How to substitute a SSD1351 display to use a ST7735 UNO script
I am attempting to substitute a ST7735 display in place of the original SSD1351 display in an Arduino sketch I found on the net.
The original sketch using the SSD1351 works however my attempts to convert this display to a more inexpensive display are unsuccessful. My thinking was that a few simple substitutions of the display type entries should do it. With my inexperience showing I was wrong.
Below is a copy of the original sketch and a copy of my own with the errors. I expect I’m just missing something simple here but could use some help. Thanks in advance for any assistance.
Ie:
Compilation error: no matching function for call to 'Adafruit_ST7735::Adafruit_ST7735(int, int, SPIClass*, int, int, int)'
 *   LM: Emulate magic eye tube
 *   Requires Adafruit libraries supporting 1.5-inch 16-bit Color OLED display
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1351.h>
#include <SPI.h>
// #define DEBUG
// Screen dimensions
#define SCREEN_WIDTH  128
#define SCREEN_HEIGHT 128 // Change this to 96 for 1.27" OLED.
// You can use any (4 or) 5 pins
#define SCLK_PIN 2
#define MOSI_PIN 3        // AKA DIN
#define DC_PIN   4
#define CS_PIN   5
#define RST_PIN  6
// Hardware
#define SCLK_PIN 13
#define MOSI_PIN 11
#define DC_PIN   12
#define CS_PIN   10
#define RST_PIN  6
// Color definitions
#define BLACK           0x0000
#define BLUE            0x001F
#define RED             0xF800
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define WHITE           0xFFFF
                         // Adafruit GREEN is 0x07E0
#define BRTGREEN  0x0380  // Simulate the lit part of the tube
#define DIMGREEN  0x01A0  // Dimmer 0x200, Less dim 0x400 (still green)
#define TESTCOLOR 0x0000  // Change value for testing
// Option 1: use any pins but a little slower
//Adafruit_SSD1351 tft = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, CS_PIN, DC_PIN, MOSI_PIN, SCLK_PIN, RST_PIN);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
 Adafruit_SSD1351 tft = Adafruit_SSD1351(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI, CS_PIN, DC_PIN, RST_PIN);
// Application-wide declarations follow:
const boolean DOUBLE_WEDGE = true;   // More realistic but slower (half-speed)
const int TONE_OUT =     8;          // DIO pin 8 - Random wedge demo 'sound effects'
const int RADIO_PIN = A0;            // Signal strength input
const boolean RADIO_MODE = true;     // If true, tracks signal on RADIO_PIN, else demo mode
const boolean INVERT_S = true;       // -> Stronger signal = narrower angle
// Calibration
const boolean RT_CAL = false;        // If true sMin and sMAX auto-calibrate...  Else,
int sMin = 100;                      // Signal minimum (in units 0 to 1023
int sMax = 500;                      // Signal maximum (empirically determined)
const int DAMPING_CONSTANT = 0;      // Relative weight of recent signal readings
                                     // Value = 0 disables software damping
const boolean TONE_DEMO = true;      // Tone for demo random wedge (consumes cycles)
const boolean MUSICAL_NOTES = false; // Substitute random notes for random frequency
const int AMAX = 50;                 // Degrees
const int XMAX = SCREEN_WIDTH;       // Number of horizontal pixels
const int YMAX = SCREEN_HEIGHT;      // Number of vertical pixels
const int X0   = XMAX/2;             // Approximate middle
const int Y0   = YMAX/2;
const int R    = Y0;                 // Radius of outer circle
const int R_SMALL = 27;              // Radius of inner circle
const int R2   = 4096;               // Squared radius of outer circle
const int DEG  = 90;                 // Degrees in quadrant
const int MAX_DISPLAY_ANGLE = 45;    // Less than or equal to maximum tabled angle
// The following circle array is for testing.
// QC stands for 'quarter circle' - Quadrant I
// R=64
const int QC [R] = {64,64,64,64,64,64,64,63,63,63,63,63,63,62,62,62,62,61,61,61,60,60,60,59,59,58,58,58,57,57,56,55,55,54,54,53,52,51,51,50,49,48,47,46,46,44,43,42,41,40,39,37,36,34,33,31,29,27,25,22,19,16,11,0};
// R=27 (Center circle)
const int SMQC [R_SMALL] = {27,27,27,27,27,26,26,26,25,25,25,24,24,23,22,22,21,20,19,18,17,16,14,12,10,7,0};
// Quadrant 1 pixel array, presently 2 to 50 degrees
// Subscript order: angle in degrees, delta x, delta y_min, delta y_max
const int DIMV = 754;
const int PROGMEM V [DIMV] [4] = {               // {angle, x, min y, max y}
                        {2,1,43,63},
                        {3,1,29,42},
                        {3,2,48,63},
                        {4,1,27,28},
                        {4,2,36,47},
                        {4,3,50,63},
                        {5,2,29,35},
                        {5,3,40,49},
                        {5,4,51,63},
                        {5,5,63,63},
                        {6,2,27,28},
                        {6,3,33,39},
                        {6,4,43,50},
                        {6,5,52,62},
                        {6,6,62,63},
                        {7,3,29,32},
                        {7,4,37,42},
                        {7,5,45,51},
                        {7,6,53,61},
                        {7,7,61,63},
                        {8,3,27,28},
                        {8,4,32,36},
                        {8,5,39,44},
                        {8,6,46,52},
                        {8,7,53,60},
                        {8,8,60,63},
                        {9,4,28,31},
                        {9,5,35,38},
                        {9,6,41,45},
                        {9,7,47,52},
                        {9,8,54,59},
                        {9,9,60,63},
                        {10,4,27,27},
                        {10,5,31,34},
                        {10,6,37,40},
                        {10,7,43,46},
                        {10,8,48,53},
                        {10,9,54,59},
                        {10,10,60,63},
                        {11,5,28,30},
                        {11,6,33,36},
                        {11,7,39,42},
                        {11,8,44,47},
                        {11,9,49,53},
                        {11,10,54,59},
                        {11,11,59,63},
                        {12,5,27,27},
                        {12,6,31,32},
                        {12,7,35,38},
                        {12,8,40,43},
                        {12,9,45,48},
                        {12,10,49,53},
                        {12,11,54,58},
                        {12,12,59,62},
                        {13,6,28,30},
                        {13,7,32,34},
                        {13,8,37,39},
                        {13,9,41,44},
                        {13,10,45,48},
                        {13,11,50,53},
                        {13,12,54,58},
                        {13,13,58,62},
                        {14,6,27,27},
                        {14,7,30,31},
                        {14,8,34,36},
                        {14,9,38,40},
                        {14,10,42,44},
                        {14,11,46,49},
                        {14,12,50,53},
                        {14,13,54,57},
                        {14,14,58,62},
                        {14,15,62,62},
                        {15,7,28,29},
                        {15,8,32,33},
                        {15,9,35,37},
                        {15,10,39,41},
                        {15,11,43,45},
                        {15,12,47,49},
                        {15,13,50,53},
                        {15,14,54,57},
                        {15,15,58,61},
                        {16,7,27,27},
                        {16,8,30,31},
                        {16,9,33,34},
                        {16,10,37,38},
                        {16,11,40,42},
                        {16,12,44,46},
                        {16,13,47,49},
                        {16,14,51,53},
                        {16,15,54,57},
                        {16,16,58,61},
                        {16,17,61,61},
                        {17,8,28,29},
                        {17,9,31,32},
                        {17,10,34,36},
                        {17,11,38,39},
                        {17,12,41,43},
                        {17,13,44,46},
                        {17,14,47,50},
                        {17,15,51,53},
                        {17,16,54,57},
                        {17,17,57,60},
                        {17,18,61,61},
                        {18,8,26,27},
                        {18,9,29,30},
                        {18,10,32,33},
                        {18,11,35,37},
                        {18,12,38,40},
                        {18,13,42,43},
                        {18,14,45,46},
                        {18,15,48,50},
                        {18,16,51,53},
                        {18,17,54,56},
                        {18,18,57,60},
                        {18,19,60,61},
                        {19,9,28,28},
                        {19,10,30,31},
                        {19,11,33,34},
                        {19,12,36,37},
                        {19,13,39,41},
                        {19,14,42,44},
                        {19,15,45,47},
                        {19,16,48,50},
                        {19,17,51,53},
                        {19,18,54,56},
                        {19,19,57,59},
