Step 5: TROUBLESHOOTING
If anything goes wrong, turn on verbose logging. Go to Preferences... and check the box for "Show verbose output during: [ ] compilation [X] upload"
Error Type 1:
Reading | Error while burning bootloader.
################################################## | 100% 0.05s
avrdude: Device signature = 0x1eXXXX
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
That generally means that either you failed to disable the auto-reset on your ISP Arduino or your target processor is not the right type for the Arduino board you selected in Step 4.
Error Type 2:
avrdude: Device signature = 0x1e9406
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ***failed;
################################################## | 100% 0.13s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x00 != 0x3f
avrdude: verification error; content mismatch
That usually means that you failed to disable the auto-reset on your ISP Arduino (see: Step 2). The Arduino bootloader on your ISP Arduino speaks the same protocol as the ArduinoISP sketch. It doesn't, however, allow you to change lock fuse byte and when asked to read that byte it always returns 0x00. If the ISP Arduino resets and happens to have the same model processor as the target (avoiding Error Type 1 above) the first thing to go wrong will be the read-back of the lock fuse byte. Go back to Step 2.
Error Type 3:
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check..
This is a symptom of the target chip's clock not running. That can happen when you are trying to switch a bare ATmega168/328P from a crystal oscillator (like on an Arduino) to the internal 8 MHz RC oscillator. An ATmega that is expecting a crystal needs that crystal to run its system clock. Without the clock you can't burn a bootloader.
There are two ways to provide a system clock:
1: If you can find a crystal between 8 and 20 MHz you can connect it between pins 9 and 10 of the target chip. Do that and try Step 4 again.
2: If you can't find a spare crystal or you try the crystal and still get the "Device signature = 0x000000" error you should get this modified ArduinoISP sketch from adafruit: GitHub - adafruit/ArduinoISP: A fork of the ArduinoISP that has 8mhz output clock Go back to Step 1 and upload this version of ArduinoISP to your ISP Arduino. Connect Pin 9 of the ISP Arduino to pin 9 of the ATmega168/328P on the breadboard. That will provide an 8 MHz clock to allow programming without a crystal.
If you try both methods and it still fails with "Device signature = 0x000000" you might have a chip with configuration fuses set to disable serial programming. To fix the fuses you will need something like the HV Rescue Shield 2 from MightyOhm (HV Rescue Shield 2 | MightyOhm). That uses High Voltage Serial Programming to reset your ATmega/ATtiny configuration fuses to factory defaults. If that doesn't work your ATmega/ATtiny is probably damaged beyond use.
Error Type 4:
avrdude: 1 bytes of lock verified
avrdude done. Thank you.
That's no error! That indicates SUCCESS!
