Hello, this is my very first ask in this forum, just to the point, i wanna using rc522 but using library is too easy and i cant learn something new with just learning using library, so i decided to using rc522 and code it without library, but i getting confused because why my code not work even i though it should be work fine, and i have been try with module too and its can its mean the wire is right already, and when i use my code that is not work, here is my code:
#include <SPI.h>
int RFIDsda = 2, RFIDsck = 13, RFIDmosi = 11;
int RFIDmi = 12, RFIDrst = 3;
byte RegFifoData = 0x09, RegFifoLevel = 0x0a;
byte RegCommand = 0x01, RegBitFraming = 0x0D;
byte RegFIFOLevelReg = 0x08, RegTxControl = 0x14;
void RFIDreset() {
digitalWrite(RFIDrst, LOW);
delay(5);
digitalWrite(RFIDrst, HIGH);
void RFIDsend(byte reg, byte data) {
digitalWrite(RFIDsda, LOW);
SPI.transfer((reg << 1) & 0x7E);
SPI.transfer(data);
digitalWrite(RFIDsda, HIGH);
byte RFIDread(byte reg) {
SPI.transfer(((reg << 1) & 0x7E) | 0x80);
byte val = SPI.transfer(0x00);
return val;
void RFIDgetCard() {
RFIDsend(RegCommand, 0x00); // Idle
RFIDsend(RegFifoLevel, 0x80); // Flush FIFO
RFIDsend(RegBitFraming, 0x07); // 7 bits utk REQA
RFIDsend(RegFifoData, 0x26); // REQA
RFIDsend(RegCommand, 0x0C); // Transceive
while (RFIDread(RegCommand) & 0x1F); // tunggu selesai
byte error = RFIDread(0x06); // ErrorReg
if (error != 0) {
Serial.print("Err: ");
Serial.println(error, HEX);
return; // ga usah baca FIFO
byte level = RFIDread(RegFifoLevel);
if (level > 0) {
Serial.print("Ada kartu! FIFO: ");
Serial.println(level);
for (byte i = 0; i < level; i++) {
Serial.print(RFIDread(RegFifoData), HEX);
Serial.print(" ");
Serial.println("Ga ada kartu.");
pinMode(RFIDsda, OUTPUT);
pinMode(RFIDrst, OUTPUT);
digitalWrite(RFIDsda, HIGH); digitalWrite(RFIDrst, HIGH);
SPI.begin();
Serial.begin(250000);
RFIDsend(RegCommand, 0x0F); // Soft reset
delay(50);
RFIDsend(RegTxControl, 0x83);
RFIDreset();
RFIDsend(RegTxControl, 0x83); // antena nyala setelah reset
RFIDgetCard();
delay(300);
Serial.print("ErrorReg: "); Serial.println(RFIDread(0x06), HEX);
Serial.print("Status2: "); Serial.println(RFIDread(0x09), HEX);
