I've used Weka (a machine learning suite of programs) to generate a Random Forest algorithm to accomplish speech selection on 10 different sounds. I would like to put onto an Uno. I have no idea of how to program the Uno with a Random Forest algorithm. I've searched the Web. Apparently transferring from Weka to any other machine is difficult. Hope you have some suggestions. Bob
How would speech samples be stored in the tiny memory available on the Uno?
Hi:
As I see it the random forest is a set of a couple of trees. The trees would be the decision makers and there is no need to store the speech samples. The Weka Random Forest algorithm has generated a model and I don’t know how to read it. I would like to go from the weka random forest model to C. If I used the J48 tree algorithm in Weka it is easy to write a C program for that. I’m working off on Instructables article on identifying speech and with its author to get my speech for the machine learning part. .
Bob
Robert (Bob) C. Gillespie
904-540-7679
![AC8DBE6F4ED546699B5AB94FF1C69990[27334984].png](https://europe1.discourse-cdn.com/arduino/original/4X/0/1/a/01ab5daab7d80ed08e90d033232251f6ca9a2b69.png)
"There is no such thing as spare time, no such thing as free time, no such
thing as down time. All we’ve got is this life time. Go. [Be]" — (H.L. Garfield)
I am afraid the Arduino Uno is really bad a math. It might be able to add a few numbers faster than you and me but in the world of machine learning it would not be allowed to the starting line for a competition.
Have a look at the following blog entry about Arduinos first step into the world of machine learning.
https://blog.arduino.cc/2019/10/15/get-started-with-machine-learning-on-arduino/
The Arduino Nano 33 BLE uses a ARM Cortex-M4 processor which seems to be the lowest entry point for this kind of applications. You will need a processor that is at least as powerful as that.
Exceptionally interesting. I will study it. Here is the link to the article in Instructables. It is also an experiment and a learning experience. I’ve learned a great deal using the data from the Instructables article and that is why I’m pursuing the potential for installing a Random Forest implementation on an Uno. Thanks for this reference. It is fantastic.
Bob
904-540-7679
Hi:
As I see it the random forest is a set of a couple of trees. The trees would be the decision makers and there is no need to store the speech samples. The Weka Random Forest algorithm has generated a model and I don’t know how to read it. I would like to go from the weka random forest model to C. If I used the J48 tree algorithm in Weka it is easy to write a C program for that. I’m working off on Instructables article on identig
904-540-7679
Thanks for this info. I look forward to studying it and learning. That is all I’ve done since I started this effort after reading the Instructables article. I am learning and I’m enjoying it.
Bob
904-540-7679
The Uno can easily run a simple neural network, with a hidden layer and 20 nodes or so, including the training and back-propagation step.
This example shows how to teach the Uno to recognize decimal digits, as they might be displayed on a 7 segment LED.
The main limitation is the 2048 bytes of RAM memory.
Note: A more complete explanation of the Arduino neural network code linked above is presented by the actual author of the code, in this blog page.
This is great!
Bob Gillespie
904-540-7679 Mobile
"Fewer invasions and more equations"
