I have recently made a project which have multiple sensors performing different function.I want to call all these functions at a frequency of 1HZ.So how reliable is it use a timer interrupt to perform this task.How can I generate this 1Hz delay with timer2 as timer1 is used in servo which I am using again.Would there be any conditions of deadlock?are there any better alternative ways to this. Example I found a non blocking delay library as given in link.Are there any other best choices
using interruption has consequences if what you need to do requires interruption.
1 Hz is pretty slow, you should handle that with millis()
unsigned long chrono;
chrono = millis();
if (millis() - chrono >= 1000) {
// do your stuff
chrono = millis(); // or chrono += 1000; depending on how you want to manage the time it took to execute the actions
You can. But by default interrupts are disabled in an interrupt. So millis() won't be maintained, other ISR dependant stuff (I2C, SoftwareSerial, ...) won't work unless you take special care of it etc... In a nutshell you don't want to run the main part of your code within an interrupt context.
I don't know if it's buggy or not, never used it - but this is just a wrapper to do exactly what I did with millis()... I'm not sure it brings lots of value but if you feel this makes your code looks better...
