I am trying to figure out how arduino implements the micros() function.
I understand an interrupt is called to update the current number of microseconds.
What happens when "timer0_overflow_count" exceeds its limit? Since it tracks microseconds and it is a 32 bit unsigned integer, it should overflow in approximately 72 minutes.
Does the micros() function reset? Does that affect the millis() function? My guess is that it does and its all I really want to know.
Catcher:
The value resets, but in a non-destructive manner; it simply goes back [edit: warps over [edit2:roll over?], that's the expression I was looking for] to zero and continues from there. In most calculations, you won't even feel this - unless you measure periods longer than 72 minutes, in which case you shouldn't be using micros() to begin with.
millis()'s value increments with every 1000 "ticks" of the microsecond counter; this check is not influenced by the "reset" in micros(). millis() itself "resets" after about 49 days.
Lastly, whats the need for uint16_t, why not keep it as uint32_t ?
Your version, that uses millis(), may be less accurate. Imagine you want to do a delay(1), and the function happens to get called just a few microseconds before millis() changes. The actual delay will be a lot less than one millisecond. The original version has a better accuracy.
Given that the MCU is 8-bit, the shorter integers are (without losing information), the better and faster.
