PWM jumps from 50% to 100%
Hi all,
I’m experimenting whit an Arduino R4 WifFi and a DF robot quad motor driver (https://www.dfrobot.com/product-1513.html). The board is PWM controlled. To control the speed of a motor I use the analogWrite command.
void M1_advance(char Speed) ///<Motor1 Advance
 digitalWrite(M1,LOW);
 analogWrite(E1,Speed);
This works between 0 and 128 any value between 129 and 255 results in a 100% duty cycle.
I experimented setting the analogWriteResolution to 12. This resulted in a bigger jump in speed. I still get 100% when I specify a value larger than 128. Below 128 I get a lower duty cycle on the PWM
The motor shield seems not to be the problem, I used a scope to watch the PWM signal from the Uno R4 (on pin 3) and its jumps from 50% to 100%.
Using an unsigned was not the solution, what am I missing?
Test software:
* @file QuadMotorDriverShield.ino
* @brief QuadMotorDriverShield.ino  Motor control program
* Every 2 seconds to control motor positive inversion
* @author linfeng(490289303@qq.com)
* @version  V1.0
* @date  2016-4-5
const int E1 = 3; ///<Motor1 Speed
const int E2 = 11;///<Motor2 Speed
const int E3 = 5; ///<Motor3 Speed
const int E4 = 6; ///<Motor4 Speed
const int M1 = 4; ///<Motor1 Direction
const int M2 = 12;///<Motor2 Direction
const int M3 = 8; ///<Motor3 Direction
const int M4 = 7; ///<Motor4 Direction
//minimum speed = 75
// maximum speed = 255
const int sollSpeed = 120;
int loopCounter = 0;
int factor = 1;
int step = 1;
void M2_advance(char Speed) ///<Motor2 Advance
 digitalWrite(M2,HIGH);
 analogWrite(E2,Speed);
void M3_advance(char Speed) ///<Motor3 Advance
 digitalWrite(M3,LOW);
 analogWrite(E3,Speed);
void M4_advance(char Speed) ///<Motor4 Advance
 digitalWrite(M4,HIGH);
 analogWrite(E4,Speed);
void M1_back(char Speed) ///<Motor1 Back off
 digitalWrite(M1,HIGH);
void M2_back(char Speed) ///<Motor2 Back off
 digitalWrite(M2,LOW);
void M3_back(char Speed) ///<Motor3 Back off
 digitalWrite(M3,HIGH);
void M4_back(char Speed) ///<Motor4 Back off
 digitalWrite(M4,LOW);
  analogWriteResolution(8);// - 12 bit analog out resolution.
  for(int i=3;i<9;i++)
    pinMode(i,OUTPUT);
  for(int i=11;i<13;i++)
    pinMode(i,OUTPUT);
  Serial.begin(9600); //Initialiseer de seriele monitor
  if (sollSpeed + (loopCounter * factor) < 130){
    Serial.println(sollSpeed + (loopCounter * factor));
    M1_back(sollSpeed + (loopCounter * factor));
    M2_back(sollSpeed + (loopCounter * factor));
    M3_back(sollSpeed + (loopCounter * factor));
    M4_back(sollSpeed + (loopCounter * factor));
    delay(2000); ///<Delay 2S
    loopCounter = loopCounter + step;
  else {
    M1_advance(0);
    M2_advance(0);
    M3_advance(0);
    M4_advance(0);
The function analogWrite() takes an int argument for speed.
Thanks, I'm a bit ashamed I didn’t see this, I changed char to int and the problem was solved.
I good reminder not to blindly copy paste from the internet.
