Quick question
Beginner here, I am working with the HelloKeypad example file as a start.
Input from the keypad is working, I see numbers show up on the screen when i hit the serial monitor eye glass thing.
My Question is, how does this library/example work? I want to be able to save the input from the keypad/user and store it and maybe down the line check to see if it matches a password and then light up an led or something, how can I do that?
here is the keypad code so far:
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {8, 7, 6, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 3, 2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
void loop(){
char key = keypad.getKey();
if (key){
Serial.println(key);
:slight_smile:
wriley2018:
It works really, really well. Joking. But have you run it? It prints the value of 'key' so you can test the variable 'key' with if statements or switch/case statements, to do various things.
Not serial.println, but Serial.println, like in the code you posted.
Edit: hey, what happened to your post?
TheMemberFormerlyKnownAsAWOL:
aarg:
Thank you for responding! Sorry if its kind of a dumb question i'm not familiar with some of the commands here. like I know printf("") what is serial.prinln ?
and what does keypad keypad =keypad(xyz) mean? I have some idea that its a function taking in values and spitting something out, but where is the function definition? I'm really lost, do you know if there is a tutorial out there that teaches you how to use this library?
so anyways input from the user is being stored in 'key' ? via the .getkey(); command?
I deleted it when i realized you can kinda sorta quote/reply directly to people instead of juts replying to the entire post in general....but then i had to wait because i'm new to this forum so i can only post like every 5 mins lol
For checking password, see Arduino password with keypad
IoT_hobbyist:
thank you, exactly what i was looking for
wriley2018:
Wow, I asked myself the same question when I got into this. But there is a reason, actually, I can't promise that this is it, but I hazily remember that printf() just used up too much memory on a small processor. But with libraries, you can use the '<<' streaming operators for serial output, as is very common in C++. That makes the print functions less verbose in the source code.