                        {19,20,60,60},
                        {20,9,26,27},
                        {20,10,29,29},
                        {20,11,32,32},
                        {20,12,34,35},
                        {20,13,37,38},
                        {20,14,40,41},
                        {20,15,43,44},
                        {20,16,45,47},
                        {20,17,48,50},
                        {20,18,51,53},
                        {20,19,54,56},
                        {20,20,56,59},
                        {20,21,59,60},
                        {21,10,27,28},
                        {21,11,30,31},
                        {21,12,33,33},
                        {21,13,35,36},
                        {21,14,38,39},
                        {21,15,40,42},
                        {21,16,43,44},
                        {21,17,46,47},
                        {21,18,48,50},
                        {21,19,51,53},
                        {21,20,53,55},
                        {21,21,56,58},
                        {21,22,59,60},
                        {22,10,26,26},
                        {22,11,28,29},
                        {22,12,31,32},
                        {22,13,33,34},
                        {22,14,36,37},
                        {22,15,38,39},
                        {22,16,41,42},
                        {22,17,43,45},
                        {22,18,46,47},
                        {22,19,48,50},
                        {22,20,51,52},
                        {22,21,53,55},
                        {22,22,56,58},
                        {22,23,58,59},
                        {23,11,27,27},
                        {23,12,29,30},
                        {23,13,32,32},
                        {23,14,34,35},
                        {23,15,37,37},
                        {23,16,39,40},
                        {23,17,41,42},
                        {23,18,44,45},
                        {23,19,46,47},
                        {23,20,48,50},
                        {23,21,51,52},
                        {23,22,53,55},
                        {23,23,55,57},
                        {23,24,58,59},
                        {24,11,26,26},
                        {24,12,28,28},
                        {24,13,30,31},
                        {24,14,33,33},
                        {24,15,35,36},
                        {24,16,37,38},
                        {24,17,39,40},
                        {24,18,42,43},
                        {24,19,44,45},
                        {24,20,46,47},
                        {24,21,48,50},
                        {24,22,51,52},
                        {24,23,53,54},
                        {24,24,55,57},
                        {24,25,57,58},
                        {25,11,25,25},
                        {25,12,27,27},
                        {25,13,29,29},
                        {25,14,31,32},
                        {25,15,33,34},
                        {25,16,35,36},
                        {25,17,38,38},
                        {25,18,40,41},
                        {25,19,42,43},
                        {25,20,44,45},
                        {25,21,46,47},
                        {25,22,48,50},
                        {25,23,50,52},
                        {25,24,53,54},
                        {25,25,55,56},
                        {25,26,57,58},
                        {26,12,26,26},
                        {26,13,28,28},
                        {26,14,30,30},
                        {26,15,32,32},
                        {26,16,34,34},
                        {26,17,36,37},
                        {26,18,38,39},
                        {26,19,40,41},
                        {26,20,42,43},
                        {26,21,44,45},
                        {26,22,46,47},
                        {26,23,48,49},
                        {26,24,50,52},
                        {26,25,52,54},
                        {26,26,54,56},
                        {26,27,56,58},
                        {27,12,25,25},
                        {27,13,26,27},
                        {27,14,28,29},
                        {27,15,30,31},
                        {27,16,32,33},
                        {27,17,34,35},
                        {27,18,36,37},
                        {27,19,38,39},
                        {27,20,40,41},
                        {27,21,42,43},
                        {27,22,44,45},
                        {27,23,46,47},
                        {27,24,48,49},
                        {27,25,50,51},
                        {27,26,52,53},
                        {27,27,54,55},
                        {27,28,56,57},
                        {28,13,25,25},
                        {28,14,27,27},
                        {28,15,29,29},
                        {28,16,31,31},
                        {28,17,33,33},
                        {28,18,35,35},
                        {28,19,37,37},
                        {28,20,39,39},
                        {28,21,40,41},
                        {28,22,42,43},
                        {28,23,44,45},
                        {28,24,46,47},
                        {28,25,48,49},
                        {28,26,50,51},
                        {28,27,52,53},
                        {28,28,54,55},
                        {28,29,55,57},
                        {29,13,24,24},
                        {29,14,26,26},
                        {29,15,28,28},
                        {29,16,30,30},
                        {29,17,32,32},
                        {29,18,33,34},
                        {29,19,35,36},
                        {29,20,37,38},
                        {29,21,39,39},
                        {29,22,41,41},
                        {29,23,42,43},
                        {29,24,44,45},
                        {29,25,46,47},
                        {29,26,48,49},
                        {29,27,50,51},
                        {29,28,51,53},
                        {29,29,53,54},
                        {29,30,55,56},
                        {30,14,25,25},
                        {30,15,27,27},
                        {30,16,29,29},
                        {30,17,30,31},
                        {30,18,32,32},
                        {30,19,34,34},
                        {30,20,36,36},
                        {30,21,37,38},
                        {30,22,39,40},
                        {30,23,41,41},
                        {30,24,42,43},
                        {30,25,44,45},
                        {30,26,46,47},
                        {30,27,48,49},
                        {30,28,49,50},
                        {30,29,51,52},
                        {30,30,53,54},
                        {30,31,55,55},
                        {31,14,24,24},
                        {31,15,26,26},
                        {31,16,27,28},
                        {31,17,29,29},
                        {31,18,31,31},
                        {31,19,32,33},
                        {31,20,34,35},
                        {31,21,36,36},
                        {31,22,37,38},
                        {31,23,39,40},
                        {31,24,41,41},
                        {31,25,42,43},
                        {31,26,44,45},
                        {31,27,46,47},
                        {31,28,47,48},
                        {31,29,49,50},
                        {31,30,51,52},
                        {31,31,52,54},
                        {31,32,54,55},
                        {32,15,25,25},
                        {32,16,26,26},
                        {32,17,28,28},
                        {32,18,30,30},
                        {32,19,31,31},
                        {32,20,33,33},
                        {32,21,34,35},
                        {32,22,36,36},
                        {32,23,38,38},
                        {32,24,39,40},
                        {32,25,41,41},
                        {32,26,42,43},
                        {32,27,44,45},
                        {32,28,46,46},
                        {32,29,47,48},
                        {32,30,49,50},
                        {32,31,50,51},
                        {32,32,52,53},
                        {32,33,54,54},
                        {33,15,24,24},
                        {33,16,25,25},
                        {33,17,27,27},
                        {33,18,28,29},
                        {33,19,30,30},
                        {33,20,32,32},
                        {33,21,33,33},
                        {33,22,35,35},
                        {33,23,36,37},
                        {33,24,38,38},
                        {33,25,39,40},
                        {33,26,41,41},
                        {33,27,42,43},
                        {33,28,44,45},
                        {33,29,45,46},
                        {33,30,47,48},
                        {33,31,49,49},
                        {33,32,50,51},
                        {33,33,52,53},
                        {33,34,53,54},
                        {34,15,23,23},
                        {34,16,24,24},
                        {34,17,26,26},
                        {34,18,27,27},
                        {34,19,29,29},
                        {34,20,30,31},
