Hi
I am very new to the arduino stuff. I have electronic experience but am stuck with this project.
I copied code as given (attached below) but cant get the push button to trigger immediatly.
Im using the new Unorev 3 board. could this be the problem that the code was written for the older board.
Please help!!!
Hi, unfortunately you have chosen to use another instructables project that has no where near enough information for you to complete the construction.
Here it fails to give you a proper complete circuit diagram.
Hi
You guys ROCK!!!
Thanks for the help getting the quiz buzzers to work.
The change in coding helped.
However....
I now would like to add a ITEAD PLAYER SHIELD to play :
Player 1...Player 2...etc when each respective button is pressed.
Please help with additional coding for attached code.
also how do i load audio to SD card.
Thanks once again for help thus far
