question stp arduino uno + module wifi shield
salut a tt
j'ai une carte arduino uno rev3+ module wifi shield atmeg32uc3a1512
et un programme telecharger
mais aucun réponse
aide moi stp
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "yourNetwork"; // your network SSID (name)
char pass[] = "secretPassword"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
String fv = WiFi.firmwareVersion();
if( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin();
// you're connected now, so print out the status:
printWifiStatus();
// listen for incoming clients
WiFiClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("");
client.println("");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Programme téléchargé et aucune réponse ... Si la mienne !
Je veux dire que vous chargez le programme wifi web serveur sur carte arduino uno et module wifi mais la carte pas travaillez et merci
B83s:
sans plus de détail, un peu dur de répondre :slight_smile:
si téléchargé tel quel, normal que ca réponde pas :wink:
la balise "code" existe pour plus de clarté
Et-ce que des messages arrivent à la console?
normalement il y'a des capteurs A0-A5 mais dans mon pc n'apparaît pas connexion reseau sans fil de arsuino wifi SSID dans la liste de reseau
il est pas en mode point d'accès donc normal.
que viennent faire les pins A0-A5 la dedans?
si tu mettais le prog que tu as mis réellement, ca serait mieux.
salut est qu'il y'a obliger Upload arduino wifi frimware
himriyacine:
vous pouvez répéter la question???
stéphaniiiiieeeeeeeee de monacoooooooooooooooooo
ha ben non c'est pas ca :slight_smile:
blague à part, c'est quoi la question exactement?
salut
j'ai Upload les deux ficher avec succès
-batchisp.exe -device AT32UC3A1512 -hardware usb -operation erase f memory flash blankcheck loadbuffer c:/wifi_dnld.elf program verify start reset 0
-batchisp.exe -device AT32UC3A1512 -hardware usb -operation erase f memory flash blankcheck loadbuffer c:/wifiHD.elf program verify start reset 0
  • et téléverser code wifi web server
    le prb que je connecte aduino uno avec module wifi ily'a un LED rouge ERROR
    aide moi
    et merci