                        {34,21,32,32},
                        {34,22,33,34},
                        {34,23,35,35},
                        {34,24,36,37},
                        {34,25,38,38},
                        {34,26,39,40},
                        {34,27,41,41},
                        {34,28,42,43},
                        {34,29,44,44},
                        {34,30,45,46},
                        {34,31,47,48},
                        {34,32,48,49},
                        {34,33,50,51},
                        {34,34,51,52},
                        {34,35,53,53},
                        {35,17,25,25},
                        {35,18,26,26},
                        {35,19,28,28},
                        {35,20,29,29},
                        {35,21,31,31},
                        {35,22,32,32},
                        {35,23,34,34},
                        {35,24,35,35},
                        {35,25,36,37},
                        {35,26,38,38},
                        {35,27,39,40},
                        {35,28,41,41},
                        {35,29,42,43},
                        {35,30,44,44},
                        {35,31,45,46},
                        {35,32,46,47},
                        {35,33,48,49},
                        {35,34,49,50},
                        {35,35,51,52},
                        {35,36,52,52},
                        {36,16,23,23},
                        {36,17,24,24},
                        {36,18,25,25},
                        {36,19,27,27},
                        {36,20,28,28},
                        {36,21,30,30},
                        {36,22,31,31},
                        {36,23,32,33},
                        {36,24,34,34},
                        {36,25,35,35},
                        {36,26,36,37},
                        {36,27,38,38},
                        {36,28,39,40},
                        {36,29,41,41},
                        {36,30,42,43},
                        {36,31,43,44},
                        {36,32,45,45},
                        {36,33,46,47},
                        {36,34,47,48},
                        {36,35,49,50},
                        {36,36,50,51},
                        {36,37,52,52},
                        {37,16,22,22},
                        {37,17,23,23},
                        {37,19,26,26},
                        {37,20,27,27},
                        {37,21,29,29},
                        {37,22,30,30},
                        {37,23,31,31},
                        {37,24,33,33},
                        {37,25,34,34},
                        {37,26,35,35},
                        {37,27,36,37},
                        {37,28,38,38},
                        {37,29,39,40},
                        {37,30,40,41},
                        {37,31,42,42},
                        {37,32,43,44},
                        {37,33,44,45},
                        {37,34,46,46},
                        {37,35,47,48},
                        {37,36,48,49},
                        {37,37,50,51},
                        {37,38,51,51},
                        {38,17,22,22},
                        {38,18,24,24},
                        {38,19,25,25},
                        {38,20,26,26},
                        {38,21,28,28},
                        {38,22,29,29},
                        {38,23,30,30},
                        {38,24,31,32},
                        {38,25,33,33},
                        {38,26,34,34},
                        {38,27,35,35},
                        {38,28,36,37},
                        {38,29,38,38},
                        {38,30,39,39},
                        {38,31,40,41},
                        {38,32,42,42},
                        {38,33,43,43},
                        {38,34,44,45},
                        {38,35,45,46},
                        {38,36,47,47},
                        {38,37,48,49},
                        {38,38,49,50},
                        {39,18,23,23},
                        {39,19,24,24},
                        {39,20,25,25},
                        {39,21,27,27},
                        {39,22,28,28},
                        {39,23,29,29},
                        {39,24,30,30},
                        {39,25,31,32},
                        {39,26,33,33},
                        {39,27,34,34},
                        {39,28,35,35},
                        {39,29,36,37},
                        {39,30,38,38},
                        {39,31,39,39},
                        {39,32,40,41},
                        {39,33,41,42},
                        {39,34,43,43},
                        {39,35,44,44},
                        {39,36,45,46},
                        {39,37,46,47},
                        {39,38,48,48},
                        {39,39,49,50},
                        {40,17,21,21},
                        {40,18,22,22},
                        {40,19,23,23},
                        {40,20,24,24},
                        {40,21,26,26},
                        {40,22,27,27},
                        {40,23,28,28},
                        {40,24,29,29},
                        {40,25,30,30},
                        {40,26,32,32},
                        {40,27,33,33},
                        {40,28,34,34},
                        {40,29,35,35},
                        {40,30,36,37},
                        {40,31,38,38},
                        {40,32,39,39},
                        {40,33,40,40},
                        {40,34,41,42},
                        {40,35,42,43},
                        {40,36,43,44},
                        {40,37,45,45},
                        {40,38,46,47},
                        {40,39,47,48},
                        {40,40,48,49},
                        {40,41,49,49},
                        {41,18,21,21},
                        {41,19,22,22},
                        {41,21,25,25},
                        {41,22,26,26},
                        {41,23,27,27},
                        {41,24,28,28},
                        {41,25,29,29},
                        {41,26,30,31},
                        {41,27,32,32},
                        {41,28,33,33},
                        {41,29,34,34},
                        {41,30,35,35},
                        {41,31,36,37},
                        {41,32,37,38},
                        {41,33,39,39},
                        {41,34,40,40},
                        {41,35,41,41},
                        {41,36,42,42},
                        {41,37,43,44},
                        {41,38,44,45},
                        {41,39,45,46},
                        {41,40,47,47},
                        {41,41,48,48},
                        {42,20,23,23},
                        {42,21,24,24},
                        {42,22,25,25},
                        {42,23,26,26},
                        {42,24,27,27},
                        {42,25,28,28},
                        {42,26,29,29},
                        {42,27,31,31},
                        {42,28,32,32},
                        {42,29,33,33},
                        {42,30,34,34},
                        {42,31,35,35},
                        {42,32,36,36},
                        {42,33,37,38},
                        {42,34,38,39},
                        {42,35,39,40},
                        {42,36,41,41},
                        {42,37,42,42},
                        {42,38,43,43},
                        {42,39,44,44},
                        {42,40,45,46},
                        {42,41,46,47},
                        {42,42,47,48},
                        {43,19,21,21},
                        {43,20,22,22},
                        {43,21,23,23},
                        {43,22,24,24},
                        {43,23,25,25},
                        {43,24,26,26},
                        {43,25,27,27},
                        {43,26,28,28},
                        {43,27,29,30},
                        {43,28,31,31},
                        {43,29,32,32},
                        {43,30,33,33},
                        {43,31,34,34},
                        {43,32,35,35},
                        {43,33,36,36},
                        {43,34,37,37},
                        {43,35,38,38},
                        {43,36,39,40},
                        {43,37,40,41},
                        {43,38,41,42},
                        {43,39,42,43},
                        {43,40,43,44},
                        {43,41,45,45},
                        {43,42,46,46},
                        {43,43,47,47},
                        {44,19,20,20},
                        {44,20,21,21},
                        {44,21,22,22},
                        {44,22,23,23},
                        {44,23,24,24},
                        {44,24,25,25},
                        {44,25,26,26},
                        {44,26,27,27},
                        {44,27,28,28},
                        {44,28,30,30},
                        {44,29,31,31},
                        {44,30,32,32},
                        {44,31,33,33},
                        {44,32,34,34},
                        {44,33,35,35},
                        {44,34,36,36},
                        {44,35,37,37},
                        {44,36,38,38},
