Rainbow/Gradient colour scheme for TFT fillRect,triangle,circle
HI All
I have made a temperature and humidity monitor with 2.4" ST7789 TFT display, AdafruitGFX and DHT22 sensors
The temp and humid value are displayed as a 180* ( half circle ) ring meter with rainbow display colour gradient using Bodmers ring meter display Bodmer ring meter display
What I would like to do is have shaded background rectangles for each meter, vertically. I "could" do it with a rainbow bar graph, but would rather find a better method.
#include <Adafruit_ST7735.h>
#include <Adafruit_ST7789.h>
#include <Adafruit_ST7796S.h>
#include <Adafruit_ST77xx.h>
#include "DHT.h"
#include <SPI.h>
#include "Adafruit_GFX.h"
#include <Fonts/FreeSansBoldOblique9pt7b.h>
#include <Fonts/FreeSans9pt7b.h>
DHT dht1(2, DHT22);
DHT dht2(3, DHT22);
DHT dht3(4, DHT22);
DHT dht4(5, DHT22);
// xpos = dist from left edge, ypos = dist down from top, radius = size
// Meter colour schemes
#define TFT_CS 10
#define TFT_RST 9  // Or set to -1 and connect to Arduino RESET pin
#define TFT_DC 8
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
#define ST77XX_BLACK 0x0000
#define ST77XX_GRAY 0x8410
#define ST77XX_WHITE 0xFFFF
#define ST77XX_RED 0xF800
#define ST77XX_ORANGE 0xFA60
#define ST77XX_YELLOW 0xFFE0
#define ST77XX_DENIM 0x03EE
#define ST77XX_GREEN 0x1781
#define ST77XX_DARKGREEN 0x2ce1
#define ST77XX_LIGHTGREEN 0xc781
#define ST77XX_CYAN 0x07FF
#define ST77XX_AQUA 0x04FF
#define ST77XX_BLUE 0x001F
#define ST77XX_MAGENTA 0xF81F
#define ST77XX_PINK 0xF8FF
#define WHITE2BLUE 0
#define GREEN2GREEN 1
#define BLUE2BLUE 2
#define BLUE2RED 3
#define GREEN2RED 4
#define RED2GREEN 5
#define YELLOW2RED 6
#define WHITE2BLUE 7
#define ST77XX_GREY 0x2104  // Dark grey 16 bit colour
float humidS1 = dht1.readHumidity();
float tempS1 = dht1.readTemperature();
float humidS2 = dht2.readHumidity();
float tempS2 = dht2.readTemperature();
float humidS3 = dht3.readHumidity();
float tempS3 = dht3.readTemperature();
float humidS4 = dht4.readHumidity();
float tempS4 = dht4.readTemperature();
  dht1.begin();
  dht2.begin();
  dht3.begin();
  dht4.begin();
  Serial.print(F("Hello! ST77xx TFT Test"));
  tft.init(240, 320);  // Init ST7789 240x320  // Use this initializer (uncomment) if using a 1.3" or 1.54" 240x240 240x320 TFT etc:
  tft.fillScreen(ST77XX_BLACK);
  tft.setRotation(1);
  tft.setCursor(80, 100);
  tft.setTextSize(4);
  tft.print("T.I.S.M");
  delay(2000);
  tft.fillScreen(ST77XX_WHITE);
  tft.invertDisplay(0);
  tft.fillRoundRect(2, 2, 157, 117, 5, ST77XX_GREY);
  tft.fillRoundRect(161,2, 156, 117, 5, ST77XX_GREY);
  tft.fillRoundRect(2,121 , 157,117, 5, ST77XX_GREY);
  tft.fillRoundRect(161,121, 156, 117, 5, ST77XX_GREY);
  Serial.print("Humidity of Sensor   1: ");
  Serial.println(humidS1, 2);
  Serial.print("Temp of Sensor        1: ");
  Serial.println(tempS1, 2);
  Serial.print("Humidity of Sensor   2: ");
  Serial.println(humidS2, 2);
  Serial.print("Temp of Sensor         2: ");
  Serial.println(tempS2, 2);
  Serial.print("Humidity of Sensor   4: ");
  float tempS3 = dht3.readTemperature(0);
  Serial.print("Temp of Sensor         3: ");
  Serial.println(tempS3, 2);
  Serial.print("Humidity of Sensor   3: ");
  Serial.println(humidS4, 2);
  Serial.print("Temp of Sensor         4: ");
