Hello,
I built a geiger counter inside of a small plastic project box. I recently added a 3 digit led display on a second board controlled by an arduino microcontroller. I am using just the atmel chip in a socket with a crystal. I have the multiplexed display working perfectly, and I can send the time value to the display as a check by commenting out all the lines in the top part of the code and sending "time" to "displayValue". I commented these lines out in the code but you can read through and see them.
The problem I am having is the display. When I run this code, the display just reads "111". I have played with my code by changing values here and there, and I can't seem to affect those 1's with anything other than the counter routine I outlined above. The data is reaching the arduino properly, and I can see this by throwing a line of code in to send "state" to "displayValue", and the LSB will flicker when I excite the geiger tube with radioactive source. I have the pulses coming out of the geiger counter running through a 555 timer to make them a constant pulsewidth, which is about 100 ns. To be clear, the pulses are randomly timed, and have a constant pulsewidth of 100ns.
Does anyone have any idea why I might be seeing "111" instead of zero's and/or why I can't get the counetr to increment? Any help would be greatly appreciated.
THIS CODE HAS BEEN MODIFIED AND IS IN THE POST BELOW
// Geiger counter seven segment display with analog input
// By Scott Damiani
// Sept 2, 2013
// rev 9/7/2013
const int digitalPin = A0; // set analog input pin as A0 with digitalRead
const int maxvalue = 999;
void setup() // run these once
DDRD = B11111111; // set port D pins as digital outputs 7:0
DDRB = B111111; // set port B pins as digital outputs 13:8
// not needed with DDRB pinMode(8, OUTPUT);
// pinMode(9, OUTPUT);
// pinMode(10, OUTPUT); // set 8, 9, and 10 as outputs
int sensorReading = 0;
int num3 = 0;
int num2 = 0;
int num1 = 0;
int digitSelect = 1;
int cps = 0;
int displayValue = 0;
int count = 0;
void loop () // the main program
int time; int lastTime; int state; int sampleTime = 1; int displayValue; int count; int lastState;
lastState = state; // if state changes, last state will record the change
state = digitalRead(digitalPin); // sets state to 0 or 1 depending on current input status
lastTime = time; // when time changes, lastTime will record the change
time = (millis()/(sampleTime*1000)); // (should be *1000) converts milliseconds to seconds
if (time != lastTime) {displayValue = count; count = 0;} /// when time increments,
/// the current value of count will be displayed, and then the count is reset
if (state != lastState) { // if input is HIGH then execute next line
if (state == HIGH) {count++; lastState = HIGH; // increment counter if input is HIGH
///this line makes sure to read only the rising edge of the input pulse
} else {lastState = LOW;}
// displayValue = time; //activate this for counter and deactivate all above but "time = (millis.."line
int num3 = (displayValue/100); // seperates the 100's digit and set it to num3 active on pin 10
int num2 = ((displayValue/10)-(num3*10)); // seperates the 10's digit and set it to num2 active on pin 9
int num1 = ((displayValue)-(num2*10)-(num3*100)); // seperates the 1's digit and set it to num1 active on pin 8
for (int digitSelect = 1; digitSelect<4; digitSelect++) // selects a number to set active on display
// delay(1); // this line helps eliminates bleed/blur from the other numbers but makes the MSB go crazy
int num = 1; // this won't work above with the other int statements
if (digitSelect == 1) {
num = num1;
PORTB = B000110;
} // sends LOW to pin 8 and biases LED#1 power switching transistor
if (digitSelect == 2) {
num = num2;
PORTB = B000011;
} // sends LOW to pin 9 and biases LED#2 power switching transistor
if (digitSelect == 3) {
num = num3;
PORTB = B000101;
} // same as above this last one could be an else statement too
delay (9);
// this was here to attempt to remove blur but doesn't completely remove it
switch (num) { // MSB is set to 0 for all cases and num is the current displayed digit with active high
// had to swap pins "b" and "f" due to an assembly error
case 0:
PORTD = B11111010; // number zero or = 0x7E this outputs to segments on pins 1-7 and pin 0 is always LOW
case 1:
PORTD = B10001000; // number one or = 0x30 hex example
case 2:
PORTD = B10110110; // number two
case 3:
PORTD = B10011110; // number three
case 4:
PORTD = B11001100; // number four
case 5:
PORTD = B01011110; // number five
case 6:
PORTD = B01111110; // number six
case 7:
PORTD = B10001010; // number seven
case 8:
PORTD = B11111110; // number eight
case 9:
PORTD = B11011110; // number nine
default:
PORTD = B00000000; // blank
} // switch end
} // for end
} // loop end