                        {44,37,39,39},
                        {44,38,40,40},
                        {44,39,41,41},
                        {44,40,42,42},
                        {44,41,43,44},
                        {44,42,44,45},
                        {44,43,45,46},
                        {44,44,46,46},
                        {45,20,20,20},
                        {45,21,21,21},
                        {45,22,22,22},
                        {45,23,23,23},
                        {45,24,24,24},
                        {45,25,25,25},
                        {45,26,26,26},
                        {45,27,27,27},
                        {45,28,28,29},
                        {45,29,29,30},
                        {45,30,30,31},
                        {45,31,31,32},
                        {45,32,32,33},
                        {45,33,33,34},
                        {45,34,34,35},
                        {45,35,35,36},
                        {45,36,36,37},
                        {45,37,37,38},
                        {45,38,38,39},
                        {45,39,39,40},
                        {45,40,40,41},
                        {45,41,41,42},
                        {45,42,42,43},
                        {45,43,43,44},
                        {45,44,44,45},
                        {45,45,45,45},
                        {46,29,28,28},
                        {46,30,29,29},
                        {46,31,30,30},
                        {46,32,31,31},
                        {46,33,32,32},
                        {46,34,33,33},
                        {46,35,34,34},
                        {46,36,35,35},
                        {46,37,36,36},
                        {46,38,37,37},
                        {46,39,38,38},
                        {46,40,39,39},
                        {46,41,40,40},
                        {46,42,41,41},
                        {46,43,42,42},
                        {46,44,43,43},
                        {46,45,44,44},
                        {47,20,19,19},
                        {47,21,20,20},
                        {47,22,21,21},
                        {47,23,22,22},
                        {47,24,23,23},
                        {47,25,24,24},
                        {47,26,25,25},
                        {47,27,26,26},
                        {47,28,27,27},
                        {47,30,28,28},
                        {47,31,29,29},
                        {47,32,30,30},
                        {47,33,31,31},
                        {47,34,32,32},
                        {47,35,33,33},
                        {47,36,34,34},
                        {47,37,35,35},
                        {47,38,36,36},
                        {47,39,37,37},
                        {47,40,38,38},
                        {47,41,39,39},
                        {47,42,40,40},
                        {47,43,41,41},
                        {47,44,41,42},
                        {47,45,42,43},
                        {47,46,43,44},
                        {48,21,19,19},
                        {48,22,20,20},
                        {48,23,21,21},
                        {48,24,22,22},
                        {48,25,23,23},
                        {48,26,24,24},
                        {48,27,25,25},
                        {48,28,26,26},
                        {48,29,27,27},
                        {48,30,27,27},
                        {48,31,28,28},
                        {48,32,29,29},
                        {48,33,30,30},
                        {48,34,31,31},
                        {48,35,32,32},
                        {48,36,33,33},
                        {48,37,34,34},
                        {48,38,35,35},
                        {48,39,36,36},
                        {48,40,36,37},
                        {48,41,37,38},
                        {48,42,38,39},
                        {48,43,39,40},
                        {48,44,40,40},
                        {48,45,41,41},
                        {48,46,42,42},
                        {48,47,43,43},
                        {49,23,20,20},
                        {49,24,21,21},
                        {49,25,22,22},
                        {49,26,23,23},
                        {49,27,24,24},
                        {49,28,25,25},
                        {49,29,26,26},
                        {49,31,27,27},
                        {49,32,28,28},
                        {49,33,29,29},
                        {49,34,30,30},
                        {49,35,31,31},
                        {49,36,32,32},
                        {49,37,33,33},
                        {49,38,33,34},
                        {49,39,34,35},
                        {49,40,35,35},
                        {49,41,36,36},
                        {49,42,37,37},
                        {49,43,38,38},
                        {49,44,39,39},
                        {49,45,40,40},
                        {49,46,40,41},
                        {49,47,41,42},
                        {49,48,42,42},
                        {50,21,18,18},
                        {50,22,19,19},
                        {50,25,21,21},
                        {50,26,22,22},
                        {50,27,23,23},
                        {50,28,24,24},
                        {50,29,25,25},
                        {50,30,26,26},
                        {50,31,26,26},
                        {50,32,27,27},
                        {50,33,28,28},
                        {50,34,29,29},
                        {50,35,30,30},
                        {50,36,31,31},
                        {50,37,31,32},
                        {50,38,32,32},
                        {50,39,33,33},
                        {50,40,34,34},
                        {50,41,35,35},
                        {50,42,36,36},
                        {50,43,37,37},
                        {50,44,37,38},
                        {50,45,38,39},
                        {50,46,39,39},
                        {50,47,40,40},
                        {50,48,41,41}
const int VNDX[AMAX-1] = {0, 1, 3, 6, 10, 15, 20, 26, 32, 39, 46, 54, 62, 72, 81, 92, 103, 115, 127, 140, 153, 167, 181, 196, 212, 228, 245, 262, 280, 298, 317, 336, 356, 377, 397, 419, 441, 463, 485, 510, 533, 556, 581, 607, 633, 650, 676, 703, 728};
int lastOpening = 0;      // Last width before changing in response to analog data
long sDamping = AMAX / 2; // For use in damping received signal strength
// Substitute notes for frequencies in correlated tone demo
// Two octaves + one half-step (for the convenient 8/15 calculation)
// * Slower, because average frequency is lower in the note range!
const int TONES   = 25;
const int NOTES[] = {262, 277, 294, 311, 330, 349, 370, 392, 415, 440, 466, 494, 523, 554, 587, 622, 659, 740, 784, 831, 880, 932, 988, 1047, 1108};
#ifdef DEBUG
#endif
  // Not sure if radio signal pin should be pulled up
  pinMode(RADIO_PIN, INPUT);
  if (RADIO_MODE && RT_CAL) {
    sMin = 1023;
    sMax = 0;
  pinMode(TONE_OUT, OUTPUT);
  tft.begin();
  tft.fillScreen(BLACK);
  tft.fillCircle(X0, Y0, R-1, BRTGREEN);
  tft.fillCircle(X0, Y0, R_SMALL, DIMGREEN);
  randomSeed(analogRead(0));
  if (!RADIO_MODE) {
    testV(DIMGREEN);
    delay(2000);
    testV(BRTGREEN);
    delay(2000);
  initMidline(DIMGREEN);
  int to;
  int from = lastOpening;
  if (RADIO_MODE)
    to = signalStrength();
  else {
    to = random(MAX_DISPLAY_ANGLE);
    int freq;
    if (TONE_DEMO) {
      if (MUSICAL_NOTES)
        freq = NOTES[TONES - (to*8/15)- 1];
        freq = 1200-(to*20);
      tone(TONE_OUT, freq);
#ifdef DEBUG
  Serial.println("to = " + String(to) + ", from = " + String(from));
#endif
  if (to > from)       // Shrink
    drawV(from, to, DIMGREEN);
  else if (to < from)  // Expand
    drawV(from, to, BRTGREEN);
  lastOpening = to;
int fetch(int i, int j) {   //Placeholder
  return pgm_read_word_near(V[i] + j);
void drawV(int from, int to, uint16_t color) {
  // parameters 'from' and 'to' are degrees
  from -= 2;                  // Convert degrees to VNDX subscript
  to   -= 2;
  if (from < 0) from = 0;     // Index to angle cannot be negative, etc.
  if (to   < 0) to   = 0;
  if (from > (AMAX-1)) from = AMAX-1;
  if (to   > (AMAX-1)) to   = AMAX-1;
  int phi, v_from, v_to, x, y, y1, y2, h;
  if (from == to) return;
  else if (from < to) {       // Expanding wedge
    v_from = VNDX[from];      // Starting point in large data array
    if (to == (AMAX-1))
//    v_to = DIMV;
      v_to = VNDX[to];        // For startup before S-meter calibration
      v_to = VNDX[to+1];      // Stopping point in large data array
    for (int i=v_from; i<v_to; i++) {
      x  = fetch(i, 1);       // delta x (offset from X0)
      y1 = fetch(i, 2);       // delta y (smallest y for specified x)
      y2 = fetch(i, 3);       // delta y (largest y for specified x)
      h  = y2 - y1 + 1;       // Not used in drawPixel - For drawFastVLine
      tft.drawFastVLine(X0+x, Y0-y2, h, color);
      tft.drawFastVLine(X0-x, Y0-y2, h, color);
      if (DOUBLE_WEDGE) {   // Bottom wedge (Reduces speed to 1/2)
        tft.drawFastVLine(X0+x, Y0+y1, h, color);
        tft.drawFastVLine(X0-x, Y0+y1, h, color);
      // Alternatively tft.drawPixel loop ...
