How do I read serial data in python from Arduino? I've established communication using the serial.readline() command in the loop but I am unable to read real-time data continuously. It takes initial reading and then keeps on giving the same reading no matter what. Any way I can get real-time data without delay? Some way I can see data on ANACONDA as its being produced by ARDUINO? Any help? please? a little lag will be okay. any help would be highly appreciated guys. HELPPPPPPP!
This Simple Python - Arduino demo may help.
The Python code should work on Windows if you edit it to use the Windows style of COM ports.
...R
It would be much faster and reliable to interface Python with your Arduino using the compatible libraries: pySerialTransfer and SerialTransfer.h.
pySerialTransfer is pip-installable and cross-platform compatible. SerialTransfer.h runs on the Arduino platform and can be installed through the Arduino IDE's Libraries Manager.
Both of these libraries have highly efficient and robust packetizing/parsing algorithms with easy to use APIs.
Example Python Script:
import time
from pySerialTransfer import pySerialTransfer as txfer
if __name__ == '__main__':
try:
link = txfer.SerialTransfer('COM17')
link.open()
time.sleep(2) # allow some time for the Arduino to completely reset
while True:
send_size = 0
# Send a list
list_ = [1, 3]
list_size = link.tx_obj(list_)
send_size += list_size
# Send a string
str_ = 'hello'
str_size = link.tx_obj(str_, send_size) - send_size
send_size += str_size
# Send a float
float_ = 5.234
float_size = link.tx_obj(float_, send_size) - send_size
send_size += float_size
# Transmit all the data to send in a single packet
link.send(send_size)
# Wait for a response and report any errors while receiving packets
while not link.available():
if link.status < 0:
if link.status == -1:
print('ERROR: CRC_ERROR')
elif link.status == -2:
print('ERROR: PAYLOAD_ERROR')
elif link.status == -3:
print('ERROR: STOP_BYTE_ERROR')
# Parse response list
rec_list_ = link.rx_obj(obj_type=type(list_),
obj_byte_size=list_size,
list_format='i')
# Parse response string
rec_str_ = link.rx_obj(obj_type=type(str_),
obj_byte_size=str_size,
start_pos=list_size)
# Parse response float
rec_float_ = link.rx_obj(obj_type=type(float_),
obj_byte_size=float_size,
start_pos=(list_size + str_size))
# Display the received data
print('SENT: {} {} {}'.format(list_, str_, float_))
print('RCVD: {} {} {}'.format(rec_list_, rec_str_, rec_float_))
print(' ')
except KeyboardInterrupt:
link.close()
except:
import traceback
traceback.print_exc()
link.close()
Example Arduino Sketch:
#include "SerialTransfer.h"
SerialTransfer myTransfer;
myTransfer.begin(Serial);
if(myTransfer.available())
// send all received data back to Python
for(uint16_t i=0; i < myTransfer.bytesRead; i++)
myTransfer.txBuff[i] = myTransfer.rxBuff[i];
myTransfer.sendData(myTransfer.bytesRead);
On the Arduino side, you can use myTransfer.txObj() and myTransfer.rxObj() to copy values to the library's RX buffer and parse multi-byte variables out of the library's TX buffer.
For theory behind robust serial communication, check out the tutorials Serial Input Basics and Serial Input Advanced.