  Serial.println(tempS4, 2);
tft.setTextSize(2);
//tft.setFont(&FreeSansBoldOblique9pt7b);
    //Display tempS1, humidS1
    tft.setCursor(62, 75);
    tft.setTextColor(ST77XX_AQUA, ST77XX_GREY);
    tft.print(humidS1, 0);
    tft.setCursor(110, 100);
    tft.setTextColor(ST77XX_ORANGE, ST77XX_GREY);
    tft.print(tempS1, 0);
    tft.setCursor(10, 100);
    tft.setTextColor(ST77XX_GREEN, ST77XX_GREY);
    tft.print("O/side");
    //Display tempS2
    tft.setCursor(220, 75);
    tft.print(humidS2, 0);
    tft.setCursor(270, 100);
    tft.print(tempS2, 0);
    tft.setCursor(180, 100);
    tft.setTextColor(ST77XX_WHITE, ST77XX_GREY);
    tft.print("Room *c");
    //Display tempS3
    tft.setCursor(62,200);
    tft.print(humidS3, 0);
    tft.setCursor(110, 220);
    tft.print(tempS3, 0);
    tft.setCursor(10, 220);
    tft.print("Air-Ex");
    //Display tempS4
    tft.setCursor(220, 200);
    tft.print(humidS4, 0);
    tft.setCursor(280, 220);
    tft.print(tempS4, 0);
    tft.setCursor(180, 220);
    tft.print("Air-out");
  // values for ((int) enginerpm/oil/boost/egt are derived from respective float values as displayed in texwrite, not from pin values
  // Set the the position, gap between meters, and inner radius of the meters
  int xpos = 0, ypos = 0, gap = 0, radius = 0;
  // Draw temp1
  xpos = 10, ypos = 20, gap = 50, radius = 70;                                 //sets size and position on screen
  xpos = gap + ringMeter1((int)tempS1, -10, 60, xpos, ypos, radius, 1, YELLOW2RED);  //0, 50 are range off meter ie 0-50 oilPSI
  //Draw hunid
  xpos = 40, ypos = 50, gap = 50, radius = 40;                                  //sets size and position on screen
  xpos = gap + ringMeter1((int)humidS1, 0, 100, xpos, ypos, radius, 1, WHITE2BLUE);  //0, 120 are range off meter ie 0-120*c
  // Draw temp2
  xpos = 170, ypos = 20, gap = 50, radius = 70;                                    //sets size and position on screen
  xpos = gap + ringMeter1((int)tempS2, -10, 60, xpos, ypos, radius, 1, YELLOW2RED);  //0, 120 are range off meter ie 0-120*c
  // Draw humid2
  xpos = 200, ypos = 50, gap = 50, radius = 40;                                     //sets size and position on screen
  xpos = gap + ringMeter1((int)humidS2, 0, 100, xpos, ypos, radius, 1, WHITE2BLUE);  //0, 120 are range off meter ie 0-120*c
  //Draw temp3
  xpos = 10, ypos = 140, gap = 50, radius = 70;                                 //sets size and position on screen
  xpos = gap + ringMeter1((int)tempS3, -10, 60, xpos, ypos, radius, 1, YELLOW2RED);  //0, 750 are range off meter ie 0-750*c EGT Temp
  //Draw hunid3
  xpos = 40, ypos = 170, gap = 50, radius = 40;                                     //sets size and position on screen
  xpos = gap + ringMeter1((int)humidS3, 0, 100, xpos, ypos, radius, 1, WHITE2BLUE);  //0, 120 are range off meter ie 0-120*c
  // Draw temp4
  xpos = 170, ypos = 140, gap = 50, radius = 70;                               //sets size and position on screen
  xpos = gap + ringMeter1((int)tempS4, -10, 60, xpos, ypos, radius, 1, YELLOW2RED);  //0, 30 are range off meter ie 0-30psi boost*c
  // Draw humid4
  xpos = 200, ypos = 170, gap = 50, radius = 40;                                    //sets size and position on screen