    } // End for (i...)
  } // End else if (from < to)
  else {                      // Contracting wedge
    if (from == (AMAX-1))
      v_from = VNDX[DIMV];
      v_from = VNDX[from+1];  // Starting point in large data array
    v_to   = VNDX[to];        // Stopping point in large data array
    for (int i=v_from; i>v_to; i--) {
    } // End for (i...)
  } // End else // Contracting wedge
int signalStrength() {
  int s = analogRead(RADIO_PIN);
  if (RT_CAL) {
    if (s < sMin) sMin = s;
    else if (s > sMax) sMax = s;
  else {
    if (s < sMin) s = sMin;
    else if (s > sMax) s = sMax;
#ifdef DEBUG
  Serial.println("s = " + String(s) + ", sMin = " + String(sMin) + ", sMax= " + String(sMax));
#endif
  // Convert to angle
  long tmp;
  if ((sMax - sMin) > 0)
    tmp = (long) (s - sMin) * (long) MAX_DISPLAY_ANGLE / (long) (sMax - sMin);
    tmp = MAX_DISPLAY_ANGLE - 1;
#ifdef DEBUG
  Serial.println("Angle = " + String(tmp));
#endif
  if (INVERT_S) tmp = MAX_DISPLAY_ANGLE - tmp;
  return dampen(tmp);
int dampen(long sAngle) {
  if (DAMPING_CONSTANT == 0) return sAngle;
  sDamping = (sDamping * DAMPING_CONSTANT + sAngle) / (DAMPING_CONSTANT + 1);
#ifdef DEBUG
  Serial.println("Dampened sAngle = " + String(sDamping));
#endif
  return (int) sDamping;
// * Below will be removed when testing is complete
void initMidline(uint16_t color) {
  int from = Y0;
  if (DOUBLE_WEDGE)
    from = YMAX;
  for (int y=from; y>=0; y--) {
    tft.drawPixel(X0-1, y, color);
    tft.drawPixel(X0,   y, color);
    tft.drawPixel(X0+1, y, color);
void testV(uint16_t color) {                        // Ascertain if V can be placed in variable storage
  int phi, x, y, y1,y2;                             // Finally a clean wedge
  for (int i=0; i<DIMV; i++) {
    phi = fetch(i, 0);
    x   = fetch(i, 1);
    y1  = Y0-fetch(i, 2);
    y2  = Y0-fetch(i, 3);
    for (y=y1; y<=y2; y++)
      tft.drawPixel(x, y, BLACK);
    for (y=y2; y<=y1; y++) {
      tft.drawPixel(X0 + x, y, color);
      tft.drawPixel(X0 - x, y, color);
ST7735 Sketch
//#include <Adafruit_SSD1351.h>
#include <Adafruit_ST7735.h>
#include <SPI.h>
//#include <Adafruit_ImageReader.h>
// #define DEBUG
#define SCLK_PIN 2
#define DC_PIN   4
#define CS_PIN   5
#define RST_PIN  6
// Hardware
#define SCLK_PIN 13
#define MOSI_PIN 11
#define DC_PIN   12
#define CS_PIN   10
#define RST_PIN  6
#define BLUE            0x001F
#define RED             0xF800
#define CYAN            0x07FF
//Adafruit_ST7735 tft = Adafruit_ST7735(SCREEN_WIDTH, SCREEN_HEIGHT, CS_PIN, DC_PIN, MOSI_PIN, SCLK_PIN, RST_PIN);
Adafruit_ST7735 tft = Adafruit_ST7735(SCREEN_WIDTH, SCREEN_HEIGHT, &SPI, CS_PIN, DC_PIN, RST_PIN);
// Calibration
// R=64
                        {2,1,43,63},
                        {3,1,29,42},
                        {3,2,48,63},
                        {4,1,27,28},
                        {4,2,36,47},
                        {4,3,50,63},
                        {5,2,29,35},
                        {5,3,40,49},
                        {5,4,51,63},
                        {5,5,63,63},
                        {6,2,27,28},
                        {6,3,33,39},
                        {6,4,43,50},
                        {6,5,52,62},
                        {6,6,62,63},
                        {7,3,29,32},
                        {7,4,37,42},
                        {7,5,45,51},
                        {7,6,53,61},
                        {7,7,61,63},
                        {8,3,27,28},
                        {8,4,32,36},
                        {8,5,39,44},
                        {8,6,46,52},
                        {8,7,53,60},
                        {8,8,60,63},
                        {9,4,28,31},
                        {9,5,35,38},
                        {9,6,41,45},
                        {9,7,47,52},
                        {9,8,54,59},
                        {9,9,60,63},
                        {10,4,27,27},
                        {10,5,31,34},
                        {10,6,37,40},
                        {10,7,43,46},
                        {10,8,48,53},
                        {10,9,54,59},
                        {10,10,60,63},
                        {11,5,28,30},
                        {11,6,33,36},
                        {11,7,39,42},
                        {11,8,44,47},
                        {11,9,49,53},
                        {11,10,54,59},
                        {11,11,59,63},
                        {12,5,27,27},
                        {12,6,31,32},
                        {12,7,35,38},
                        {12,8,40,43},
                        {12,9,45,48},
                        {12,10,49,53},
                        {12,11,54,58},
                        {12,12,59,62},
                        {13,6,28,30},
                        {13,7,32,34},
                        {13,8,37,39},
                        {13,9,41,44},
                        {13,10,45,48},
                        {13,11,50,53},
                        {13,12,54,58},
                        {13,13,58,62},
                        {14,6,27,27},
                        {14,7,30,31},
                        {14,8,34,36},
                        {14,9,38,40},
                        {14,10,42,44},
                        {14,11,46,49},
                        {14,12,50,53},
                        {14,13,54,57},
                        {14,14,58,62},
                        {14,15,62,62},
                        {15,7,28,29},
                        {15,8,32,33},
                        {15,9,35,37},
                        {15,10,39,41},
                        {15,11,43,45},
                        {15,12,47,49},
                        {15,13,50,53},
                        {15,14,54,57},
                        {15,15,58,61},
                        {16,7,27,27},
                        {16,8,30,31},
                        {16,9,33,34},
                        {16,10,37,38},
                        {16,11,40,42},
                        {16,12,44,46},
                        {16,13,47,49},
                        {16,14,51,53},
                        {16,15,54,57},
                        {16,16,58,61},
                        {16,17,61,61},
                        {17,8,28,29},
                        {17,9,31,32},
                        {17,10,34,36},
                        {17,11,38,39},
                        {17,12,41,43},
                        {17,13,44,46},
                        {17,14,47,50},
                        {17,15,51,53},
                        {17,16,54,57},
                        {17,17,57,60},
                        {17,18,61,61},
                        {18,8,26,27},
                        {18,9,29,30},
                        {18,10,32,33},
                        {18,11,35,37},
                        {18,12,38,40},
                        {18,13,42,43},
                        {18,14,45,46},
                        {18,15,48,50},
                        {18,16,51,53},
                        {18,17,54,56},
                        {18,18,57,60},
                        {18,19,60,61},
                        {19,9,28,28},
                        {19,10,30,31},
                        {19,11,33,34},
                        {19,12,36,37},
                        {19,13,39,41},
                        {19,14,42,44},
                        {19,15,45,47},
                        {19,16,48,50},
                        {19,17,51,53},
                        {19,18,54,56},
                        {19,19,57,59},
                        {19,20,60,60},
                        {20,9,26,27},
                        {20,10,29,29},
                        {20,11,32,32},
                        {20,12,34,35},
                        {20,13,37,38},
                        {20,14,40,41},
                        {20,15,43,44},
                        {20,16,45,47},
                        {20,17,48,50},
                        {20,18,51,53},
                        {20,19,54,56},
                        {20,20,56,59},
                        {20,21,59,60},
                        {21,10,27,28},
                        {21,11,30,31},
                        {21,12,33,33},
                        {21,13,35,36},
                        {21,14,38,39},
                        {21,15,40,42},
                        {21,16,43,44},
                        {21,17,46,47},
                        {21,18,48,50},
                        {21,19,51,53},
                        {21,20,53,55},
                        {21,21,56,58},
                        {21,22,59,60},
                        {22,10,26,26},
                        {22,11,28,29},
                        {22,12,31,32},
                        {22,13,33,34},
                        {22,14,36,37},
                        {22,15,38,39},
                        {22,16,41,42},
                        {22,17,43,45},
