R3 Device Signature Error
I have two new Ardunio Uno R3s and they both exhibit the same device signature error as follows:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA328P is 1E 95 14
avrdude: reading input file "grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex"
avrdude: error opening grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex: No such file or directory
avrdude: input file grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex auto detected as invalid format
avrdude: can't open input file grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex: No such file or directory
avrdude: read from file 'grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex' failed
avrdude: safemode: Fuses OK
avrdude done. Thank you.
As you can see, I changed the device signature from 1E 95 0F to 1E 95 14 (for PU chip). The original signature gave the type of error. I am able to run sketches including controlling a stepper motor using easy driver board.
Since I seem to be having a communication problem, I also tried a different usb cable and different modem ports…no luck.
I running a MacBook Pro with Mountain Lion installed. This is the code I'm using:
Arduino/build/macosx/dist/tools/avr/bin/avrdude -C/Users/myusername/Arduino/build/macosx/dist/tools/avr/etc/avrdude.conf -pm328p -cstk500v1 -P/dev/tty.usbmodem411 -D -Uflash:w:grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex -F
I have searched and searched but have found no solution. Help will be greatly appreciated.
Why did you change the Chip ID? Are your Atmegas '328-PU and not '328P-PU dips?
I changed the chip code based on information in the following forum link:
I had the same error message with the original chip code contained in avrdude.conf. as follows:
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
My chips are 328P-PU. Is there a different code for these chips?
Thanks.
1E 95 0F is correct for your '328P. Does the Arduino IDE upload, say, Blink OK?
Yes, blink works OK. I have also been able to run all three of Brian Schmalz’s stepper motor examples. Today I added a joystick shield and it seems to work OK (position outputs show up the serial monitor). Thanks.
Still no luck with 328P-PU device codes. I tried everything I can of. I ran the Loop-Back test and it checked ok. I have run several sketches with serialWrite and digitalWrite with success. But, every time I try to upload a hex file for my CNC project, I get:
This is the instruction I sending the board via the Mac Terminal.
/Users/myUserName/Ardunio/build/macosx/dist/tools/avr/bin/avrdude -C/Users/ myUserName /Ardunio/build/macosx/dist/tools/avr/etc/avrdude.conf -pm328p -cstk500v1 -P/dev/tty.usbmodem411 -D -Uflash:w:grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex –F
Desperately need help to keep my project going. Thanks.
Regarding the moderator comment "f you are seeing this:
Then it looks to me that you do not have a '328P plugged in."
These are two new Unos purchased from amazon.com (different vendors). The chips on both are marked ATMEG328P-PU. Could they be counterfeit or clones? They were in nicely sealed packages and the boards are marked Made in Italy.
Also is there a way to determine the device code of a board? Thanks.
How are you getting code to load in? Are you using an external writer? Looks like you may have over written your bootloader on the 328P.
This is the instruction I am sending the board via the Mac Terminal.
That's when I get Yikes!
See if changing -cstk500v1 to -carduino does anything.
Great! That got me past the device error problem. The change produced:
avrdude: Device signature = 0x1e950f
avrdude: reading input file "/Users/raymondjohnson/Arduino/build/macosx/dist/tools/avr/etc/grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex"
avrdude: error opening /Users/raymondjohnson/Arduino/build/macosx/dist/tools/avr/etc/grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex: No such file or directory
I now have some directory/path problems to resolve. Greatly appreciated.
Success at last. I put the hex file in my Ardunio user folder a provided an explicit path in my statement as follows:
/Users/myUserName/Ardunio/build/macosx/dist/tools/avr/bin/avrdude -C/Users/myUserName/Ardunio/build/macosx/dist/tools/avr/etc/avrdude.conf -pm328p -carduino -P/dev/tty.usbmodem411 -D -Uflash:w:/Users/myUserName/Ardunio/grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex
And got:
Writing | ################################################## | 100% 4.26s
avrdude: 23050 bytes of flash written
avrdude: verifying flash memory against /Users/myUserName/Ardunio/grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex:
avrdude: load data flash data from input file /Users/myUserName/Ardunio/grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex:
avrdude: input file /Users/myUserName/Ardunio/grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex auto detected as Intel Hex
avrdude: input file /Users/myUserName/Ardunio/grbl_v0_8b_edge_328p_16mhz_9600_build20121013.hex contains 23050 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 3.32s
avrdude: verifying ...
avrdude: 23050 bytes of flash verified
I really appreciate the help.