  xpos = gap + ringMeter1((int)humidS4, 0, 100, xpos, ypos, radius, 1, WHITE2BLUE);  //0, 120 are range off meter ie 0-120*c
//  Draw the meter on the screen, returns x coord of righthand side
int ringMeter1(int temp, int vmin, int vmax, int x, int y, int r, const char *units, byte scheme) {
  // Minimum value of r is about 52 before value text intrudes on ring
  // drawing the text first is an option
  x += r;
  y += r;  // Calculate coords of centre of ring
  int w = r / 5;  // Width of outer ring is. 4 = 1/4 of radius, smaller number gives fater ring
  int angle = 90;  // Half the sweep angle of meter (300 degrees) 90 gives a semi-circle, 180 = full-circle
  int text_colour = 0;  // To hold the text colour
  int v = map(temp, vmin, vmax, -angle, angle);  // Map the value to an angle v
  byte seg = 1;  // Segments are 5 degrees wide = 60 segments for 300 degrees
  byte inc = 1;  // Draw segments every 5 degrees, increase to 10 for segmented ring
  // Draw colour blocks every inc degrees
  for (int i = -angle; i < angle; i += inc) {
    // Choose colour from scheme
    int colour = 0;
    switch (scheme) {
      case 0: colour = ST77XX_RED; break;                               // Fixed colour
      case 1: colour = ST77XX_GREEN; break;                             // Fixed colour
      case 2: colour = ST77XX_BLUE; break;
      // BLUE 0=BLUE 63=GREEN 127=RED
      case 3: colour = rainbow(map(i, -angle, angle, 0, 127)); break;   // Full spectrum BLUE2RED 0=BLUE 63=GREEN 127=RED
      case 4: colour = rainbow(map(i, -angle, angle, 63, 127)); break;  // GREEN2RED
      case 5: colour = rainbow(map(i, -angle, angle, 127, 63)); break;  // RED2GREEN
      case 6: colour = rainbow(map(i, -angle, angle, 90, 127)); break;  // YELLOW2RED
      case 7: colour = rainbow(map(i, -angle, angle, 40, 0)); break;  // WHITE2BLUE
      default: colour = ST77XX_BLUE; break;  // Fixed colour
    // Calculate pair of coordinates for segment start
    float sx = cos((i - 90) * 0.0174532925);
    float sy = sin((i - 90) * 0.0174532925);
    uint16_t x0 = sx * (r - w) + x;
    uint16_t y0 = sy * (r - w) + y;
    uint16_t x1 = sx * r + x;
    uint16_t y1 = sy * r + y;
    // Calculate pair of coordinates for segment end
    float sx2 = cos((i + seg - 90) * 0.0174532925);
    float sy2 = sin((i + seg - 90) * 0.0174532925);
    int x2 = sx2 * (r - w) + x;
    int y2 = sy2 * (r - w) + y;
    int x3 = sx2 * r + x;
    int y3 = sy2 * r + y;
    if (i < v) {  // Fill in coloured segments with 2 triangles
      tft.fillTriangle(x0, y0, x1, y1, x2, y2, colour);
      tft.fillTriangle(x1, y1, x2, y2, x3, y3, colour);
      text_colour = colour;  // Save the last colour drawn
    } else                   // Fill in blank segments
      tft.fillTriangle(x0, y0, x1, y1, x2, y2, ST77XX_GREY);
      tft.fillTriangle(x1, y1, x2, y2, x3, y3, ST77XX_GREY);
  // Convert value to a string
  char buf[10];
  byte len = 4;
  if (temp > 999) len = 5;
  dtostrf(temp, len, 0, buf);
// Return a 16 bit rainbow colour
unsigned int rainbow(byte value) {
  // Value is expected to be in range 0-127
  // The value is converted to a spectrum colour from 0 = blue through to 127 = red
  byte red = 0;    // Red is the top 5 bits of a 16 bit colour value
  byte green = 0;  // Green is the middle 6 bits