                        {22,18,46,47},
                        {22,19,48,50},
                        {22,20,51,52},
                        {22,21,53,55},
                        {22,22,56,58},
                        {22,23,58,59},
                        {23,11,27,27},
                        {23,12,29,30},
                        {23,13,32,32},
                        {23,14,34,35},
                        {23,15,37,37},
                        {23,16,39,40},
                        {23,17,41,42},
                        {23,18,44,45},
                        {23,19,46,47},
                        {23,20,48,50},
                        {23,21,51,52},
                        {23,22,53,55},
                        {23,23,55,57},
                        {23,24,58,59},
                        {24,11,26,26},
                        {24,12,28,28},
                        {24,13,30,31},
                        {24,14,33,33},
                        {24,15,35,36},
                        {24,16,37,38},
                        {24,17,39,40},
                        {24,18,42,43},
                        {24,19,44,45},
                        {24,20,46,47},
                        {24,21,48,50},
                        {24,22,51,52},
                        {24,23,53,54},
                        {24,24,55,57},
                        {24,25,57,58},
                        {25,11,25,25},
                        {25,12,27,27},
                        {25,13,29,29},
                        {25,14,31,32},
                        {25,15,33,34},
                        {25,16,35,36},
                        {25,17,38,38},
                        {25,18,40,41},
                        {25,19,42,43},
                        {25,20,44,45},
                        {25,21,46,47},
                        {25,22,48,50},
                        {25,23,50,52},
                        {25,24,53,54},
                        {25,25,55,56},
                        {25,26,57,58},
                        {26,12,26,26},
                        {26,13,28,28},
                        {26,14,30,30},
                        {26,15,32,32},
                        {26,16,34,34},
                        {26,17,36,37},
                        {26,18,38,39},
                        {26,19,40,41},
                        {26,20,42,43},
                        {26,21,44,45},
                        {26,22,46,47},
                        {26,23,48,49},
                        {26,24,50,52},
                        {26,25,52,54},
                        {26,26,54,56},
                        {26,27,56,58},
                        {27,12,25,25},
                        {27,13,26,27},
                        {27,14,28,29},
                        {27,15,30,31},
                        {27,16,32,33},
                        {27,17,34,35},
                        {27,18,36,37},
                        {27,19,38,39},
                        {27,20,40,41},
                        {27,21,42,43},
                        {27,22,44,45},
                        {27,23,46,47},
                        {27,24,48,49},
                        {27,25,50,51},
                        {27,26,52,53},
                        {27,27,54,55},
                        {27,28,56,57},
                        {28,13,25,25},
                        {28,14,27,27},
                        {28,15,29,29},
                        {28,16,31,31},
                        {28,17,33,33},
                        {28,18,35,35},
                        {28,19,37,37},
                        {28,20,39,39},
                        {28,21,40,41},
                        {28,22,42,43},
                        {28,23,44,45},
                        {28,24,46,47},
                        {28,25,48,49},
                        {28,26,50,51},
                        {28,27,52,53},
                        {28,28,54,55},
                        {28,29,55,57},
                        {29,13,24,24},
                        {29,14,26,26},
                        {29,15,28,28},
                        {29,16,30,30},
                        {29,17,32,32},
                        {29,18,33,34},
                        {29,19,35,36},
                        {29,20,37,38},
                        {29,21,39,39},
                        {29,22,41,41},
                        {29,23,42,43},
                        {29,24,44,45},
                        {29,25,46,47},
                        {29,26,48,49},
                        {29,27,50,51},
                        {29,28,51,53},
                        {29,29,53,54},
                        {29,30,55,56},
                        {30,14,25,25},
                        {30,15,27,27},
                        {30,16,29,29},
                        {30,17,30,31},
                        {30,18,32,32},
                        {30,19,34,34},
                        {30,20,36,36},
                        {30,21,37,38},
                        {30,22,39,40},
                        {30,23,41,41},
                        {30,24,42,43},
                        {30,25,44,45},
                        {30,26,46,47},
                        {30,27,48,49},
                        {30,28,49,50},
                        {30,29,51,52},
                        {30,30,53,54},
                        {30,31,55,55},
                        {31,14,24,24},
                        {31,15,26,26},
                        {31,16,27,28},
                        {31,17,29,29},
                        {31,18,31,31},
                        {31,19,32,33},
                        {31,20,34,35},
                        {31,21,36,36},
                        {31,22,37,38},
                        {31,23,39,40},
                        {31,24,41,41},
                        {31,25,42,43},
                        {31,26,44,45},
                        {31,27,46,47},
                        {31,28,47,48},
                        {31,29,49,50},
                        {31,30,51,52},
                        {31,31,52,54},
                        {31,32,54,55},
                        {32,15,25,25},
                        {32,16,26,26},
                        {32,17,28,28},
                        {32,18,30,30},
                        {32,19,31,31},
                        {32,20,33,33},
                        {32,21,34,35},
                        {32,22,36,36},
                        {32,23,38,38},
                        {32,24,39,40},
                        {32,25,41,41},
                        {32,26,42,43},
                        {32,27,44,45},
                        {32,28,46,46},
                        {32,29,47,48},
                        {32,30,49,50},
                        {32,31,50,51},
                        {32,32,52,53},
                        {32,33,54,54},
                        {33,15,24,24},
                        {33,16,25,25},
                        {33,17,27,27},
                        {33,18,28,29},
                        {33,19,30,30},
                        {33,20,32,32},
                        {33,21,33,33},
                        {33,22,35,35},
                        {33,23,36,37},
                        {33,24,38,38},
                        {33,25,39,40},
                        {33,26,41,41},
                        {33,27,42,43},
                        {33,28,44,45},
                        {33,29,45,46},
                        {33,30,47,48},
                        {33,31,49,49},
                        {33,32,50,51},
                        {33,33,52,53},
                        {33,34,53,54},
                        {34,15,23,23},
                        {34,16,24,24},
                        {34,17,26,26},
                        {34,18,27,27},
                        {34,19,29,29},
                        {34,20,30,31},
                        {34,21,32,32},
                        {34,22,33,34},
                        {34,23,35,35},
                        {34,24,36,37},
                        {34,25,38,38},
                        {34,26,39,40},
                        {34,27,41,41},
                        {34,28,42,43},
                        {34,29,44,44},
                        {34,30,45,46},
                        {34,31,47,48},
                        {34,32,48,49},
                        {34,33,50,51},
                        {34,34,51,52},
                        {34,35,53,53},
                        {35,17,25,25},
                        {35,18,26,26},
                        {35,19,28,28},
                        {35,20,29,29},
                        {35,21,31,31},
                        {35,22,32,32},
                        {35,23,34,34},
                        {35,24,35,35},
                        {35,25,36,37},
                        {35,26,38,38},
                        {35,27,39,40},
                        {35,28,41,41},
