Raspberry PI Pico usable in Arduino IDE?
IDE V2-RC6
I have a genuine Raspberry Pi Pico (early version). I can upload and successfully run the example "blink without delay". However when I try to upload a slightly larger program the upload fails.
I see a message "Performing 1200-bps touch reset on serial port COM10" but the "blink without delay" just uploaded.
I've installed this board driver:
Question: Is the Raspberry Pi Pico worth the bother?
Using library Wire in folder: C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\mbed_rp2040\3.0.1\libraries\Wire (legacy)
Using library SHT30 Sensor at version 1.2.1 in folder: C:\Users\John\Documents\Arduino\libraries\SHT30 Sensor
"C:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\John\\AppData\\Local\\Temp\\arduino-sketch-E46ECF3BACD69B8FD96AC3E4A9BF07C2/DisplayXferFcn_01.ino.elf"
Sketch uses 87408 bytes (0%) of program storage space. Maximum is 16777216 bytes.
Global variables use 43604 bytes (16%) of dynamic memory, leaving 226732 bytes for local variables. Maximum is 270336 bytes.
Compilation complete.
"C:\Users\John\AppData\Local\Arduino15\packages\arduino\tools\rp2040tools\1.0.2/rp2040load" -v -D "C:\Users\John\AppData\Local\Temp\arduino-sketch-E46ECF3BACD69B8FD96AC3E4A9BF07C2/DisplayXferFcn_01.ino.elf"
rp2040load 1.0.1 - compiled with go1.15.8
Upload error: Failed uploading: uploading error: exit status 1
this is better
