Hello, I was wondering If the MinIMA uses the same SWD hardware programmer the arduino zero uses? The other question is Would any SWD hardware programmer work?
Joseph
Joseph
Please, refrain from starting multiple topics with the same subject. Continue this subject using your other topic.
@xfpd Well one is for programming using the IDE. And the other one is hardware programmer is there out not software.
Okay. Sorry to intrerfere.
@xfpd But you could be right. I might of worded it off a little. I will look at it and fix if I made a mistake for it.
The arduino zero has an on-board swd programmer.
The minima has a bootloader, like the (retired) Arduino M0.
In theory, you should be able to program the minima (or re-program the arduino bootloader) using a standard swd debugger - there is even the standard 10pm swd connector. (There also appears to be some sort of rom bootloader…)