                        {35,29,42,43},
                        {35,30,44,44},
                        {35,31,45,46},
                        {35,32,46,47},
                        {35,33,48,49},
                        {35,34,49,50},
                        {35,35,51,52},
                        {35,36,52,52},
                        {36,16,23,23},
                        {36,17,24,24},
                        {36,18,25,25},
                        {36,19,27,27},
                        {36,20,28,28},
                        {36,21,30,30},
                        {36,22,31,31},
                        {36,23,32,33},
                        {36,24,34,34},
                        {36,25,35,35},
                        {36,26,36,37},
                        {36,27,38,38},
                        {36,28,39,40},
                        {36,29,41,41},
                        {36,30,42,43},
                        {36,31,43,44},
                        {36,32,45,45},
                        {36,33,46,47},
                        {36,34,47,48},
                        {36,35,49,50},
                        {36,36,50,51},
                        {36,37,52,52},
                        {37,16,22,22},
                        {37,17,23,23},
                        {37,19,26,26},
                        {37,20,27,27},
                        {37,21,29,29},
                        {37,22,30,30},
                        {37,23,31,31},
                        {37,24,33,33},
                        {37,25,34,34},
                        {37,26,35,35},
                        {37,27,36,37},
                        {37,28,38,38},
                        {37,29,39,40},
                        {37,30,40,41},
                        {37,31,42,42},
                        {37,32,43,44},
                        {37,33,44,45},
                        {37,34,46,46},
                        {37,35,47,48},
                        {37,36,48,49},
                        {37,37,50,51},
                        {37,38,51,51},
                        {38,17,22,22},
                        {38,18,24,24},
                        {38,19,25,25},
                        {38,20,26,26},
                        {38,21,28,28},
                        {38,22,29,29},
                        {38,23,30,30},
                        {38,24,31,32},
                        {38,25,33,33},
                        {38,26,34,34},
                        {38,27,35,35},
                        {38,28,36,37},
                        {38,29,38,38},
                        {38,30,39,39},
                        {38,31,40,41},
                        {38,32,42,42},
                        {38,33,43,43},
                        {38,34,44,45},
                        {38,35,45,46},
                        {38,36,47,47},
                        {38,37,48,49},
                        {38,38,49,50},
                        {39,18,23,23},
                        {39,19,24,24},
                        {39,20,25,25},
                        {39,21,27,27},
                        {39,22,28,28},
                        {39,23,29,29},
                        {39,24,30,30},
                        {39,25,31,32},
                        {39,26,33,33},
                        {39,27,34,34},
                        {39,28,35,35},
                        {39,29,36,37},
                        {39,30,38,38},
                        {39,31,39,39},
                        {39,32,40,41},
                        {39,33,41,42},
                        {39,34,43,43},
                        {39,35,44,44},
                        {39,36,45,46},
                        {39,37,46,47},
                        {39,38,48,48},
                        {39,39,49,50},
                        {40,17,21,21},
                        {40,18,22,22},
                        {40,19,23,23},
                        {40,20,24,24},
                        {40,21,26,26},
                        {40,22,27,27},
                        {40,23,28,28},
                        {40,24,29,29},
                        {40,25,30,30},
                        {40,26,32,32},
                        {40,27,33,33},
                        {40,28,34,34},
                        {40,29,35,35},
                        {40,30,36,37},
                        {40,31,38,38},
                        {40,32,39,39},
                        {40,33,40,40},
                        {40,34,41,42},
                        {40,35,42,43},
                        {40,36,43,44},
                        {40,37,45,45},
                        {40,38,46,47},
                        {40,39,47,48},
                        {40,40,48,49},
                        {40,41,49,49},
                        {41,18,21,21},
                        {41,19,22,22},
                        {41,21,25,25},
                        {41,22,26,26},
                        {41,23,27,27},
                        {41,24,28,28},
                        {41,25,29,29},
                        {41,26,30,31},
                        {41,27,32,32},
                        {41,28,33,33},
                        {41,29,34,34},
                        {41,30,35,35},
                        {41,31,36,37},
                        {41,32,37,38},
                        {41,33,39,39},
                        {41,34,40,40},
                        {41,35,41,41},
                        {41,36,42,42},
                        {41,37,43,44},
                        {41,38,44,45},
                        {41,39,45,46},
                        {41,40,47,47},
                        {41,41,48,48},
                        {42,20,23,23},
                        {42,21,24,24},
                        {42,22,25,25},
                        {42,23,26,26},
                        {42,24,27,27},
                        {42,25,28,28},
                        {42,26,29,29},
                        {42,27,31,31},
                        {42,28,32,32},
                        {42,29,33,33},
                        {42,30,34,34},
                        {42,31,35,35},
                        {42,32,36,36},
                        {42,33,37,38},
                        {42,34,38,39},
                        {42,35,39,40},
                        {42,36,41,41},
                        {42,37,42,42},
                        {42,38,43,43},
                        {42,39,44,44},
                        {42,40,45,46},
                        {42,41,46,47},
                        {42,42,47,48},
                        {43,19,21,21},
                        {43,20,22,22},
                        {43,21,23,23},
                        {43,22,24,24},
                        {43,23,25,25},
                        {43,24,26,26},
                        {43,25,27,27},
                        {43,26,28,28},
                        {43,27,29,30},
                        {43,28,31,31},
                        {43,29,32,32},
                        {43,30,33,33},
                        {43,31,34,34},
                        {43,32,35,35},
                        {43,33,36,36},
                        {43,34,37,37},
                        {43,35,38,38},
                        {43,36,39,40},
                        {43,37,40,41},
                        {43,38,41,42},
                        {43,39,42,43},
                        {43,40,43,44},
                        {43,41,45,45},
                        {43,42,46,46},
                        {43,43,47,47},
                        {44,19,20,20},
                        {44,20,21,21},
                        {44,21,22,22},
                        {44,22,23,23},
                        {44,23,24,24},
                        {44,24,25,25},
                        {44,25,26,26},
                        {44,26,27,27},
                        {44,27,28,28},
                        {44,28,30,30},
                        {44,29,31,31},
                        {44,30,32,32},
                        {44,31,33,33},
                        {44,32,34,34},
                        {44,33,35,35},
                        {44,34,36,36},
                        {44,35,37,37},
                        {44,36,38,38},
                        {44,37,39,39},
                        {44,38,40,40},
                        {44,39,41,41},
                        {44,40,42,42},
                        {44,41,43,44},
                        {44,42,44,45},
                        {44,43,45,46},
                        {44,44,46,46},
                        {45,20,20,20},
                        {45,21,21,21},
                        {45,22,22,22},
                        {45,23,23,23},
                        {45,24,24,24},
                        {45,25,25,25},
                        {45,26,26,26},
                        {45,27,27,27},
                        {45,28,28,29},
                        {45,29,29,30},
