R307 fingerprint sensor not detected on NodeMcu esp32
the title pretty much.
The sensor blinks for a second when i connect the board to my laptop but thats pretty much it.
i only get this error in the terminal every time i try to enroll a new fingerpint
G@ a�K0�T��%L��
Adafruit Fingerprint sensor enrollment
Did not find fingerprint sensor :(
here's a picture of the hardware:
code:
  This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  Small bug-fix by Michael cochez
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id;
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) { delay(1); }
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
uint8_t readnumber(void) {
  uint8_t num = 0;
  while (num == 0) {
    while (! Serial.available());
    num = Serial.parseInt();
  return num;
void loop()                     // run over and over again
  Serial.println("Ready to enroll a fingerprint!");
  Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
  id = readnumber();
  if (id == 0) {// ID #0 not allowed, try again!
     return;
  Serial.print("Enrolling ID #");
  Serial.println(id);
  while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
  int p = -1;
  Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.print(".");
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
    default:
      Serial.println("Unknown error");
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  Serial.println("Remove finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  Serial.print("ID "); Serial.println(id);
  p = -1;
  Serial.println("Place same finger again");
    switch (p) {
      Serial.print(".");
    default:
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  Serial.print("Creating model for #");  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
    return p;
  return true;
wiring:
Check the baudrate in serial monitor. Code uses 9600, serial uses?
Crank up both to 115200.
hey! i see a drop down menu in my serial monitor to change the baudrate. would setting that 115200 do the trick or do i need to change something else as well?
serial uses?
not entirely sure what this means, im still very new to arduino.
a screenshot of the dropdown menu in question:
tried setting the baudrate from the dropdown menu to 115200 and this is what i got. Not sure what to make of it
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13260
load:0x40080400,len:3028
entry 0x400805e4
Serial monitor looks like running at 115200. Use the same rate in the code, not 9600.
I'm not sure about how to do that. doing a find for the term"baud" in the codebase pulls up this line
appears to be the only occurance of baudrate within the code itself.
i tried changing this line to
Serial.print(F("Baud rate: 115200 ")); Serial.println(finger.baud_rate);
but that doesnt seem to be doing anything either
this is the output i got:
entry 0x400805e4
is there a possibility that the sensor is bricked? I'm not sure because the thing does momentarily blink when i plug the board in. Is there a way to know for sure?
Try Serial.begin(115200); in setup.
tried that.
this is what i got.
Looks good to me.
i think i made a mistake while copying the output. It still says "sensor not found"
entry 0x400805e4
That's good progress compared to the Chinese messages earlier.
A link to the datasheet for the sensor might help us.
My guess is that the esp is a 3.3 volt logic device. What kind is the sensor?
here's a link to datasheet for the sensor.
also attached is a schematic for the NodeMCU esp32
How is the ESP powered?
Connecting ESP Vin to +5 R307 might be a mistake.
esp powered by usb (connected to a laptop). also, the r307 is running 3.3V. i soldered the 3.3v contacts on the r307 like so
Then You can't expect any power at Vin, as far as I know. Use the 5 volt pin! The 3.3 volt pin ought to provide 3.3 volt then.
That's beyond my comfort zone.....
GPIO 16 & 17 is serial2 port yet in the code you used, serial1 is used.
solutions:
either deifine serial1 pins(any other pins apart from the defaults of serial and serial 2) for example:
<#define RXD1 9
#define TXD1 10
  Serial.begin(9600);  // Initialize Serial for debugging
  Serial1.begin(57600, SERIAL_8N1, RXD1, TXD1);  // Initialize Serial1 with custom pins
or change the Serial1 instance of mySerial to Serial2, which seems easier.
#define mySerial Serial2
instead of
please use 3.3v
