Apologies, didn't think I needed to add a link to a datasheet. I assumed if people knew what a BD139 was, they may be able to answer the question, and vice versa.
The power rating of the silicone heating pad I have is 4W 5V, so the max current is 800ma.
theMusicMan:
Will the PWM signal from an Arduino be sufficient to switch a BD139 on/off in order to control 0-5V on it's output?
An Arduino can certainly click an NPN transistor.
The BD139 alone may not have enough gain for the 800mA you anticipate.
But you could try.
Better use/spec a MOSFET (a low rDS(on), logic-level MOSFET).
theMusicMan:
Simple qn, as though I see the Base-Emitter voltage on the datasheet is 5v
You probably misunderstood.
Vbeo 5volt is the maximum reverse voltage between B and E.
It's in the max ratings (warning) section.
Vbe is 1volt max.
For switching, you need a base current of 1/10 of the collector current. An Arduino pin can't provide 80mA.
A darlington like the TIP120 could be used, but they have a high CE saturation voltage.
A logic mosfet might be the best solution.
Leo..
Wawa:
Vbe is 1volt max.
Leo..
Thanks Leo!
Yep, need to brush up on my understanding datasheet skills :o
You could try a two transistors stage.
BD139: emitter to ground, collector to -load, +Load to (external) supply.
BC547: emitter to BD139 base, collector via 33ohm resistor to Arduino 5volt, base via 1k resitor to Arduino pin.
Leo..