                        {45,30,30,31},
                        {45,31,31,32},
                        {45,32,32,33},
                        {45,33,33,34},
                        {45,34,34,35},
                        {45,35,35,36},
                        {45,36,36,37},
                        {45,37,37,38},
                        {45,38,38,39},
                        {45,39,39,40},
                        {45,40,40,41},
                        {45,41,41,42},
                        {45,42,42,43},
                        {45,43,43,44},
                        {45,44,44,45},
                        {45,45,45,45},
                        {46,29,28,28},
                        {46,30,29,29},
                        {46,31,30,30},
                        {46,32,31,31},
                        {46,33,32,32},
                        {46,34,33,33},
                        {46,35,34,34},
                        {46,36,35,35},
                        {46,37,36,36},
                        {46,38,37,37},
                        {46,39,38,38},
                        {46,40,39,39},
                        {46,41,40,40},
                        {46,42,41,41},
                        {46,43,42,42},
                        {46,44,43,43},
                        {46,45,44,44},
                        {47,20,19,19},
                        {47,21,20,20},
                        {47,22,21,21},
                        {47,23,22,22},
                        {47,24,23,23},
                        {47,25,24,24},
                        {47,26,25,25},
                        {47,27,26,26},
                        {47,28,27,27},
                        {47,30,28,28},
                        {47,31,29,29},
                        {47,32,30,30},
                        {47,33,31,31},
                        {47,34,32,32},
                        {47,35,33,33},
                        {47,36,34,34},
                        {47,37,35,35},
                        {47,38,36,36},
                        {47,39,37,37},
                        {47,40,38,38},
                        {47,41,39,39},
                        {47,42,40,40},
                        {47,43,41,41},
                        {47,44,41,42},
                        {47,45,42,43},
                        {47,46,43,44},
                        {48,21,19,19},
                        {48,22,20,20},
                        {48,23,21,21},
                        {48,24,22,22},
                        {48,25,23,23},
                        {48,26,24,24},
                        {48,27,25,25},
                        {48,28,26,26},
                        {48,29,27,27},
                        {48,30,27,27},
                        {48,31,28,28},
                        {48,32,29,29},
                        {48,33,30,30},
                        {48,34,31,31},
                        {48,35,32,32},
                        {48,36,33,33},
                        {48,37,34,34},
                        {48,38,35,35},
                        {48,39,36,36},
                        {48,40,36,37},
                        {48,41,37,38},
                        {48,42,38,39},
                        {48,43,39,40},
                        {48,44,40,40},
                        {48,45,41,41},
                        {48,46,42,42},
                        {48,47,43,43},
                        {49,23,20,20},
                        {49,24,21,21},
                        {49,25,22,22},
                        {49,26,23,23},
                        {49,27,24,24},
                        {49,28,25,25},
                        {49,29,26,26},
                        {49,31,27,27},
                        {49,32,28,28},
                        {49,33,29,29},
                        {49,34,30,30},
                        {49,35,31,31},
                        {49,36,32,32},
                        {49,37,33,33},
                        {49,38,33,34},
                        {49,39,34,35},
                        {49,40,35,35},
                        {49,41,36,36},
                        {49,42,37,37},
                        {49,43,38,38},
                        {49,44,39,39},
                        {49,45,40,40},
                        {49,46,40,41},
                        {49,47,41,42},
                        {49,48,42,42},
                        {50,21,18,18},
                        {50,22,19,19},
                        {50,25,21,21},
                        {50,26,22,22},
                        {50,27,23,23},
                        {50,28,24,24},
                        {50,29,25,25},
                        {50,30,26,26},
                        {50,31,26,26},
                        {50,32,27,27},
                        {50,33,28,28},
                        {50,34,29,29},
                        {50,35,30,30},
                        {50,36,31,31},
                        {50,37,31,32},
                        {50,38,32,32},
                        {50,39,33,33},
                        {50,40,34,34},
                        {50,41,35,35},
                        {50,42,36,36},
                        {50,43,37,37},
                        {50,44,37,38},
                        {50,45,38,39},
                        {50,46,39,39},
                        {50,47,40,40},
                        {50,48,41,41}
#ifdef DEBUG
#endif
    sMin = 1023;
    sMax = 0;
  tft.begin();
  if (!RADIO_MODE) {
    testV(DIMGREEN);
    delay(2000);
    testV(BRTGREEN);
    delay(2000);
  int to;
  if (RADIO_MODE)
  else {
    int freq;
    if (TONE_DEMO) {
      if (MUSICAL_NOTES)
#ifdef DEBUG
#endif
  lastOpening = to;
  to   -= 2;
  if (to   < 0) to   = 0;
    if (to == (AMAX-1))
//    v_to = DIMV;
    } // End for (i...)
    } // End for (i...)
  if (RT_CAL) {
  else {
#ifdef DEBUG
#endif
  // Convert to angle
  long tmp;
#ifdef DEBUG
#endif
  return dampen(tmp);
#ifdef DEBUG
#endif
  int from = Y0;
  if (DOUBLE_WEDGE)
    from = YMAX;
    phi = fetch(i, 0);
    x   = fetch(i, 1);
ERROR MSG:
C:\Users\edfri\Documents\Arduino\ST7735_Magic_Eye\ST7735_Magic_Eye.ino:57:97: error: no matching function for call to 'Adafruit_ST7735::Adafruit_ST7735(int, int, SPIClass*, int, int, int)'
In file included from C:\Users\edfri\Documents\Arduino\ST7735_Magic_Eye\ST7735_Magic_Eye.ino:8:0:
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:57:3: note: candidate: Adafruit_ST7735::Adafruit_ST7735(SPIClass*, int8_t, int8_t, int8_t)
   Adafruit_ST7735(SPIClass *spiClass, int8_t cs, int8_t dc, int8_t rst);
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:57:3: note:   candidate expects 4 arguments, 6 provided
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:55:3: note: candidate: Adafruit_ST7735::Adafruit_ST7735(int8_t, int8_t, int8_t)
   Adafruit_ST7735(int8_t cs, int8_t dc, int8_t rst);
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:55:3: note:   candidate expects 3 arguments, 6 provided
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:54:3: note: candidate: Adafruit_ST7735::Adafruit_ST7735(int8_t, int8_t, int8_t, int8_t, int8_t)
   Adafruit_ST7735(int8_t cs, int8_t dc, int8_t mosi, int8_t sclk, int8_t rst);
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:54:3: note:   candidate expects 5 arguments, 6 provided
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:52:7: note: candidate: constexpr Adafruit_ST7735::Adafruit_ST7735(const Adafruit_ST7735&)
 class Adafruit_ST7735 : public Adafruit_ST77xx {
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:52:7: note:   candidate expects 1 argument, 6 provided
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:52:7: note: candidate: constexpr Adafruit_ST7735::Adafruit_ST7735(Adafruit_ST7735&&)
C:\Users\edfri\Documents\Arduino\ST7735_Magic_Eye\ST7735_Magic_Eye.ino: In function 'void setup()':
C:\Users\edfri\Documents\Arduino\ST7735_Magic_Eye\ST7735_Magic_Eye.ino:879:13: error: 'virtual void Adafruit_ST77xx::begin(uint32_t)' is protected within this context
   tft.begin();
In file included from c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST7735.h:4:0,
c:\Users\edfri\Documents\Arduino\libraries\Adafruit_ST7735_and_ST7789_Library/Adafruit_ST77xx.h:111:8: note: declared protected here
   void begin(uint32_t freq = 0);
exit status 1
Only Lines changed were:
rem line 7
add line 8
modify line 57
The constructor for the library does not use the dimensions of the display, and only the ESP8266 needs the pointer to the SPI. You would need something like this:
Adafruit_ST7735 tft = Adafruit_ST7735(CS_PIN, DC_PIN, RST_PIN);
There is no begin() function, there are initB() for ST7735B displays, and initR() for ST7735R displays. The initR() function takes an argument to identify the type of display, you will need to see the library documentation to determine which argument fits your display.
Got it
Thanks! I try all this
