i want to controll 39 led's each drawing 20mA with PWM. In order to do this i utilize a BD139 transistor with 1k resistance connected to B.
since it's a NPN, is it possible to put the load in front of the collector and connecting the emitter directly to GND? all parts are supplied by regulated 5V. see picture added below.
As I see it, that's "basically" fine.
If your intention is 780mA through one transistor - maybe (probably) not.
With Rds of <12Ohm with 5v on the gate, then power dissipated by the MOSFET will be I^2 x R = .78A x .78A x .012 = 7.3mW.
WIth BJT, assuming 0.7V Vce, power dissipated = I x V = .78A x 0.7V = 546mW.
To Saturate the BJT, get it to turn full on, you need 50mA of base current to support 500mA Ice current:
VCE(sat) Collector-Emitter Saturation Voltage at IC = 500 mA, IB = 50 mA: 0.5V
which Arduino pin can't support (for very long).
It will work with a 220ohm base resistor.
Saturation voltage of the transistor is a bit higher, the transistor gets hot, and the LEDs are not getting full current.
You could add a small NPN transistor, and make a darlington.
But as CrossRoads suggested, a logic fet would be better/easier.
Leo..
I started a subject along these lines awhile back.
It was more about drawing lots of current than about LEDs, but using LEDs was more visually convincing than just using resistors (I supposed.)
[If it was about getting 20 LEDs going, I would have put bunches of them in series.]
are you sure using MOSFET is a good idea, since i'm using it to controll 39 LEDs with PWM....those high frequencies will increase power loss at the MOSFET?!
if not: all i have to do is connect gate via 330 ohm or so to the arduino pin (and via high resistor - eg. 100k - to GND), source to GND and drain via the load to VCC ?
TobiasCrackz:
Firstly the default PWM frequencies on the Arduino are either about 1kHz or 500Hz depending on
which pin... Not particularly fast.
Secondly a reasonable choice of MOSFET for 1A load or so will have perhaps a couple of nF gate
capacitance, which with a 220 gate resistor would give a switching time of the order of 0.5us
which is fine. Probably faster than BD139 switch-off time from saturation.
