Hi, I am trying to use the QMC5883l compass, however, the readings from the compass are clearly inaccurate. If the heading it shows is 200 degrees, and I rotate it ~90 deg CCW, the heading only changes by 40-50 deg. However, if it reads a heading below 100, and I move the compass very slightly, by around 10 deg, the heading jumps by 90 - 100 deg on the compass. I doubt there is an issue with the code because I am using the code provided by the DFRobot_5883 library. I have already factored in magnetic declination, but is any other calibration required?
* @file getCompassdata.ino
* @brief Output the compass data
* @copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @license The MIT License (MIT)
* @author [dexian.huang](952838602@qq.com)
* @version V1.0
* @date 2017-7-3
* @url https://github.com/DFRobot/DFRobot_QMC5883
#include <DFRobot_QMC5883.h>
DFRobot_QMC5883 compass(&Wire, /*I2C addr*/0X0D);
while (!compass.begin())
Serial.println("Could not find a valid 5883 sensor, check wiring!");
if(compass.isHMC())
Serial.println("Initialize HMC5883");
//Set/get the compass signal gain range, default to be 1.3 Ga
// compass.setRange(HMC5883L_RANGE_1_3GA);
// Serial.print("compass range is:");
// Serial.println(compass.getRange());
//Set/get measurement mode
// compass.setMeasurementMode(HMC5883L_CONTINOUS);
// Serial.print("compass measurement mode is:");
// Serial.println(compass.getMeasurementMode());
//Set/get the data collection frequency of the sensor
// compass.setDataRate(HMC5883L_DATARATE_15HZ);
// Serial.print("compass data rate is:");
// Serial.println(compass.getDataRate());
//Get/get sensor status
// compass.setSamples(HMC5883L_SAMPLES_8);
// Serial.print("compass samples is:");
// Serial.println(compass.getSamples());
else if(compass.isQMC())
Serial.println("Initialize QMC5883");
// compass.setRange(QMC5883_RANGE_2GA);
// compass.setMeasurementMode(QMC5883_CONTINOUS);
// compass.setDataRate(QMC5883_DATARATE_50HZ);
// compass.setSamples(QMC5883_SAMPLES_8);
else if(compass.isVCM())
Serial.println("Initialize VCM5883L");
// compass.setMeasurementMode(VCM5883L_CONTINOUS);
// compass.setDataRate(VCM5883L_DATARATE_200HZ);
* @brief Set declination angle on your location and fix heading
* @n You can find your declination on: http://magnetic-declination.com/
* @n (+) Positive or (-) for negative
* @n For Bytom / Poland declination angle is 4'26E (positive)
* @n Formula: (deg + (min / 60.0)) / (180 / PI);
float declinationAngle = (11.0 - (41.0 / 60.0)) / (180 / PI);
compass.setDeclinationAngle(declinationAngle);
sVector_t mag = compass.readRaw();
compass.getHeadingDegrees();
/*Serial.print("X:");
Serial.print(mag.XAxis);
Serial.print(" Y:");
Serial.print(mag.YAxis);
Serial.print(" Z:");
Serial.println(mag.ZAxis);*/
Serial.print("Degress = ");
Serial.println(mag.HeadingDegress);
delay(100);