  byte blue = 0;   // Blue is the bottom 5 bits
  byte quadrant = value / 32;
  if (quadrant == 0) {
    blue = 31;
    green = 2 * (value % 32);
    red = 0;
  if (quadrant == 1) {
    blue = 31 - (value % 32);
    green = 63;
    red = 0;
  if (quadrant == 2) {
    blue = 0;
    green = 63;
    red = value % 32;
  if (quadrant == 3) {
    blue = 0;
    green = 63 - 2 * (value % 32);
    red = 31;
  return (red << 11) + (green << 5) + blue;
My first advice would be to spend some time improving this code and your coding skills, before moving on to enhancing the code. It is full of repetition and at least 4 times longer than it should be. Learn about arrays, for-loops and/or creating your own functions to remove that repetition. This will make enhancing the code easier because you will need to do it once only instead of 4 times over.
Yes, I do understand what you are saying, this is a work in progress.
I am just concentrating on one just 1 specific thing at the moment, then I can move on
I don't think this code will work correctly. It's certainly not a good idea. Initialising global variables happens before setup() runs, and setup() calls the .begin() method for the sensors. Until .begin() has been called, the results of .readTemperature() and .readHumidity() may not be valid.
Instead, let them default to zero and assign an initial value to them in setup(), after .begin() has been called.
Fine, but the 1 specific thing that you should be concentrating on right now is improving the code, then you can move on to enhancing it. Take it from me, I've been coding for 40+ years. If you put more complexity into something that's already over-complicated, you will run into trouble.
I'll get you started.
DHT dht1(2, DHT22);
DHT dht2(3, DHT22);
DHT dht3(4, DHT22);
DHT dht4(5, DHT22);
becomes
#define SENSORS 4
DHT dht[SENSORS] = {
  DHT(2, DHT22),
  DHT(3, DHT22),
  DHT(4, DHT22),
  DHT(5, DHT22)
Then you can use a for-loop in setup() to start each sensor:
  for(byte s = 0; s < SENSORS; s++) {
    dht[s].begin();
    humidS[s] = dht[s].readHumidity();
    tempS[s] = dht[s].readTemperature();
Yes, I can do all that, but, I have been playing with different sensors as well, different values, different scales...etc.. At present it is just using 4 x DHT22 just to see how they go, but I am going to throw a Ktype in there as well, and and maybe a DS18xx...so it might end up a mix of sensors, I will also use the same layout for pressure and vacuum sensors
At the moment I am concentrating on the graphical element, as I can adapt the graphic element to whatever sensors and readings I want. ...Think engine monitor....
This actually works perfectly, slow, but works. But YES, I should set those float values to "0" instead of the read.temp values. Normally I set float/int values to 0. just not this time
You don't really need to read the sensors in setup(), since the readings are not used in setup(), and the first thing you do in loop() is read the sensors. The DHT22 is a fairly slow sensor, taking around 250mS to get a reading. If you do want to read the sensors in setup(), the delay would not be noticeable if you moved the initialization to right after the first delay(2000) in setup and reducing that delay to 1000mS.
Yes, they are very slow compared to most others
