Question about capacitors
Would you say such capacitor is beneficial if I use a power supply like this one?
After you turn it off, the status led on it lights for quite a while before going dark, so I would say it has a capacitor somewhere at the end. Or this isn't that simple?
Yes.
Meanwell are known for their crappy designs. But anyway a capicator where the current is drawn is far better than having it way back in the power supply. Yes an LED stays on a long time but so what? It says nothing about the ESR ( effective serial resistance ) of the capacitor, and that is much more important than mere capacity and charge storage, if you want to suppress transients which is the whole point of using one.
Thanks!
Could you recommend a brand with not crappy designs?
Can I measure with a multimeter whether this capacitor is required?
Also,
Grumpy_Mike:
To stop you frying the first LED in the strip if the strip’s supply voltage drops lower than the driving signal and to prevent reflections on the line between strip and Arduino causing excess voltage spikes.
If I fried the first LED, would that result in a break on the strip's 5V line at the first LED?
Not as such, but avoid eBay and use a respectable distributor like Farnell, DigiKey or Mouser. You pay more but get quality stuff.
No.
No.
Thanks! Do you maybe have any idea what could cause such damage? It was working fine for a while and when I tried to plug it in again, this is what I realized.
Lots of damage is cumulative, yes it might work for a time with things chipping away before it actually fails. It could be many things. For example if you apply a signal to the strip before you apply the power to it.
Power supply bring up is important, if you connect and power up your Arduino and then power up the LED strip, you have a signal going into the strip but no power to it. That can damage things, the series resistor in the data line is designed to offer some protection if that happens.
This should 'break' the data line, not the 5V though, right?
Yes, you can't break the 5V line as it does not go through the chip, it is just a piece of copper wire.
