I noticed strange behavior of the Cloud.
I connected a clean Arduino Nano 33 IoT, I added 3 variables (and 3 widgets) and only led on/off sketch for 1 switch. When I upload code or reset the arduino after connecting to the cloud the led state is updated randomly from the cloud. Dashboard changes its settings randomly. Sometimes it stays "1", sometimes it changes to "0". The other two variables also change their states randomly. Sometimes one comes on, sometimes two at once.
EDIT1:
I added a second Arduino Nano 33 IoT, with 3 new variables and a new dashboard. Now, every time when board connect to the cloud, if Switch is set to ON in the dashboard, the other two variables are turned on too by themselves. If Switch is set to OFF then the other two Variables will not turn on.
EDIT2:
Did I miss something? is this normal cloud behavior? If not, how to avoid such random data from the cloud.
#include "thingProperties.h"
delay(1500);
initProperties();
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
pinMode(LED_BUILTIN, OUTPUT);
ArduinoCloud.update();
void onColoredLight2Change() {
void onColoredLight1Change() {
void onSwitch1Change() {
if(switch1 == true) digitalWrite(LED_BUILTIN, HIGH);
else digitalWrite(LED_BUILTIN, LOW);
