin() must be ended with Serial.end().
Work fine on At Mega328PB (Nano)
