Quectel bg950aglaa-n06-sgnsa
Hi everyone,
I have an issue with the BG950AGLAA-N06-SGNSA module and detecting the SIM card. Currently, even though the SIM card is properly inserted, it cannot be detected. An important detail is that I am using a pre-made PCB board that does not have the USIM_DET pin exposed. Could the absence of this pin be causing problems with SIM card detection? If so, is there any workaround or alternative solution that I can apply?
Thanks in advance for any advice and help!
you dont need usim_det to have it work its just to know its there software wise for whatever reason you might have
